Question about Enhance Technology Computers & Internet
PT 6500 PE
Hi I am after a manual for a Power Tech Genset Model PT6500SE
I need a manual for onan 6500 lp genset
You can buy a service and or operator manual from advanced-power-technologies.com
Aug 13, 2012 | Onan Cummins RV QG 6500 Generator, 6500W,...
I have a 1997 onan emerald series GenSet 6500 I have been thru 4 starters it keeps breaking the drive gear assmbly WHAT CAN I DO PLEASE ITS ALREADY COST ME 400.00
Have you replaced the solinoid too? If not, maybe the solinoid is staying engaged, which keeps your starter, well starting. If the starter stays energised the flywheel WILL tear up the starter gear.
hope this helps
Nov 04, 2010 | Watts Onan Portable Generator - 5000 ,...
How to fix a genset 6500 generators that stops when you turn starter switch loose?
Check the oil level or any other alarm that can stop it.
The switch may have lost its middle stable position and drop directly to stop.
Try after you have the switch up for starting, let it easy back in middle position. If there it stops again. Try to move the switch down to "Stop". You should hear a click. If not replace the switch with the same type.
Jun 10, 2010 | Watts Onan Portable Generator - 5000 ,...
I have a Onan 7000 genset in my rv It starts and
Either you have a kill wire ( if I remember it is the brown wire) that is disconnected on one end or the other Or your in coach switch is bad.
Check the switch this way
Remove the switch from the dash/ mounting surface unplug the brown wire - start the genset - ground the brown wire - it should kill the motor
If it kills the motor your switch is bad
Mar 07, 2010 | Watts Onan Portable Generator - 5000 ,...
I have a 6500 lp onan marquis generator in my rv. It starts then stops after 15 seconds or so. I did a code check on it using the manual and it read code 47. Controller not reading generator running. Any...
ONANS ARE PRETTY QUIRKY AS IT IS NOT CONSUMER FRIENDLY. THE GENSET IS DESIGNED FOR ROUTINE AND SIMPLE MAINTENANCE PERFORMED BY THE OWNER, AFTER THAT, U WILL NEED TO TAKE IT TO THE NEAREST DEALER OR CUMMINS DIESEL REPAIR SHOP.
Jan 10, 2010 | Watts Onan Portable Generator - 5000 ,...
I just bought a 1999 Winnebago with an Onan 6500 genset. It only has 45 hours on it. It will run for 15 - 20 minutes with the AC on and then quits. It will restart after a few minutes and go through the...
a 10 year old genset with only 45hrs on it...sound like the carb may need replace. working with these rv units for 6+ years has taught me that you cannot clean one well enough to fix it. you will need a new carb. your local onan dealer can help. when new the warrenty makes known that 1hr per month under load will keep the carb clean and problem free. evaporating gas leaves deposits and eventualy plug fuel jets. no replacement parts are recommended. i've personaly worked on rv's with 200+ hous and no issues at all. hope this helps, good luck...
Jul 12, 2009 | Watts Onan Portable Generator - 5000 ,...
6.5 RV Onan generaotr wont kick in when loaded. checked automatic transfer switch and excited it manually, worked one time but never again,
1. Does the generator stay running when you start it the first time?
2. What color is the housing on this generator? Try to get the model number and serial number.
If the genset is shutting down on the first try, then your probably not creating voltage. However, if this is an older unit then the genset may stay running although no voltage is created. Place a volt meter on the genset to check for output voltage.
Mar 08, 2009 | Watts Onan Portable Generator - 5000 ,...
Computers & Internet Logo
48 people viewed this question
Top Enhance Technology Computers & Internet Experts
David Payne
David Payne
Are you an Enhance Technology Computer and Internet Expert? Answer questions, earn points and help others
