Question about Waterwise 8800 Water Distiller
Waterwise 8800 leaking at the bottom
We have bought a new lid assembly for the pot and tried it out today. It is still leaking. Any suggestions?
Need a new crock for CH-9350. Are they available and what price?
I have a Tricity TSC09 6 litre Slow Cooker and I just love it its so handy. I smashed the lid and was so gutted I tried for hours online to find a replacement lid with no luck. I went shopping and bought a very cheap 6 to 7 Quart or 6 to 6.5 litre Slow cooker / Crock pot of roughly the same size shape the removable pot and lid fit. I bought a cookworks, signature, 24 euro 6.5 litre oval dog standard slow cooker and the lid fit, now I also have a removable pot replacement as well just in case I smash that too. Try that its a cheap option if it a good slow cooker and you cant get spares. You can always bring it back to the shop if it does not fit.
Nov 03, 2013 | WeatherWorks CH-9350 Slow Cooker
DCC-1200 leaks coffee onto carafe and warmer plate
My coffee pot was leaking over the carafe and onto the warmer. I found that this issue was caused by the carafe lid. The lid was not allowing coffee to flow into the pot fast enough. I removed the inner mechanism from the carafe lid (it pops off really easily) and just sit the lid on top of the pot while brewing, and no more leaks! After brewing, I put the mechanism back onto the lid and twist lid onto the pot.
Nov 16, 2012 | Cuisinart DCC-1200 Coffee Maker
Waterwise 8800 Water Distiller Troubleshooting
Our distiller has been leaking water out the bottom. We have ordered a new lid for the kettle, got it today and started the pot up. Well, it is still leaking. Do you have any suggestions?
Sep 05, 2012 | Waterwise 9000 Water Distiller
I have WaterWise 8800 since 2004, and now when I start it up - it keeps shutting itself off. Tried to clean out dust through the slots at top of machine where fan is. Still not work. What's wrong?...
Have you used Kleenwise to remove scale from the boiler? YOu can call Waterwise and they have technicians that can help you. I have had my Waterwise 7000 for many years, and love it! It makes the BEST tasting water, no chemicals or biologicals in it. I keep my machine clean and when I have questions, I call the tech guys for help.
Dec 23, 2010 | Microwave Ovens
The plastic top of the glass pot on two coffee makers drip.
This is a design flaw and can be corrected by enlarging the lid spout. First remove the plastic lid. Then use a fine grinder or sandpaper to remove approximately 1/8 inch of plastic from the lid spout. Follow the exact same contour of the oval spout. However, do not take off so much material that you disturb the small plastic tabs that hold the lid to the pot. Finish by slightly rounding the edges where the material was removed with fine sandpaper. No leaks - no drips.
Apr 26, 2009 | Cuisinart DCC-1200 Coffee Maker
Need plastic handle on Rival Crockpot lid.
For what it's worth, when the handle on my mother-in-law's crockpot broke, I went to Home Depot and bought a cheap wooden drawer knob (about $1 as I recall). I put a plastic washer between the knob and the glass and another under the screw head from the bottom (to prevent cracking the lid), tightened the screw and good as new.
Feb 20, 2009 | Rival 38601 Smart Pot 6-Quart
Need a Replacement Lid for Rival's Oval Smart Pot Crockpot
I found something on amazon,click here and take a look: Amazon com rival replacement lid. I hope this was helpful. Cheers
Nov 17, 2008 | Rival 38601 Smart Pot 6-Quart
Slow cooker lid
I buy a slowcooker Bravetti Professional Model KC272BN, and I can't bake nothing, because he don't heat enough, WHAT CAN I DO?
Sep 27, 2008 | Crock Pots & Slow Cookers
Can't find replacement crock.
the lid on our crock pot broke. We will sell you the bottom if you're interested.
This unit does not seem to be cracked.
Apr 05, 2008 | Rival SCVE500 Slow Cooker
Replacement cover for Rival 38601 Crock Pot
No, dont throw it away!!! You can use tin foil as a lid - I do this all the time as my lid shattered too and it works perfectly. You dont have to adjust times or anything.
Dec 09, 2007 | Rival 38601 Smart Pot 6-Quart
Waterwise 8800 Water Distiller Logo
43 people viewed this question
Top Waterwise Baby Gear Experts
Dorel UK
Dorel UK
Are you a Waterwise Baby Gear Expert? Answer questions, earn points and help others
