Question about Samsung Digimax S500 Digital Camera
Camera won't turn on/lens extended
My friend was trying to take a picture and the camera shut off as soon as he hit the shutter button, and now the lens/zoomer thing is extended and it won't turn back on. If I hold the power button or the "view pictures" button down, the green light just blinks.
Check the battery. It is probbly low
Posted on Sep 06, 2007
    Genius:
  • 2,985 Answers
General system failure- Contact Samsung for repair cost.
Posted on Aug 30, 2007
Sony cybershot camera fell and lens is stuck
The lens may be out of position, or there could be dirt/dust in the lens mechanism. You could try some of the following suggestions:
1: Switch on the camera while you hold the shutter button and connect it to the AC adapter or to the USB cable at the same time.
2: Now by default the lens should get properly aligned if not try to twist them slightly by holding down the camera lens with soft hands.
3: Just push and pull the lens slightly as it extends automatically.
4: Now when the lens is in the hard surface power on your camera.
5: Try to hit the camera softly beside the lens which might solve the issue.
Sep 07, 2014 | Cameras
Kodak m522 turns off with lens extended
Here are some troubleshooting steps that you can try:
Dec 09, 2012 | Kodak M522 Digital Camera
My Digital camera wont start... I can view pictures but as soon as i click to take a pictures the camera shut off.
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Aug 26, 2010 | Sony Cyber-shot DSC-H50 Digital Camera
Batteries are fully charged. I can turn my camera on and look through my pictures, go through all the menus, etc., but as soon as I hit the button to take a picture, the camera just shuts off. I can...
Possible that the shutter or the focus mechanism is faulty and will need to be opened. Only if you are competent must you attempt to remove the camera as the mechansim and circuit will be delicate which needs experience. Ohter wise the best option is to ask a reliable technician to assist in opening and checking for a locked mechanism. Possible that some link had come loose or some foreign dirt has clogged. Hope you try. Good day
Aug 13, 2010 | Cameras
Lens gets stuck,and makes a clicking noise when trying to open
Hi
Thanks for using FixYa. With the camera closed and off point it straight up (lens towards the ceiling) and hit the power button while holding down the shutter release. When the camera opened, it immediately tried to focus for the picture it was told to take, and apparently it forced the lens to move.
You can also try blowing compressed air around the lens cover to clean it. Now slide a thin strip of paper between the lens cover shutters and the outer support ring and move it around 360 degrees. This will clear the debris stuck there.
With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat these steps several times to resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 04, 2010 | Samsung S1050 Digital Camera
My digital camera FinePix A900, keeps turning off when I turn it on. Unable to pull any menus. Batteries are good. any suggestions, is it fixable or do I have to buy a new one?
Try pressing the playback button to turn the camera on. This should turn the camera on just so that you can view any pictures stored on the card or internal memory. You can also access the menu functions this way. Also try pressing the picture/shutter button and see if the lens extends. If the camera shuts off when you press the picture button and the lens does not move or only moves a fraction then the problem is probably to do with the lens
Dec 18, 2009 | Fuji FinePix A900 Digital Camera
Casio Exilim Z40 - Lens Error Message
You can try to "fix" this problem by holding down the shutter release button as soon as the camera power up.If this does not work you will need to replace the lens assembly. This should only be done by a qualified tech.
This is usually caused by one of two circumstances. (1) The user dropped the camera while the lens was extended causing a mechanical failure. (2) The lens attempts to extend while in a pouch or pocket without the user's knowledge. This usually happens when the user is carrying the camera with the battery in. When/if the REC button or power button is pressed accidentally, the lens will attempt to extend but can't. This causes the servo motors to "smoke".
Apr 25, 2009 | Casio Exilim EX-Z40 Digital Camera
My lens does not open or extend.
my camera is doing the same thing but i dropped it once and ever since it won't open anymore... it's definetely broken right? this sucks
Jun 15, 2008 | Canon PowerShot A520 Digital Camera
Nikon L3 Lens wont extend
Hi:
If the camera has not been abused, such as dropping, impact of some sort, or restricting the extending lens, then there is an internal problem.
See my other posts on suggestions of selling it.
Nov 27, 2007 | Nikon COOLPIX L3 Digital Camera
Camera shuts off when you click the shutter button
The same thing happened to mine. While not a solution, my workaround has been to turn the LCD screen off when I'm shooting. It's worked so far.
Jul 21, 2007 | Fuji FinePix 2650 Digital Camera
Samsung Digimax S500 Digital Camera Logo
102 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
