Question about Toshiba 32AV502U 31.5 in. LCD HDTV
Toshiba lcd tv 32" making noise by speaker
Toshiba lcd tv model# 32av502u. lcd tv working fine after replace power supply. couple dates after lcd tv have noise from speakers when i watch tv channel program. i try switch to another channel & all channel. samething have noise in it. what is problem? how to repair it?
    Top Expert:
  • Toshiba Master
  • 12,223 Answers
Test this steps and fix it. God bless you
Line noise is feeding in from the AC line. Use an AC liner filter to block the line noise. RF (radio frequency) interference is being picked up by the power line or wiring. Remove sources of RF interference, such as fluorescent lighting or wireless devices not designed to work with audio/video equipment. Wires between the components are on top of one of the components; the transformers are causing RF interference. Be sure that wiring goes behind the components rather than on top or between components. If there is an equalizer in use, there could be a ground loop. Ground loops can be resolved by installing GLI's (ground loop isolators) on the cables connecting to the equalizer.
Posted on Jul 25, 2013
SOURCE: Toshiba LCD Colour TV (Model 15VL63B)
the invertor board faulty
Martin
Posted on Jan 28, 2008
IFIXALL
  • 868 Answers
SOURCE: no audio brand new toshiba 42xv540u
speakers are muted.
Posted on Jun 10, 2008
  • 10 Answers
SOURCE: Discrete IR code for Current model Toshiba 32" TV
these only work on the latest models HX81 etc...
pon- 0000 0069 0022 0002 0161 00b1 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0042 0016 0016 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0016 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0042 0016 0609 0161 0058 0016 00b1
pof-
0000 0069 0022 0002 0161 00b1 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0042 0016 0016 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0016 0016 0042 0016 0016 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0016 0016 0042 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0042 0016 0609 0161 0058 0016 00b1
Posted on Jun 29, 2009
  • 36 Answers
SOURCE: Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
Posted on Aug 03, 2009
  • 308 Answers
SOURCE: I have a Toshiba 32av500u HD LCD TV.NO picture
Its a backlight problem. Common with this model. Under warranty? If not, then its a service shop repair.
Posted on Mar 26, 2010
TV won't power up. This model has lost a power supply before. how do I verify this is the problem and replace the faulty component?
Hi Dave, Troubleshooting circuit boards to the component level has become a bit harder due to the availability of semiconductors.
I would suggest to measure all the voltages from the power supply at P802 and P803.
Let me know if you require further assistance or I can send you the service manual if need be.
Sep 13, 2015 | Toshiba 32AV502U 31.5 in. LCD HDTV
Screen Flicker/Speaker Pop on one HDMI
Look for loose contacts in jacks, sockets, cables. Look for loose contacts in power outlet.
Aug 03, 2012 | Toshiba 32AV502U 31.5 in. LCD HDTV
I have a 32av502u the unit keeps running through all the inputs then makes a popping sound?
OK if you are getting a popping sound from your speakers then it's provably your signal board. IF you are getting a popping sound from one of your parts like the power supply then its provably that part that is bad. You can get parts at www.interliquidparts.com
Dec 15, 2011 | Toshiba 32AV502U 31.5 in. LCD HDTV
Toshiba 32AV502U
As far as i remember Samsung makes all the screens Toshiba uses. I would try to contact Toshiba for a replacement screen, from what i've heard the price of the screen is comparable with the price of a new TV
hope this helps,
Thomas
Mar 03, 2010 | Toshiba 32AV502U 31.5 in. LCD HDTV
Humming or squealing noise when tv is turned on (model 32LG30)
Be sure you have installed the stand scresw weather or not you are using the stand.
The back panel can vibrate without the screws.
Other sources of a hum are the coils on the power supply.
The power supply would have to be replaced to solve the issue.
Jan 19, 2010 | LG 32LG30 32 in. LCD HDTV
RCA 32 in TV no picture no sound just a beeping noise TV power is on
the tv has one part of the power supply working this is needed to have the microcontroller ready to work. But the tv needs more than that for work im talking 'bout the high voltage power supply who is now damaged. the parts required depends on the diagnosis in the bench but at least two are needed. the cost of this repair of course depends in how many parts are going to be replaced, but i concider this repair kind of average in this technology.
Apr 13, 2009 | RCA 32V524T TV
Astar 30 inch model ltv-3001 will not turn on
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com
Jan 20, 2009 | Astar LTV-3201 32 in. LCD Television
Power supply
Its possible that it is the power supply. If you wanted me to take a loot at it I could but you would need to remove the power supply from the TV and ship it to me. The power supply has been a common fail point of TV's, VCR's and other home electronics in the past several years. Let me know if this is something you would like to discuss further. I just need contact info.
Dec 29, 2008 | Akai LCT3201TD 32 in. LCD Television
Toshiba 32AV502U 31.5 in. LCD HDTV Logo
110 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
