Question about Aqueon Modular LED Aquarium Lights - Colormax Lamp 36"
How many lumens is a aqueon 48" - Aqueon Modular LED Aquarium Lights - Colormax Lamp 36"
Technical data
lumens is a measure of light intensity
the lower the number the duller the light, the higher the number the brighter the light average shops have a level of limens around 750 as this is the safe light level for eyes
Wattage is current flow ( amps) and was used as a measure to show the intensity of the light
12 watt bulb is dull in 240 volts situation where a 500 watt bulb as in ( quartz halogen bulbs) is something that will blind you
You will notice a change in readings from incandescent bulbs-- the old units that had a filament in them--20 watt, 40 watt,60 watt, 100 watt to fluorescent lighting where the power saver bulbs have a rating of 12 watts is equal to 60 watts of the old bulb ( a rough attempt to show the lumens ratings )
this was an attempt to compare the light intensity so that customers could see how bright the new bulb would be
Now that there are LCD units , the wattage is so low that a comparison cannot be made so the shift is to lumens as a measure of light intensity ---in reality the results are the same
for example a torch with 3 X aaa batteries as a low lumen rating as you can see by the brightness of the light and if you compare that with the lumens rating of driving lights that light up the road for miles
the wattage(amps)for the big lumens rated lights will still be low compared to the head light s in current use
Mar 10, 2016 | Televison & Video
When my E2d. Ed defender. 200 lumens flash light is turn on it act like an strob light how to stop it or is it a weak batteries
No, that is a 'feature'. It is for signalling or blinding an attacker.
This is the instructions for the 500 lumen version but it will be the same. Nice light, I run Fenix Tactical. Strobe is usually gained by switching on and then half depressing the button and holding. If this doesn't work, contact Surefire direct.
The E2D LED DefenderĀ® Ultra is a compact 500-lumen flashlight featuring dual-output capability and self-defense enhancements. Utilizing a virtually indestructible high-performance LED and a Total Internal Reflection (TIR) lens, the E2DL Ultra is activated with a pushbutton tailcap click switch that also selects output levels: press or click once for a high-intensity 500-lumen white-light beam-ten times the light needed to overwhelm the night-adapted vision of an aggressor. Return to off and press or click again within two seconds for a 5-lumen ultra-long runtime low beam that's suitable for navigating at night or performing close-up tasks for hours. The Defender's crenellated Strike BezelĀ® provides further defensive options should the need arise. Slender and powerful, the E2DL Ultra is an ideal everyday-carry light.
Jan 08, 2016 | Surefire E2D LED Defender Flashlight Max-...
Replacement parts
if your heart is set on the original one you can get a replacement from aqueon , it will need to be sent from oversea's so time will take a bit , ME id just wire in a lamp cord switch to the original power cord , they only cost about five dollars and most evey hardware store's got them
Mar 08, 2014 | Aqueon 15 Gallon Column Tank Replacement...
Fluro tube
fluro tubes are rated in watts and they are connected to the length of the tube. ie 20 watt 20 inches---30watt 36 inches and 40 watt 48 inches. Some makers have a triclor fluro that have a higher lumens value but the wattage will be the same.. You will have to compare tubes in the lighting shop.
May 29, 2013 | Home
Can you fix the top rim of a 72 g bow front if the middle piece is broken?
if its only the top black plastic piece sure you can , id use superglue and let dry (hours not minutes) and wash it several times with water to clean residue off , (NO fish in tank or water ) if crack is to the top of actual tank < its possible with aquarium silicone but I wouldn't chance it id replace it
Mar 20, 2013 | Aqueon All Glass Aquarium Co. 72 Gallon...
My 72 gallon has started pulling apart at the brace. Where can a replacement be found
Try a local pet store, but from my experience once this starts the best solution is to just get a new tank
Jul 08, 2012 | Aqueon All Glass Aquarium Co. 72 Gallon...
I need this lipstick, I just love it and I can't use an over one. Please help me...I need to find it!
It is available on shopping.com for $5.99 : take a look at the link
http://www.shopping.com/Lumene-16-Oz-Lumene-Bright-Smile-Lipstick-7-So-Joyful-Lumene/info
Sep 10, 2011 | Lumene Bright Smile Lipstick 7 So Joyful...
How much lumens per square foot a garden should get?
Gardens should receive 1000-3000 lumens per square foot. Successful gardens usually are lit at around 2,000 lumens per square foot. During the vegetative stage, plants stretch out when they receive low levels of light. During flowering, the flowers are looser and sparse.
Aug 27, 2008 | Hydrofarm Flco95w Grow Light System
Aqueon Modular LED Aquarium Lights - Colormax Lamp 36" Logo
111 people viewed this question
Top Aqueon Reptile Experts
john h
Ned Halaweh
Ned Halaweh
ray gallant
Are you an Aqueon Reptile Expert? Answer questions, earn points and help others
