Question about Motorola TalkAbout T5530 2-Way Radio
Stop the sound of a Tone when Keying to Transmit..
I am unable to use the radio, when I key the mike to Transmit.. This loud tone noise come out the radio.. How to I stop this from happening?
    Master:
  • 623 Answers
That generally means that it's set to transmit on an invalid frequency.
Posted on May 04, 2014
SOURCE: ht1000
go to earphoneconnect.com..you'll fine their products intersting
Posted on Aug 04, 2008
eradiostore
  • 1654 Answers
SOURCE: ring tone thingy
Setting and Transmitting Call Tones
Your radio can transmit different call tones to other radios in your group so you can alert them that you want to talk.
To set a call tone:
1. With the radio on, press MENU 3 times. The current call tone setting flashes and displays.
2. Press + or - to change and hear the call tone.
3. Press MENU or PTT to set the new call tone or turn feature off.
http://www.motorola.com/mdirect/manuals/T50-T55_UserGuide.pdf
Posted on Sep 07, 2008
SOURCE: muting the sound
Transmitting a Talk Confirmation Tone
You can set your radio to transmit a unique tone when you finish transmitting. It is
like saying Roger or Over to let others know you are finished talking.
• To turn talk confirmation on, press and hold (+)while you turn the radio on. When
you release after transmitting, your confirmation tone transmits and displays.
• To turn talk confirmation off, turn your radio off and then back on while pressing
and holding (+).
Posted on Nov 23, 2008
eradiostore
  • 1654 Answers
SOURCE: how do i stop my radio from making that bloop
You are either describing a CALL TONE ( The Call Tone obtains others’ attention before you start talking) or the ROGER BEEP (When you turn on this feature, your two-way radio transmits a unique tone when you
finish transmitting. It’s like saying “Roger” or “Over” and lets others know you’re
finished talking.)
To shut off the roger beep, hold in the plus + button while turning the radio on.
The CALL TONE may or may not be a feature of your T5210 radio. I am unable to open the online manual for it to tell for certain. If it does have a CALL TONE feature you would access it by pressing the MENU button until you see a "CA" on the screen along with a number. Using the plus or minus button change the setting to zero, followed by pressing the menu button or the PTT button. The zero setting is equivalent to OFF.
To
Posted on Oct 02, 2009
eradiostore
  • 1654 Answers
SOURCE: My radios are only a
Check the settings of your frequency, interference eliminator code and Qt filter. These three must match identically on all your radios. For basic operation set the code and Qt filter to zero (off).
Here is a link to the user guide for more details: http://www.giantintl.com/ContentManage/manuals/Moto/MR350-351%20User%20Guide%2012-16-08%20KEM-PK14190-90.pdf
Best regards.
Posted on Aug 23, 2010
Why is humming coming from speaker when mic is keyed?
this is strange as most times if a proper transmit key is depressed , then the radio switches from receive to transmit , the mfg know this would cause some great squeal from receiver /transmitting so close to a receiver so the part that is the receiver is muted to keep this from happening , id say there is some fault in the part that does this muting of receiver
Apr 13, 2016 | Radio Communications
When I key up my radio it creates a tone and will not transmit. Does anyone know why. They worked fine for a while
Model? Brand? Anything else? It "sounds" like you are trying to transmit on an unprogrammed channel. Hard to say without more information.
Apr 16, 2015 | Radio Communications
Radio works but can transmit and only hear ocassional traffic
thats happening a lot today.I don't think its your radio ,I think its just background noise because there is no one on the radio but you at the time .There is so much skip working all the channels that it creates a sssshhhhh noise in the radio and it gets real loud at times. some times going over an s 9 and if that is the case you won't be able to hear or talk on the radio .
Apr 12, 2014 | Radio Shack Radio Communications
No transmit or recieve
sounds like a repair for a tech to me.
Jan 16, 2014 | Galaxy Radios SSB Echo Base Station CB...
Tone Sound when Keying mike
You probably are referring to a "roger beep" which can be enabled to make ordinary transmissions annoying to anyone on the receiving end. Usually it is possible to disable this "feature".
Jul 26, 2013 | Radio Communications
CB Humming loudly when not transmitting, but recieving
You probably will have to dig into the unit to find out what's causing the hum.
The 5-pin connector is a mike connector, not a DIN
Jul 03, 2013 | Radio Communications
FT-890AT yaesu transceiver has distorted transmit audio
Hi Ronald,
Could the problem be related by having the mike to close to your mouth? This is the most common cause of over-modulation/ distortion from the transmission end.
If you have the mike 3-6 inches from the mouth and speak in an even non loud tone, that would help sort that out. If this is not the source of the over modulation/distortion, then you may have a transmitter issue, which would require the unit to be serviced by a qualified radio technician or ham radio operator, if you know one willing to look at it for you.
I hope that this has helped you.
Cheers,
Peter
Dec 01, 2012 | Radio Communications
I just purchased two Baofeng BF 888s radios and had them programmed to our frequency here. They will both receive and transmit with each other but not transmit to the radios we already had. Any ideas?
Your radios could be programmed with subaudible tones (CTCSS) or digital code squelch (DCS) which the new radios do not have. They can be programmed for it, you need to find out what tone/code you are using.
It could also be that your existing radios are programmed for a "duplex" repeater channel, with different transmit and receive frequencies. The new radios might be on the "repeater output" frequency so they would not activate the repeater.
Both could be the case, missing tone and duplex frequencies.
I would check the programming of the new and old radios, especially for tone/code squelch.
Sep 13, 2012 | Generic Walkie Talkie BAOFENG BF-888s Two...
Superstar 121 with astatic power mic and texas star dx 500 power..when I key up to talk they say I sound like I'm a ways from the mic, but I have a loud roger beep...any ideas....mic?...
try a stock mike or a noise canceling one. Hard to run power on top of power. And see what your radio is dead keying into the radio...usally with a 500 it can take up to a 6 watt dead key.
Nov 10, 2009 | Superstar SS-121 120-Channels Base CB...
Motorola TalkAbout T5530 2-Way Radio Logo
75 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
