Question about Gateway LX6200-01 Phenom X4 9500 8GB DDR2 750GB ATI Radeon HD 3200 IGP Windows Vista Home Pr... PC Desktop
Wiring For Gateway LX6200-01 Motherboard
I need a connection diagram for a Gateway LX6200-01 Motherboard to determine where the connections are made.
  • Norman Bader Jul 26, 2013
    I have tried that. Their web site does not have that info.
    Top Expert:
  • Gateway Master
  • 34,832 Answers
You might be able to get a MB layout diagram from Gateway
Posted on Jul 26, 2013
abhishekdubl
  • 6 Answers
SOURCE: Motherboard wiring
cba3c97.jpgthis is the diagram for 103390 Intel (Augsburg) 915G
Posted on Jan 06, 2009
acdr
  • 1913 Answers
SOURCE: Replacing Motherboard
http://www.asisupport.com/ts_intel_955x_945_chipsets.htm
u can get from here.
witmoz
  • 389 Answers
SOURCE: looking for diagram for gt5656
goto this link and download the user guide.
http://support.gateway.com/s/PC/R/1015002R/1015002Rnv.shtml
Posted on May 09, 2011
StuartB
  • 807 Answers
SOURCE: I need to find the motherboard wiring diagram for a Gateway 505gr
Look for a make and model number and version number on the motherboard, gateway use various manufactures motherboards.
Then go to the makers website and look in the support section for the moherboard manual. Most motherboards have the connections marked on the board in very small print.
Posted on Feb 11, 2012
  • 3799 Answers
SOURCE: wiring diagram for where th power,reset.and ledd wires connect to my intel h67 motherboard
I don't know if this will help, but try this link.
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=3452
It is the gateway website support page. This is where you can get all the available info and drivers for your computer.
Posted on Mar 13, 2012
Need wiring diagram for 230 v for delta table saw cat. #36-451
Is the motor designed for dual voltages? The manual does not have a wiring diagram. I assume the motor lable diagram is faded or missing.
Dual voltage motors contain two sets of winding. Each set is rated for the lower voltage. To operate the motor on the higher voltage the windings must be connected in series. AND, they must be connected in the same direction. I use a variac to apply 30-40 VAC to the coils in various combinations, then measure the open lead voltage to determine the proper connections. This test should be performed by a licensed electrician.
Dec 05, 2013 | Delta Saws
Gateway motherboard diagram
display is this external display or laptop display?
Sep 27, 2013 | Gateway Laptop Nv57h17u 15.6 I3 2310m...
Wiring diagram for where th power,reset.and ledd wires connect to my intel h67 motherboard
Mar 13, 2012 | Gateway Dx4850-45 Desktop Pc
Feb 11, 2012 | Gateway 505GR PC Desktop
Motherboard layout diagram Gateway GT5654
usually if the wires have a name on the end of them check your motherboard very carefully probably with a torch or lamp you will see the same name as on the end of those wires on pins connectors on the motherboard if it says audio ac'97 on the end of the wire you will find the ac'97 pins on the motherboard then connect if it doesnt work take out and turn the connection around the other way to see thats all i can offer hope it helps
Dec 16, 2011 | Gateway Computers & Internet
I want to hook up a slim sub for my truck using this amp. how can I do that? Because this amp plays everything not just the bass
You will need to connect the low level input leads from the head unit to the amplifier (they are RCA cables). If there are no low level leads from the head unit, you will need to connect the wires from the speakers directly into the high level inputs using a wiring harness which should have been included with the amp. It should include a wiring diagram. You will need to use that diagram in conjunction with the truck's wiring diagram in order to know which wires to connect. They are color coded and once you have the vehicle wiring diagram (which can be downloaded by searching for it on google.com), it should be easy to determine which wires to connect.
Mar 04, 2011 | Audiovox AMP610 Car Audio Amplifier
Installing new motherboard
IF the motherboard came with a manual, I would start there. Most all of today's motherboards come with some sort of documentation on how things need to be connected. If the motherboard did not come with a manual, try going to the manufactures web site and find the documentation there. You probably are not going to want to use the same specs for the original motherboard that came with the PC in the first place.(in fact, don't)
Mar 12, 2009 | Computers & Internet
Motherboard wiring
Jan 06, 2009 | Gateway 830GM PC Desktop
Emachine motherboard connections
EMachine apparently doesn't think anyone needs to know the motherboard connections! But Gateway uses the same board and here is the answer to your predicament: http://support.gateway.com/s/MOTHERBD/FIC/105554/105554tc.shtml
Good luck, Steve Medley
Sep 21, 2008 | ASUS A7N8X-E Deluxe : ATX Socket A FSB400...
Gateway LX6200-01 Phenom X4 9500 8GB DDR2 750GB ATI Radeon HD 3200 IGP Windows Vista Home Pr... PC Desktop Logo
280 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
