Question about NEC MultiSync 1770NX 17" LCD Monitor
What to do when your monater says no signal analog
  • NEC Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd and floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
Check your RAM.
The RAM is located in the middle of the motherboard.
There are tabs that you can push to release the RAM.
Remove it and put it back in place until the tabs pop out.
Loose RAM can cause your computer not to start properly where you want to see a video signal.
Make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
Restart your computer then reinstall it this should activate found new hardware wizard
Check the vga lead for secure dust free connection or try another vga lead.
also
If you have used a desktop computer or have a dual-monitor setup, you have likely seen the "No-input Signal" error message on your computer monitor.
The error message may point to a number of culprits.
Accordingly, the solutions run from simple to complex.
Prior to attempting advanced troubleshooting methods, check the connection first.
Power off the computer and the monitor.
Remove the cable that connects the monitor with the computer, then reseat it.
Try a different port, if possible, then reboot the computer.
Connect the monitor to another computer if possible to eliminate the monitor as the faulty hardware.
Shut down the computer.
Remove all cables and devices plugged into the computer.
Make a note of the port into which your monitor is plugged.
Remove the left side panel when facing the front of the case.
Unscrew screws or manipulate latches to remove the side panel.
This process varies according to the type of case you have.
Please consult your manual if you are unsure of how to remove the side panel.
Attach the antistatic wrist bracelet's clip to a metal object, then ******** the bracelet.
Locate your video card.
(This will be the card that contains the port with which your monitor interfaces.)
Remove the slot cover screw that secures the card into the slot.
Remove any power cables that connect the video card to the power supply.
Pull the card out of the slot.
Examine the gold pins to check for any damage.
Reseat the card if it physically appears to be undamaged.
You should hear a click once the card is secure in the slot.
Screw in the slot cover screw.
Attach the power cable from the power supply unit, if applicable.
Leave the case open for now.
Reconnect only the monitor, power cable and any devices required to boot the computer, then restart the computer.
Shut down the computer again if you receive the "No-input Signal" error message again.
Remove any cables and devices you plugged in to restart the machine.
Remove the video card with a spare or replacement by following the instructions above.
Connect necessary cables and devices to reboot the computer, then restart it.
Shut down the computer and remove cables and devices if the display still won't work.
Unplug the power supply's cables from all devices on the motherboard.
Make a note of each plug-in so that you can correctly connect all devices with the new power supply.
Remove the screws that mount the power supply.
Fit the new power supply into the mounting area, and screw in all screws.
Attach all required power cables to devices connected to the motherboard.
Attach the cables and devices required to start the computer.
Reboot.
http://en.allexperts.com/q/PC-hardware-CPU-1023/input-signal.htm
Posted on Jul 26, 2013
Got a 22 inch envision monater that comes on when u cut it on but goes right back out
try separating the wiring. Touching wires cause cross-talk of signals
Feb 06, 2014 | Envision Computers & Internet
My dell monator shows black
take out your memory sticks and put them back in.If you have more than one try one at a time.
Jul 28, 2012 | Acer AspireT135 (AST135US3302) PC Desktop
Can't get an analog signal
There are no broadcasters that broadcast analog, as the Government eliminated it. Analog is a large waste of resources. You would need a digital converter box to generate an analog signal, but your TV should be able to receive a digital signal.
Nov 12, 2010 | Philips 32PFL5332D 32 in. LCD Television
I have hooked up cable to the RF connector but it will not show a picture. I also tried an anntenna and it does not pick up a picture either. All I get is snow. However, I had a VCR/DVD combo connected and...
This tv is analog tv,will not get today free air tv broadcasting signal.Today free air tv signal are all digital free air broadcasting tv signal now.Anolog tv must have a pay cables tv or satalites tv signals to get a picture on analog tv set.U want analog tv to get the free air digital tv broscasting signal.The analog tv,must have it broadcasting tv signal must go through a box call a Converter box to able to produced a Digital free air broadcasting signal for analog tv to get a digital broadcasting tv signal.
Nov 07, 2010 | RCA F27442 27" TV
I bought a Gateway FPD1830 monator from a friend. What does it need other than a power cord to hook to a dell computer?
VGA or DVI cable, this cable has approx 1" x 1/2 inch blue or white ends and should connect both to the monitor and to the computer to transmit the video signal between the two.
Aug 29, 2010 | Gateway FPD 1830 18.1" Flat Panel LCD...
After starting the computer the screen is black and only displays digital analog on screen and the blue light is flashing. It then displays a box say "check signal digital analog." please help me. Thanx.
This blue light flashing means there is power to monitor bu NO video signal. No Analog or digital Video . analog is the regular plug for PC to Monitor, the other is HDMI digital or other digital. Check signal digital/analog means again: No video signal from PC detected.
Daddy
Dec 02, 2009 | Samsung Syncmaster 940BW LCD Monitor
Pc entering power saver mde
This message apears when there is no input coming from your computer. There should be a bution you can puch on the monater that would cnahge it from digatail to analog this may be the problem that you are having problems with
May 21, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Wont let go of the phone line
have your monitoring facility remotely connect to your unit and check the programing. also you need a standard potts (analog) phone line, not a voip, cable company or uverse line.
mj
Dec 10, 2008 | GE Security Simon 3 Wireless Home Security...
Samsung 931B SyncmMaster
DO YOU MEAN WONT SWITCH FROM ANALOG TO DIGITAL!!!
THE ONLY WAY THIS WILL CHANGE IS IF YOU HAVE A DIGITAL INPUT SOURCE CONNECTED to this mointor like HDMI AS THIS MOINTOR AUTOMATICALLY SENSES ANALOG SIGNALS AND DIGITAL INPUT SIGNALS if a digital signal is available it will switch over if a digital input singal is not available you will only be able to use the analog option
Jan 11, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
NEC MultiSync 1770NX 17" LCD Monitor Logo
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
