How can I restore factory settings on my tv?
Lost picture and sound while in Menu mode. I tried unplugging tv for 30 minutes. That did not help,
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
To set it to its factory settings, you have to enter its service mode option. If you are somewhat sound in electronics, you can enter this mode, and set it into factory settings. By the way, what is the brand name of your TV? Model number? Provide more details please. If you wish to get more, check the site linked here. It has details about service mode entry and adjust methods to many brand TVs. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option.
Posted on Jul 26, 2013
  • 236 Answers
SOURCE: tv has sound but no picture
Sounds like you have lost video somewhere in the video circuits. Possibly the picture tube could have gone bad or lost filiament voltage. You can check to see if you have high voltage by holding your bare arm close to the screen. The hairs will stand up if you have high voltage. Absence of high voltage will also cause a black screen,but the sound might not work either since on some sets the power for the sound is supplied from the same circuit as the high voltage. Stargazer
Posted on Jan 28, 2007
chrispurs1
  • 372 Answers
SOURCE: Bush 22" LCD TV
Hi.
What is the TV model number ?
Posted on Nov 29, 2007
techman
  • 3130 Answers
SOURCE: Lost the Manual & can't tune digital channels, option not available on menu ?
Here is a link where you can down load a free copy of your customer user manual. Good Luck
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV32FS120&LOC=3
Posted on Feb 03, 2008
jerryg50
  • 1667 Answers
SOURCE: sony kv32ds60u engineers menu
If you did not save the damage that you did, or do any damage from over-adjustment, you can make a re-set to before the adjustments were made by simply unplugging the set from the AC mains for about 10 to 20 seconds. If the improper parameters were saved, or damage was done from over adjustment, then this procedure will not work for you.
Read on for more details:
There is no default actual default. Each set is individualy set up for its optimum performance. At the factory, during the manufacturing process they set the EPROM firmware parameters to a so-called reference value before they start the calibration. This is done during production on the burner that programs the EPROM.
If the paramters are too far off to have the set working, you will have to take the set for service at a factory service rep. The factory service shop will most likely have to change the complete circuit board that constains the uPC EPROM with a new one that has the reference factory set-up. They will then have to go through the complete set-up with calibration procedures using the factory recomended calibration standards instrumentation to match for best performance. To manualy do a full calibration on the test bench it can be about 2 hours of work.
Because the factory service setup was not meant for consumer use, it is possible to over adjust parameters to the point where you can lock the set out of operation, or actualy do damage by over-adjustment.
Jerry G.
Posted on Apr 19, 2008
marked
  • 6487 Answers
SOURCE: PRIMA HT2778P pin-cushioned blue screen - service menu reset needed
Try this one:
1. Unplug your power cord from the box (NOT THE
WALL!)
2. Wait 3-5 min... No more than 5 MIN (very important)
3. Hold down the power and select button at the same time and don’t let go.
4. Have someone plug the power back in… and keep holding the power and select button.
5. Don’t let go until it gets to 0 (it's about 5 min)
6. Once it gets to 0 then it will stop counting down, that when you let go!!
7. Don’t touch anything,
8. The screen will reset and it will go blank. nad that's it
Hope that helps....
Posted on Jul 10, 2008
The sound has gone on my TEAC LCDV1901M tv
have u tried the volume control on the side panel of the tv...if that does'nt work , unplug the tv and leave it off for a five minutes ...also you can try going into the menu mode of the tv and factory reset it...hope this help...
May 02, 2014 | RCA 20F610TD TruFlat TV/DVD
I have a dynex 55 inch tv it turns and runs for a whike and then shuts off I can not get it to turn back on until I unplug it and dose the same thing over again can any one help.
I would recommend doing power cycling your TV. Turn it off, unplug it and leave unplugged for a few minutes, then plug it in and power it on. If this doesn't fix the issue, then I would also ensure settings are back to factory defaults.
Press Menu
Press Left or Right to select Setup, then press Down to open the Setup menu.
Press Up or Down to select Restore Defaults, then press Right or Enter.
When a message asks if you want to restore factory settings, select Yes to restore the settings, or select No, to exit without restoring settings.
Oct 23, 2013 | Dynex DX-LCD32-09 LCD TV
My picture was like 1380x640 but now its 680x480 and i cant play my xbox because the picture is messed up how do i change this... ive tried going into setting and nothing works..
Have you tried adjusting the aspect ratio by pressing the ZOOM button. There you can select Normal, Wide, Zoom, and Cinema modes. Normal mode: selects the aspect ratio that matches the source's aspect ratio.
If this doesn't work, try power-cycling the TV by turning it off, unplugging it & leaving it unplugged for a few minutes. Then plug it back in, turn it on. You can also restore factory default settings.
Press MENU.
Press LEFT or RIGHT to select SETUP, then press DOWN to open the SETUP menu.
Press UP or DOWN to select Restore Default, then press RIGHT or Enter.
When a message asks if you want to restore factory settings, select YES to restore the settings, or select NO to exit without restoring settings.
Oct 23, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
Turn on the TV, red light stays on, picture goes blank after a second.
I have the same problem. Factory reset did not help (hold Vol-minus on set and menu on remote five seconds, then unplug). Can there be something in service mode that would help?
Aug 04, 2012 | Panasonic Viera TH-50PX80U Plasma TV
How do I reset my tv to factory settings. samsung 32 inch LA32R81WDx/xSA
On a different Samsung TV, there is a Picture Reset in the Picture Menu on the OSD. (It's at the bottom of the list.) Similarly the sound reset is in the Sound menu. There is no global reset. (If your Samsung TV's OSD menus are different try under the Support menu.)
I hope this helps.
Aug 05, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
No TV Picture
Unplug,replug an hour later,might reset to factory setting.Tries stop all timer setting.
Dec 29, 2009 | Televison & Video
Hourglass Picture
can you please identify the unit model/maker
Jul 08, 2008 | Primax Electronics HT2778P TV
I lock the operation on the control panel
Please unplug the tv from the mains for 30 minutes this reset the tv factory mode...................
Jun 09, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
