Question about Panasonic DMR-ES35VS
Unusable I havent had my my Dvd recorder that long. I have used it quite a bit and have had a lot of trouble with it. It started out working fine and then one day The Dvd part switched and started saying that it was unable to play any dvd I put in no matter what it was I have tried using blank ones one that I have previously used on the unit and even store bought one and it will not play or recognize a single one. The Vcr part still works good but I can't get the Dvd part to do a single thing but irritate me. I have read the mauel so many times I could recite it for you It tells me differnt things to do but nothing specific I have done all of those things and I have gotten nowhere.
  • Panasonic Master
  • 12,061 Answers
I see this all the time my clients tear their hair out, over exactly this type of thing... and ya know what? 99% of the time the Hardware has actually gone "Fautly"... simply try another unit and see if ya problem still exists, I will almost guarrantee it will dissapear with replacement...
Posted on Aug 30, 2007
SOURCE:
New DVDs - New Problem
Same speed U bought 1-4x 1-8x 1-16x make sure have same speed disc.
Dec 17, 2009 | Sony RDR-VXD655 Recorder
TV was fine, now just static but works with DVD
Try using AV cable the same way you do when you hook up the DVD (- hook the cable box in place of the DVD) This will determine if you have problem with the tuner of the tv.
Oct 04, 2009 | Televison & Video
Error code E 4 54040990
jamesgranger - I think your DVD recorder is still having trouble reading the DVD+RW. It should not have a problem using a DVD+RW many times. Try taking the DVD+RW and put it in your computer. Find it in Explorer, right-click and choose "Erase". Then try to record to it using the DVD recorder again. If it works, you can use this to record, though it might be a pain.
The fact that your machine will record to the +R means that it works. Failing to work (record or erase) on the +RW means it's not reading it well. I would try running the lens cleaner again if it were mine. Also, I would make sure that the unit didn't have a lot of dust in it. If you can, power it off and use some spray-air to be sure there's no dust. You may have cleaned the lens, but if there's a lot of dust inside the unit, it will quickly find it's way back to the lens and you'll have the same problem. Michael
Jul 09, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Disc initialization Toshiba D-R250SB recorder
can i suggest you record vhs tapes on maxell dvd-r or tdk dvd-r (if you wish to keep them) used the dvd-rw to record those sporting events / movies or specials that you might not be around for....(because any one can accidently erase an dvd-rw).......now that formatting dvd-rw issue. i found that dynex http://www.dynexproducts.com/c-11-storage-media.aspx dvdv-rw works best with toshiba . i record all the ultimate fights erase (format) after i look at and on to next good luck
May 28, 2009 | Toshiba DRW2 DVD Recorder
Recording (toshiba dvr player se-r0265
Number SE-R0265 is not a Player. It is the model number of the Remote Control for a player.
However, your question is somewhat generic for all Player/Recorders. First you must use good original manufactures DVD media for recording. TY (Taiyo Yuden) is the Toshiba recommended media in many of its manuals. Verbatim and Fuji are also very good. They are more expensive, but very much worth the extra cost in reliability and headaches. Also, some older recorders will have trouble recording/playing back/finalizing newer 8X or 16X faster media. Try to by 4X and slower media if you are having problems, even with the three recommended above.
Second, DVD-R or R/W media has to be 'Finalized' before it can play on other recorders. DVD media do not. Try using DVD media if you continue to have trouble. Also, there are two recording/format types you can choose to record with on your DVDR Recorder, Video and VR, on -R/W media. Video is automatic Video format only on DVD media and do not need to be formatted (I think) before use or finalized after done recording.
If you are still having trouble using -R/W DVDs on other players, Try DVD DVDs in Video Format.
Finally, Toshiba is know for DVD media sensitivity. Many of their recorders have Firmware upgrades. Be sure you have the latest by looking in your manual to find your Firmware Version, then check out Toshiba's support site for any upgrades. But, start with good media, finalizing -R/W media, using Video disc format, then using DVD media, in this order.
Apr 03, 2009 | Televison & Video
DVD Recoder trouble
I have the LVW 5005 and was having a similar problem. Unplugged it tore it apart (looking if anything looked physically wrong) plugged it back in and it worked (and still is). Try unplugging it, letting is sit for 1/2 hour and plugging it back in. Might get lucky.
Dec 05, 2007 | Lite On LVW-5005 DVD Recorder
LG DBRH197
Read the timer record troubleshooting suggestions - timer record will only start is the unit is turned off!
Jul 03, 2007 | LG DBRH197H DVD Player/HDD Recorder
Panasonic DMR-ES35VS Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
