Question about Dishwashers
Kenmore 665 My 665.13132k700 drains very slowly. I cleaned the hose and the volume increased. than I blew compressed air in it and now it decreased.the pump spins the hose is clean. Did i blow out a check valve because the water swirls in the bottom pan. But where is the check valve?
  • 4 Answers
I disconnected hose closest to washer and cleared out blockage like hair, towel strings, little rocks and that did the job!!
Posted on Jul 26, 2013
  • 351 Answers
SOURCE: Whirlpool dishwasher not draining
blockage in the drain hose somewhere
Posted on Mar 20, 2008
  • 101 Answers
SOURCE: Dishwasher is full of water
The drain pump needs to be replace.
Posted on Apr 26, 2008
  • 28 Answers
SOURCE: dd601 ver2
have you check the tunnel between the kidney shaped sump and the well that the rotor motor locks into, often chips of crockery,seeds etc get caught in here and reduce the flow rate .You will need to remove the rotor motor,its easy, lift out racks then sprayarm to expose rotor motor turn locking ring to release stainless sieve lift out, then turn motor assembly anti clockwise and lift out.With something flexible eg 4mm insulated wire push it through tunnel from sump to motor well.
Posted on Jun 25, 2008
  • 27 Answers
SOURCE: DD601ver2
check for restriction in sump. ie remove rotor, push pipe cleaner or similar from filter sump into rotor sump
Posted on Jul 15, 2008
  • 171 Answers
SOURCE: Water won't drain
Hi fixitfran,
I'm Harvey the Master Plumber.
Your problem is: You have pulled the dishwasher out and checked hose. No kink in line. You have taken cleaned out dishwasher and no clog. You poored water into dishwasher and it drains from the bottom not throught drain hose. You have checked the drain hose on the bottom of the dishwasher and to no avail....you don't know what is causing this issue....can I help you out with this? LG-14AW3 Dishwasher does not drain properly and then powers itself off mid cycle. Filters are clean and there are no kinks in the drain hose. How do you fix this and will it be very expensive.
Have you recently replaced the garbage disposal? Sometimes the installer forgets to remove the knockout plug. All of the disposal manufacturers plug the d/w connection in case it is installed where there is no d/w. If there is a d/w, the plug must be removed.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 27, 2008
Wet floorboard 2004 toyota highlander passenger side
Often the floor of the passenger side become wet if the drain pipe of the evaporator is:
- Bent or twisted.
- Clogged or,
- There is any obstruction in its routing.
The drain pipe is a rubber hose about 14 mm in diameter, located just under the evaporator (cooling coil) casing on the passenger side.
The most easiest way to clean the pipe is to take it out, wash it from inside with water or to blow a compressed air slowly through its distal end while leaving it in place under the body.
Note: Keep your eyes away while blowing the air.
Hope that it works.
Jul 10, 2014 | 2004 Toyota Highlander
Loss of power shaky acceleration
Your PCV (Positive Crankcase Ventilation) there is an oil trap and associated hoses on the front of the engine. It runs from under the spark plug wire cover down beneath the starter (the oil trap is located here). Typically, the system plugs up and dries out. You need to remove the trap and hoses and clean the holes out beneath the trap which drain into the oil pan. I used a small brush and a bent coat hanger. I also drained the oil (needed to be changed anyway) and sprayed some sea foam down there to loosen things up and then blew it out with rubber hose with compressed air. It worked well. Pay special attention to cleaning out the bottom hole because this is where it gets clogged the most. The parts cost about $150 or so.
Apr 12, 2014 | 1999 Volvo V70
The freezer is leaking water into the fridge - shifted food in freezer, cleaned up mess. Air flow is good now. Will the increase air flow and the normal defrost cycle clear up problem?
you have to clean out the drain under the aluminum fins in the freezer. its called the condensate drain, blow out with compressed air or clear with thin metal wire.
May 04, 2010 | Kenmore Refrigerators
Dishwasher will not drain. Used compressed air and blew the drain hose. After that, dishwasher worked fine for a couple of cycles. Then problem started again.
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 24, 2010 | GE Profile PDW8400J Built-in Dishwasher
Kenmore 80 series model #110.26882503 fills slowly
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 12, 2009 | Kenmore Washing Machines
Water standing in bottom of dishwasher,after wash cycle is finished? This is a Kenmore model 665.1565591
My problem too recently.
I blew compressed air back through the drain line and let it bubble up in the standing water in the dishwasher. Then I put it through another cycle and everything was fine. Something must have gotten clogged and the air blew it out.
Mar 19, 2009 | Kenmore Dishwashers
Kenmore Elite 795 75542401
I replaced my "entire" ice cube maker (tube,hoses,water pump, ice maker) and it still pooled water at the bottom. I removed the back panel in the freezer and noticed the ciols go through a defrost cycle and water forms in tray under coils. I removed the lower panel on rear of fridge -and found a drain hose near the water solenoid/pump. I blew compressed air into the hose and hopefully unblocked it so it can drain into the pan not the freezer.
Jul 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
My dish washer does not drian completly
the water must pump uphill to the air gap. the last water in the line drops down the hose, and is in quantity equally to the volume of the hose from the bottom of the pump to the top of the hose. that flows to the bottom of the sump in the unit. if enough, it appears as residual water in the bottom. its ok.
m
Oct 27, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
37 people viewed this question
Top Dishwashers Experts
Owen Barnes
