Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
F51 code Replaced the control panel and rps sensor and still get the F51 code. The washer dies work and does make a noise like it's trying to God something but it won't. Maybe a motor is bad?
  • kathie Jul 26, 2013
    washer does not work
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
THE LAST TIME I HAD THAT HAPPEN TO ME I FOUND SOMETHING STUCK IN THE OUTER TUB...
Posted on Jul 26, 2013
ladiestch
  • 19 Answers
SOURCE: Silverdragon posted on here about the Whirlpool
Tip mch back and locate the lg allen bolt in the center of the magnet and remove counterclokwise. The motor is actually a large magnet that revolve around a stator, a series of windings. Pull hard and place magnet away from any metal. Once off, remove the bolts holding the stator to the base and on the reverse side is the rps sensor. It looks like a wedge and is clipped onto the stator.
Posted on May 03, 2010
blueextc3221
  • 15935 Answers
SOURCE: F51 & F72 Codes
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Basket Re-engagement Failure.
F then 72 flashes when the basket check routine fails to determine if the basket is re-engaged after being disengaged.
Is the basket floating? If yes, pump out water. See Long Drain.
Does basket turn freely? If not, determine cause of friction.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Cabrio Washer
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Posted on Sep 28, 2010
blueextc3221
  • 15935 Answers
e-Guru
  • 3917 Answers
SOURCE: Hello~ We've been struggling to
Hi
Please check this list of codes in whirlpool cabrio.You will get a detailed idea about code F 50 and the test to be performed:-
http://www.appliancepartsquick.com/WhirlpoolCabrioWasherFaultCodes.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Aug 07, 2011
F51 diagnostic code meaning motor RPS failure. However, upon running a diagnostic test... everything works properly and goes to the 'done' setting. Also, when doing a load of laundry the machine...
There actually is a class action law suit against whirlpool for this error code well not the error code but the machine itself. I have also had the unfortunate task at one point of fixing this error code. It basicly comes down to replacing the rps sensor, the stator which is the motor, the control board, and in my case I even had to replace the wire harness from the rps sensor to the control board as well. I would try calling whirlpool and see if there are able to provide any support for the machine. Hint while calling them stateing that all you household appliances are whirlpool as well seems to add some leverage. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation. I await any questions that you may have. Thanks Rick
Sep 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
WHAT DOES CODE F51 MEAN ?
The F51 error is a RPS (rotary position sensor) board failure where the control board looses contact with the RPS during the machines operation. The RPS uses hall effect sensors to determine the speed and direction of the drive motor, allowing the control board to constantly monitor the motors operation. Because this error is a communication error and not a mechanical error with the motor itself (that would be and F52 error) we can limit our trouble shooting to the three items that make up the RPS circuit, the control board, the wiring harness, and the RPS itself.
Jan 29, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio WTW6700TW1 only fills little bit, won't turn or agitate, buzz sound/humming noise,code F51 flashes??
Jan 16, 2011 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Leaking and F51 error code on my Kemore Elite Oasis Washer
Jun 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite oasis HE is not working and the code f51 shows up. What is this code?
Sep 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis F51 code - already replaced RPS. Now what?
Sep 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite toploader code f51
Jul 25, 2009 | Kenmore Elite 45986 Front Load Washer
F51 code
Jul 17, 2009 | Kenmore Oasis HE 27082 Top Load Washer
F51 comes out and the machine stops working. what can i do
Jun 16, 2009 | Kenmore 22422 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
115 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
