Question about Radio Communications
Tone Sound when Keying mike - Radio Communications
    Top Expert:
  • Radio Commun... Master
  • 45,065 Answers
You probably are referring to a "roger beep" which can be enabled to make ordinary transmissions annoying to anyone on the receiving end. Usually it is possible to disable this "feature".
Posted on Jul 26, 2013
  • ni6z Mar 07, 2014
    hat brand of Radio?
What kind of Scanner has a microphone for TX?
Tone could also be created by the "wires " internet connection on a yaesu.
Posted on Mar 07, 2014
Stop the sound of a Tone when Keying to Transmit..
That generally means that it's set to transmit on an invalid frequency.
Jul 26, 2013 | Motorola TalkAbout T5530 2-Way Radio
Its a cobra 25ltd when i key the mike sometimes it hangs keyed up and does it with defferent mikes so the mike is not my problem.
take some electrical spray cleaner and lightly spray the inside of the radio where the mic plugs in. could also be a keying diode.
Jan 04, 2013 | Cobra 25 LTD 40-channel Classic CB Radio...
The radio will recieve but will not talk. The needle does not move when keying the mike. I have tried several mikes but nothing seams to help.
fried finals maybe? you may want to chk buffer /driver and final transistors for errors do you have the same problem for am/fm and ssb?
Dec 16, 2010 | Cobra 150 GTL DX Base CB Radio
Cobra 29 nw when you key the radio the swr meter doesnt move and if you move the swicth to cal you can adjust it with out keying the mike but has good recive any help would be good thanks dwayne
To check the SWR, you put the swicth on CAL and key the mike with mike gain turned down all the way,then calabrate it to the meter on the CAL scale,then swicth it to SWR before you unkey the mike, then what ever the needle falls back to, that is your SWR reading.
Apr 26, 2010 | Radio Communications
My galaxy66vc.b.radio stop transmitting
Take the cover off,you will need a vom-ohm meter,check the final and regulator,if the led light is working, then its not the keying transistor,check D77,under the mike plug, original #MA27T, the sub is NTE-605A varistor. Also check the mike plug,see if pa works. ..hope this helps..
Mar 25, 2010 | Galaxy Radios DX-66V Base CB Radio
Superstar 121 with astatic power mic and texas star dx 500 power..when I key up to talk they say I sound like I'm a ways from the mic, but I have a loud roger beep...any ideas....mic?...
try a stock mike or a noise canceling one. Hard to run power on top of power. And see what your radio is dead keying into the radio...usally with a 500 it can take up to a 6 watt dead key.
Nov 10, 2009 | Superstar SS-121 120-Channels Base CB...
Ring tone thingy
Setting and Transmitting Call Tones
Your radio can transmit different call tones to other radios in your group so you can alert them that you want to talk.
To set a call tone:
1. With the radio on, press MENU 3 times. The current call tone setting flashes and displays.
2. Press + or - to change and hear the call tone.
3. Press MENU or PTT to set the new call tone or turn feature off.
http://www.motorola.com/mdirect/manuals/T50-T55_UserGuide.pdf
Sep 07, 2008 | Motorola Talkabout T5420 (14 Channels)...
Mh9915 bellsouth
go to the shop from where u brought this phone & get the ringer changed
Mar 28, 2008 | BellSouth GH5816 Cordless Phone
Serial number 91101397
Could be a number of things. Assuming the mike gain is turned up, the mike or transmit audio circuit may be defective.
Mar 24, 2008 | Magnum DeltaForce CB Radio
Muting the sound
The sound produced by a Motorola radio when the mike is keyed refers to the "Transmitting Call Tone" which is another feature other than the "Interference Eliminator" or the "Roger Beep" feature.
On most Motorola GMRS/FRS TalkAbout radios, setting the "Call Tone" to 0 disables the feature. This is done with the radio ON by pressing on the "Menu" button 3 times which will result in the display showing the current Call Tone setting (flashing) and the letters CA; pressing on the <- or +> buttons will change selection (you will also hear the different Tones), select 0 (it may be up to 5 or 10 depending on the version). Press on the "Menu" or "PTT" button to set, save and exit.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 25, 2007 | Motorola TalkAbout T5530 2-Way Radio
Radio Communications Logo
128 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
