Question about Samsung UN46C6300 TV
I have sound but no pictue
I have replace the T-Con and the main board with no change. The led backlights are on. The power supply voltages are there. TV turns on and off and all functions appear to be working, just no video or menus.
    New Friend:
  • 4 Answers
Make sure the red white and yellow cords are in correct place
Posted on Jul 25, 2013
  • 133 Answers
SOURCE: Screen goes completely out.
when it blanks out, tuen the lights out in the room, and shine a flash light at the screen, see if you can see the picture, if you can, it is the inverter moard blamking out, thats the board that lights the back lights, if you cant, hit the input button on the remote, if the TV comes back with a picture, it is a problem with the main board, in paticular the componant input on the main board
Posted on Jan 10, 2009
  • 2336 Answers
SOURCE: LN-T4061f samsung lcd no backlight, no sound, no picture
Replacing the capacitors would be a good start. Replace all the ones with the same capacitance and voltage rating even if they do not look bulge.
Let me know if you require further assistance.
Posted on Mar 14, 2009
  • 718 Answers
SOURCE: how hard it is to replace by yourself main board Samsung LN-T4065
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Posted on Mar 30, 2009
SOURCE: I have a Samsung LNT4665FX with screen problems. I
To solve this type of problem, you need a piece of white chalk. Draw a line around the area where the set is at. Call a priest - and lay the poor thing to rest!!!! This isn't the first time Samsung has "dropped" junk onto its' customers. Their dvd players also had problems with their DSP I.C.s that would over heat and cause the video playbacks to "break up". Don't waste any more time or money on the product!!!!!
Posted on May 18, 2010
bshldn
  • 736 Answers
SOURCE: I have Samsung UN46B8000XFXZA LED TV. After power
Yes based on your testing it appears that the power supply is at fault solely and you can opt to attempt a repair or replace it altogether. Unfortunately you will not be certain that the main board does not also need to be replaced until you have repaired the power supply.
Posted on Feb 05, 2011
Samsung smart tv no picture and sound. Replaced T-CON and Main Board. Same result. Any ideas?
did you change power supply? how many times does light flash (red) you didnt change the power supply did you use a vom on connections?
We Are Here To Help !!!
Donal Deane MCSE,ASE,CPO
Aug 18, 2017 | Samsung Televison & Video
Question is about a TV. What would cause ALL of the backlighting to strobe or flash.
it's likely the voltage controller for the LED's I cant imagine a manufacturer using multiple circuits to operate such a simple circuit as the LED's. So yes, it's very likely that they are all connected to the same circuit.
Oct 11, 2016 | LG Televison & Video
LG 50la6970 no backlight i have sound and dark images!
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Oct 07, 2016 | LG 50" LED 1080p 120Hz Smart 3D HDTV w/...
What's my next step in diagnosing my Vizio LCD TV picture issue?
Hi Tim,
If all the boards you replaced were good and working, the only thing remains is the panel if the backlights are on. Please see that the LVDS cable is carrying voltage to the Tcon board.
Good luck.
May 10, 2016 | Vizio E701i-A3
I replaced the t con board and the main board in my Samsung led tv and I still do not have a picture
Hi Tony,
If the backlight is there and still there is no picture, what is left is the main board. But before that please see that the Tcon board is receiving necessary voltage from the main board. Please also check the power supply board for producing all the necessary voltages.
Good Luck.
Apr 29, 2016 | Samsung Televison & Video
Samsung LED TV (UN39FH5000FXZA) has audio, but does not have backlight. I replaced the power supply/ LED board with no success, could this be caused by the main board or the t-con board?
Hi Matt,
The fault lies with the backlight LEDs. It is common with these sets. If you open the panel and replace the failed LEDs, or replace the panei.
Good luck.
Dec 05, 2015 | Samsung 5000 Series UN39FH5000 39" LED TV...
My LED TV is showing a blank screen. How can I check my TVs backlight by using jumpers on the power board? I've seen videos to do this, but nothing specific to a similar Sony model.
put jumper in between pin no 23 & 28 now your power supply is on but still no voltage at led out put error 6 code is particular for led out put not for t con so please replace power board complete
Nov 02, 2015 | Sony BRAVIA KDL-60EX645
Samsung UN46C6300 TV Logo
104 people viewed this question
Jerry Greenberg
Jerry Greenberg
