Question about Garden
Where is the safety switch on my gravely zero turn
2 Suggested Answers
  • 51280 Answers
SOURCE: someone left the key on my gravely zero turn lawn mower and now it won't crank and the fuel pump isn't working
recharge the battery and give it another go.
Posted on Jun 17, 2013
How do I put a replacement belt on a gravely promaster 200?
Any Gravely or Ariens dealer can help you with this... If you have your model number and serial number you can order it online
Sep 11, 2014 | Garden
Gravely only clicks wont start but hour meter works
Sounds like a low battery, enough juice for the hour meter but not for the starter
Aug 14, 2014 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
Gravely 23 hp zero turn mow starts but wont continue running.Whats wrong?
Sounds like a carb. problem to me. Needs to be cleaned. May need a new fuel filter also.
Jul 14, 2014 | Craftsman 10.5 Hp 33" Commercial Cutting...
Gravely zero turn lawn mower
are you sure you have the wire from the battery to the ignition key on?
Did you accidently knock the wire from the ignition key to the Starter relay off?
Aug 23, 2013 | Garden
New starter will not turn over
Yes, this could happen if the safety switches aren't engaged, so make sure you have the brake on and the control levers are both in neutral, and the PTO is off.
If that isn't the problem, look at the connections to the solenoid. The solenoid and starter are in an assembly together, so I assume when you replaced the bad starter it came with a new solenoid. If you didn't get an exact replacement, it's possible the new solenoid requires both a hot and a ground connection, where the old one just required a hot wire (and grounded itself through its mounting to the engine block). Check this.
Jun 10, 2010 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
Engine dies when Blade is engaged
It sounds like the seat safety switch is the problem. Tilt up the seat and make sure the plug to the seat switch isn't loose or off completely, and that the switch is firmly mounted. If everything seems ok, remove the switch and test it with a multimeter. The circuit between the switch terminals should close when you press in the button. If not, replace it. Good luck!
Jun 04, 2010 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
