Question about RCA RP5430 Clock Radio
What do i do
My clock was unplugged for a couple days now it just flashes the time, but the time is wrong. I have the time zone setting correct but it still is wrong...what do i do?
  • 1 more comment
  • Anonymous Nov 07, 2007
    I have tried unplugging the radio for many hours, taking out the batteries and still it flashes the wrong time. What do I do now?
  • JasonHofmann Nov 29, 2007
    I have the same problem. I think it's a reception issue. I also cannot receive any AM stations in my apartment due to the metal in the windows.
  • Blondie9986 Feb 17, 2008
    aaa
    Problem Solver:
  • 4 Answers
Slide the switch with a lock, wake 1, wake 2 and clock to the clock position. Using the backwards and forwards buttons get time to the correct time. When correct time is reached, slide the switch to the lock position. Time will now be set.
Manual can be found in PDF form from RCA here: http://support.rcaaudiovideo.com/Downloads.ashx?prodid=56&mediaid=620&force=true&file=products/RP5430/media/RP5430_UMEN.pdf
Posted on Jul 14, 2008
SOURCE:
How do I set time zone? S/N: 502 16764PH.
Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there's nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet clock radio as follows: ZONE 1 - Atlantic Time ZONE 2 - Eastern Time (Default Setting) ZONE 3 - Central Time ZONE 4 - Mountain Time ZONE 5 - Pacific Time ZONE 6 - Yukon Time ZONE 7 To c h a n g e t h e d e f a u l t t i m e z o n e d i s p l a y, depress the TIME ZONE button. The number "2" will appear on the display indicating that the default zone is ZONE 2, Eastern Time. Hold theTIMEZONE button and then press either the or buttons your own time zone appears on the display, then release the buttons. The clock display will change to the correct time in the time zone you selected . The clock will always return to the correct time in the zone you selected after every power interruption. http://www.emersonradio.com/resources/owner_manuals/manual_1396274206.pdf
Apr 08, 2016 | Emerson Smart Set Alarm AM/FM Clock Radio...
Tip
Procedure For Setting Time Zones For Emerson Clock Radios
IMPORTANT: The first time you connect your new SmartSet® clock radio to
zone. If you live in the Eastern Time zone, there’s nothing else to do. Your
display to your own zone. You only do this one time and the SmartSet® will remember
interruption.
There are 7 time zones programmed into your SmartSet® clock radio as follows:
ZONE 1 — Atlantic Time
ZONE 2 — Eastern Time (Default Setting)
ZONE 3 — Central Time
ZONE 4 — Mountain Time
ZONE 5 — Pacific Time
ZONE 6 — Yukon Time
ZONE 7 — Hawaiian Time
To change the default time zone display, depress the Time Zone button.
The number “02” will appear on the display
Eastern Time
on Jun 12, 2009 | Emerson Smartset Clock Radio
I have a clock that will only come up as pacific time zone time. I am in central time zone in the usa. How can I correct this as it does not allow me to input any time changes manually? I have tried...
1. press "MODE" (it will show the alarm time)
2. press "ADJUST" (this will switch the time zones)
3. when it is on the desired time zone, press "MODE" to return to the clock.
Mar 15, 2011 | Audio Players & Recorders
How do I change the time on my TIMEX T307S clock?
Hello
To adjust time follow this.
Auto-Set Time and Date Settings
This model is equipped with the Auto-Set feature, meaning that the time and date have been programmed at the factory
and will already be set when you first plug the model in. Auto-Set will automatically adjust the time and date settings for
daylight-saving time and leap years. Auto-Set is programmed for Eastern Standard Time; if you do not live in this time zone,
you can easily switch the setting to one of six other time zones.
1. To change your time zone setting, press and hold the 8 Time Zone Button. The current Auto-Set Time Zone in the
lower-right-hand corner of the display will flash for approximately ten seconds, after which the display will revert to the
standard clock display.
2. While the Auto-Set Time Zone is flashing, press the 1 Reverse and 6 Forward Buttons to select your time zone.
The display will show each zone's current time setting. There are seven zones to choose from:
Auto-Set Time Zones
Z-01 Atlantic Standard Time
Z-02 Eastern Standard Time
Z-03 Central Standard Time
Z-04 Mountain Standard Time
Z-05 Pacific Standard Time
Z-06 Alaskan Standard Time
Z-07 Hawaiian Standard Time
3. Find your time zone, then press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the
setting to lock into place.
