What does the compasator on a refrigerator do
How do i no if my compasitor is bad?
    Sergeant:
  • 308 Answers
Capacitors very rarely go bad on refrigerators it's mor likely to be your overload/relay combo
Posted on Jul 26, 2013
Jets are not working
Your motor may be locked up or you may have a bad starting compasitor. Remove the cap on the back of the motor and see if you can spin it freely. If so check the compasitor. (a black plastic one will have a small cut out where the wires go. If it's black or blown out it's bad. A silver one will bubble out at the ends. If you can't tell set it on a table, flat bottom down, if it rocks it's bad. It should sit flat) If the motor doesn't spin freely pull the pump out and take the wet end off of it. Once the wet is removed if it spins freely your motors fine and you need to replace the seal and more than likely the impeller you just pulled off that has a split shaft.... This is caused by a pump seal leak going unchecked.
Sep 17, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Why does the dvd player stays on standby?
the reason it stays on stanby is caused by a bad compasitor on the power supply board u can buy a replacement compasitor at a radio shack or somewere that would sell one.
Jul 08, 2012 | Memorex MVD2042 DVD Player
YORK CONDENSING UNIT MODEL H1RA042506D WIRING SCUMATIC BLOWER MOTOR WILL NOT START WITH OUT A PUSH. START COMPASITOR MAY BE BAD BUT WITCH ONE IS IT. MOTOR NAME PLATE CALLS FOR A 370MFD. I FOUND A 36MFD...
The capacitor for the fan will read 370uf 5 uf. The 370 is voltage at cap. My guess would be a 7.5 uf cap for your fan. If you read the cap. it will tell you size. Fan caps go between 5 and 20 uf or microfards. Easy to replace you can do it yourself. Rus
Oct 29, 2009 | Heating & Cooling
Refrigerator LG model GXFD22DSS, compressor do not run, there is a noise in the circuit board, like a relay is trying to actionate
on the compressor there is a start relay and compasitor these could be bad and replaced.other than that you have a bad circuit board
Jul 30, 2009 | LG Refrigerators
My campbell and housfield 60 gal wont run.. help
10 AMP CIRCUIT SOUNDS WEAK. WIRE MAY BE TOO SMALL. ARE YOU SURE ITS NOT WIRED FOR 220 VOLTS AND YOUR RUNNING IT ON 110. START CAPACITOR COULD BE BAD BUT TYPICALLY WOULD LEAK OIL-LIKE FLUID IF IT WAS DAMAGED. CUTTING OFF AND ON CONTINOUSLY COULD BE THE PRESSURE SWITCH IS DAMAGED. SOUNDS MORE LIKE WRONG VOLTAGE. THERE ISNT A LOW OIL PROTECTION DEVICE.?
Feb 04, 2009 | Campbell Hausfeld 26 - Gallon Air...
A brownish liquid inside my s40
This sounds like you have a popped compasitor a compasitor has brown liquid in it that is a form of oil that makes the compasitor work if the get overloaded for some reason they pop. Beleave me that sucks. It can be fixed but it sound like it might cost more that the camera is worth. Up to you. Sorry for the bad news. :(
Feb 18, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
My Frigidaire
there is a relay/overload/compasitor that plugs into the compressor. when this part goes bad the compressor will hum then click. its a pretty common problem with frigidaire but very easy to replace
Nov 25, 2007 | Frigidaire FRS23R4C Side by Side...
Heating & Cooling Logo
11 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
