Question about KitchenAid KGRA806PSS Gas Kitchen Range
Oven surface burners do not light - KitchenAid KGRA806PSS Gas Kitchen Range
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Replace spark module, if available.
Posted on Oct 07, 2013
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
The "hot surface" light will
for the burner problem if the hot light wont go out you have a bad burner, that burner has a limiter on it that tells you when the burner is hot. as for the oven light i would try to change the bulb
May 12, 2011 | Kenmore Microwave Ovens
Ancient (1971) Frigidaire Cookmaster electric Compact 30 Range/Oven, model number RBG-533N, has two surface mounted red indicator lamps; one for the oven & one for the burners. The surface burner...
The stove has 4 burner switches with a # 2 terminal on each switch. This contact is similiar on all four switches. One of the switches # 2 contact is stuck. The burner switch should disconnect both legs of the 240 volt circuit, one leg through the # 2 terminal and one leg through the thermostat built into the burner switch. Disconnect the pilot lamp wire on each switch unti the light goes off and then replace that burner switch. This should correct the problem
phucks001@horrycountyschools.net
Oct 08, 2010 | Frigidaire Kitchen Ranges
Surface burners light but oven does not.
ignitor probably ...when you are sure of the part you need check out Appliance Parts Solutions....cheep parts!
Feb 08, 2010 | GE Kitchen Ranges
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Heating elements
I have a Whirlpool super capacity 465, the surface light for the burners comes on, the burners don't heat up, nor does the oven,(the light that says oven is on does not light up). I checked the main circuit breaker, that works. Are there any fuses in the range that would need to be replaced?
Thank-You,maddie
Feb 01, 2009 | Whirlpool GR460 Electric Kitchen Range
I just cleaned by hand by magic chef wall oven and now I can't
Pilotless ignition means that a hot surface ignitor lights the oven burner. It does take a little bit of time to light the burner. Maybe 30 seconds. If you want to make sure it lights take the bottom panel out from the oven and observe the hot surface glow and the burners light. No real danger as the gas valve will only open after the hot surface ignitor has satisfied the gas valve. Let me know how it goes. ken
Jan 02, 2009 | Magic Chef 9122 Gas Single Oven
KitchenAid KGRA806PSS Gas Kitchen Range Logo
70 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