Manual Time and Date Settings
1. To change your time setting, press and hold the J Time Set Button so that the clock display begins flashing.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, shown by the PM Indicator.
3. After setting the time, press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the setting
to lock into place.
4. To change the calendar, press and hold the 9 Date/7-5-2 Button until the display shows the flashing year.
5. Press the 1 Reverse and 6 Forward Buttons to set the current year. When you have selected the year, press the
4 Enter Button, then use the 1 Reverse and 6 Forward Buttons to set the month/day.
6. After you have set the date, press the 4 Enter Button or wait for the display to beep twice and lock into place.
Mar 15, 2011 | Timex (T307S) Clock Radio
How do you manually reset a Lacrosse Atomic Clock. Ours is always 4 hours behind and has not caught up. We already changed the batteries.
There are many LaCrosse atomic clocks. Which model do you have? Support for most is available here: http://www.lacrossetechnology.com/support/home.php . Use the drop down menu to select the model.
For the analog clocks, there is a manual set button on the back of the clock. Press the button and wait for the clock to advance to the correct time. Then make sure the correct time zone button has been pushed. Then make sure the clock is in a location where it can hear the signal overnight. (For best results stand the clock upright in a window.)
For WT-2165U travel alarm, press and hold Set to enter the setting function. Then select the time zone (with + or -) then press and release Set. Set the DST setting to on or off as needed, then press and release Set again. The next setting option is the snooze alarm duration. Press and release Set again to change the hour manually (+ to increase). Press and release Set again to set the Minutes. Correct the date (year, month, day, day of week) similarly. Then set the display to 12 or 24 hour time. Press and release Set to finish and exit the set functions.
For some of the digital clocks you can set the time manually by pressing and holding Set. First set the time display mode (12/24), then press and release Set again. Then set the hours, followed by Set and then the minutes. Continue through other menu options or just do not press any buttons for several (30) seconds.
On the digital clocks, the item being changed will flash.
To avoid interference with the signal reception, place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal.
I hope this helps.
Feb 03, 2011 | La Crosse Radio Controlled Atomic Clock
Time Zone Setting
Sorry it took so long to give you a answer to your problem. I hope this information help you with the problem. Thank you for using FixYa and have a nice day! Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time
Nov 04, 2008 | Emerson Smartset Clock Radio
Sharper Image Weatherproof Atomic Clock Model OQ007
Press and hold the "Mode" button for a few seconds until the display flashes. The briefly press the Mode button to cycle through each setting. When you get to the "Zone" setting, press the up button to advance the time zone. Press the mode button repeatedly to finish cycling through the settings.
Done.
Nov 03, 2008 | Audio Players & Recorders
Why won't it automatically set time?
Sorry it took so long to give you a answer for the problem.I hope this information help you with your problem.Thank you for using FixYa and have a nice day! Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time
Oct 21, 2008 | Emerson Smartset Clock Radio
Cant set time
Rondart
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
On the back of the clock - left hand side if you've laid it down on it's face - is a row of switches. You need to start the time set-up with the clock having been unplugged so there's no time set in the memory5.gif.
Now, to those switches: The first (from the left) is DST = Daylight Savings Time - right now you'de set this to "ON."
The second switch is Time Zone: PST, MST, CST, EST (Pacific, Mountain, Central, Eastern). Set the switch to the time zone you are in.
The third is just the brightness.
Now, to set the time itself:
1 - Turn the clock face back up to where you can see it.
2 - LOOK AT THE CLOCK - LOL! This is an atomically set clock - you shouldn't need to set the time. The atomic clock bounces off of satellites all around the world. There is literally little to no "dead zones" for the clock, so you should never have to set your clock - just set it up like I state at the beginning.
Good Luck!
Mar 10, 2008 | RCA RP5420 Clock Radio
Centrios Atomic Desk Clock/Temperature
Here is how you adjust the time zone:
1.) push MODE till "AL" appears after the minute.
2.) tap "SET" (tap means push but do not hold) and time zone will advance.
3.) THE TRICK: The Time Zone can only be set in the Alarm Mode. Make sure you so not push and hold "SET" until the hour flashes as you would to set the alarm time. You just go into Alarm Mode and tap "SET" to advance the Time Zone by one zone per tap. When the Time Zone is where you want it, tap MODE to return to the clock and set the correct time.
Nov 08, 2007 | Audio Players & Recorders
RCA RP5430 Clock Radio Logo
607 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
