Question about Garden
I have a powercraft riding mower with hydrostatic drive it doesnt want to go i think the brake is stuck on
  • 109 Answers
SOURCE: MTD PRO RIDING MOWER/LAWN TRACTOR 18 HP ENGINE HYDROSTATIC DRIVE
In the back of the mower...probably under the seat, there should be a lever to release the transmission, or it is on the back plate. As far as the noise when trying to move drive the mower, the brake in the back, next to the transmission is jammed, use a 1/2 inch wrench to loosen it maybe 1/4 turn and this should unlock the brakes
Posted on Apr 22, 2009
  • 376 Answers
SOURCE: Craftsman 19hp won't move when in gear
There is a square key about 2 " long that fits in the slot on the axle and wheel and locks them together.. You probably didn't see it when putting tire back on and knocked it out. If you go back where you removed tire, you'll find it laying on the ground.
Posted on May 27, 2009
  • 127 Answers
SOURCE: where do you check the fluid levels for the
these are sealed units from the factory
Posted on Jun 26, 2009
  • 16 Answers
SOURCE: Rider won't move Hydrostatic
Ahh a Craftsman, out of my league slightly as they are not brought in to the UK.
From what I gather these are a Sears product so it would have been delivered to you "Dry" .ie no oil or fuel etc. Have you checked the Hydrostatic Fluid level? What type of Oil did you put in there when you built the machine up? If you have used the wrong grade it would give these type of problems. Most Hydro units on lawn tractors (here in the UK anyway) often just run on Engine Oil not Transmission Oil but this should be stated in your instruction manuals for the machine
Posted on Oct 15, 2009
  • 8 Answers
SOURCE: lt1000 hydrostatic drive stuck - will not engauge or disengauge
Does the tractor try to move or **** in any direction, if so you may want to check to see if the disk that controls the brakes is stuck, I've seen this many times.
Posted on May 18, 2010
Forward is slow
need to change hydrostatic fliud and filterthat will take care of it
Oct 02, 2014 | Husqvarna "YTH26V54 54"" Briggs And...
Craftsman lawn tractor 917.258.911 will not pull
I have a 917.273482 model but perhaps this will help. My tractor wouldn't move under engine power, and the wheels were locked, too (could not even push it). The probelm was that the brake has a linkage into the hydrostatic drive transmission, so that when the brake is applied, no engine force will be applied to the wheels. A spring releases (returns)this linkage when you take your foot off the brake. In my case the linkage was stuck. A copious amount of WD-40 into and around the opening that the linkage goes through into the transmission case made everything work fine once again. Hope you problem is as easy to fix as this.
Roger
Mar 19, 2012 | Craftsman Garden
What would cause the mower to hold back and make roaring noise and hardly go john deere model lx 279
A stuck brake maybe.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 19, 2010 | John Deere 195HP Hydrostatic 42" Cut...
Mowing right along and suddenly the tractor won't go move
it's 1 of 5 likely things
The drive belt from the engine to the transaxle is totally slipping or broken
The linkage from the control pedal to the transaxle is faulty.
The transaxle is broken (not user fixable)
The by-pass rod is pulled out
The brake pedal is pushed or the linkage is stuck in the "brake" position.
Jul 11, 2010 | John Deere 22HP Hydrostatic 42" Riding...
Lt1000 hydrostatic drive stuck - will not engauge or disengauge
May 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
HELPING A FRIEND WITH A CRFTSMN 18HP FRNT ENGINE LT2000 LAWN TRACTOR. THE ENGINE RUNS GREAT BUT WHEN HE RELEASES THE CLUTCH/BRAKE TO GO FORWARD OR REVERSE THE ENGINE DIES.
Put trans in neutral if trans is a gear drive and see if mower can be pushed, if it can you can push rule out stuck brake. If you have a hydrostatic trans you can put trans in bypass and push to see if brake is stuck. Remove drive belt at engine or at trans and try the cluch, if motor stays running there is a trans problem.
Mar 13, 2010 | Craftsman Garden
Not sure, but i think the electronic clutch is not engaging when i push the control levers forward or backwards. the engine and the mower deck both run, but the mower will not move
The electric clutch is to power the blades/mower deck. There is a belt that drives the hydrostatic pumps to power the wheels. Make sure the Parking brake is OFF. Could be a belt, spring, idler pulley.
Nov 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Apr 22, 2009 | Garden
Rear wheels will not turn. Worked fine when stored for the winter
Craftsman-Husky...same tractors-built in the same factory. I also had a problem with the hydrostatic transmission not providing power to the rear wheels. Here's what Sears told me:
(1) Check to make sure the drive belt is tight both under the engine-and the tranny.
(2) Air can get into the hydrostatic transmissions-especially during shipping (new mower) and storage.
So.....
Pull your freewheel pin out to disengage the tranny-then push the mower both forward and then backwards for 50' or so. Then push the freewheel pin back in and start the mower. If the transmission then works-drive forward-then backward-then forward repeating the cycle about 4 times. Drive about 50' in each direction. This should purge the air from the treansmission.
Mar 20, 2009 | Craftsman Garden
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
