Question about Cooling System for BMW 750Li
I have a bmw 06-750li. The ac is not blowing on high. Any answers. It appear to not working on the driver side and low on that right side
    Sergeant:
  • 352 Answers
BLOWER RESISTOR COULD BE WEAK AND FAILING...CHECK
Posted on Jul 27, 2013
1995 bmw 318ti
Did you recently add Freon in your AC system? You might have too much Freon in the system, which caused the AC compressor to recycle more frequent than normal. Or you might not have enough Freon in the system. These BMW's are very AC system are very finicky. Get an AC gauge and check the level (high side & Low side) pressure.
May 17, 2014 | 1998 BMW 318ti Compact
I am having problem with the A/C on my 2000 BMW 323i. I just Changed the Compressor, Drier, Expansion valve. In march I changed all the lines high/low pressure lines and also changed the Drier as well....
The pressure sw. on the dryer maybe weak but the way you explain it I think the sys is low on Freon. The reason for this is you said it did not get that cold. I would add a half can or one to the sys and see if the compressor cycles longer. Hope this helps.
Apr 26, 2017 | 2000 BMW 3 Series
2004 BMW X3 driver side low beam headlight
remove the air filter housing ,simple .this programme has a spell check thingy working and its driving me nuts ,it cant identify plain english ,write colour and it squiggles it out but color is ok .
Oct 30, 2009 | 2004 BMW 3 Series
AC unit blows cold on passenger side and warm on driver side.
There are separate blend doors for the passenger and driver's side. The blend doors divert, not block air, so it is unlikely that the blend doors are the problem. You need to check the operation of the re-circ door.
There may be some more duct work that attaches to the heat/air conditioning housing under the dash, that supplies air and or heat to both the driver side and passenger side of the car, the duct work on the driver side may have come disconnected.Check this also.
Hope this helps
Thanks
Smith.
Sep 11, 2009 | 2008 BMW 528i Sedan
2002 dodge caravan 3.3 liter v6 ac blowing warm. Refrigent appears ok. have it on 30 psi running. replaced clutch fuse. relay fuse ok. passenger side and rear blows less warm than driver side. Believe...
I assume you are charging this unit with cans from aparts store. If so the guages sold in those kits are not the best. That said I believe you are still low on refrigerant. Wear saftey glasses while working on A/C systems, and follow all saftey instructions. Then with a helper inside vehicle, run engine at appx. 2000 rpm. add refrigerant untill pressure stays at 35 psi with both blowers on high.
Jul 20, 2009 | Heating & Cooling
Ac not working cuts on and off when aux fans turn on. what could be the problem?ac was working fine, now it blows really low cold air then blows hot air.
i assume u r refering to the cooling fans,,, if this is so the freon is low ,fans come on and lower the high side ,there fore lowering the low side and the low side switch cuts it off and on,,charge it up
Jun 29, 2009 | 2002 Nissan Sentra
Hi, my husband and i have a 2006 optima. te ac
Absolutely not!  Never attempt to recharge from the high side. Recharging from the high side is extremely dangerous and could do harm to both you and the car.  If the low side pressure is only 10psi, you are low on refrigerant.  Most cars require 20psi to operate the compressor and should never fill to more than 40-45psi unless recommended by the manufacturer.  I'd re-check the pressure readings.  It's possible that instead of charging the system, while hooking up the hose, you've let freon escape, accounting for the hissing noise and the low pressure reading.  When recharging the AC system, it's important to have the car running and have the AC on high.  It's possible, you didn't have a good connection to the low side which also would account for the escaping refrigerant.  I hope this answers your question.  I'd try to recharge the system again on the low side, making sure the connection is good both at the low side valve and on the can of refrigerant.  Best of luck.
Greg
Jun 27, 2009 | 2005 Kia Optima
Ac blows cool only on drivers side of 2000 bmw 323i"
sounds like you have a low refrigerant charge. your best bet is to recovery the refrigerant in the system with an a/c recovery machine and see if you have the proper fill level. most likely the system is very low.
Apr 26, 2009 | 2000 BMW 3 Series
Vehicle Parts & Accessories Logo
95 people viewed this question
Top BMW Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
greg benton
Are you a BMW Vehicle Part and Accessory Expert? Answer questions, earn points and help others
