Question about Vehicle Parts & Accessories
I need to replace he ignition switch in my 2005 volvo s40. I have the part just need to know how to get to the piece to remove the old part
    Top Expert:
  • Vehicle Part... Master
  • 12,223 Answers
Just go to www.automecanico.com translate this website and fix it.
God bless you
Posted on Jul 25, 2013
Volvo s40 clutch
I dont know but I guess its a hydraulic clutch operation and if so your problem is probably the slave cylinda leaking air or also quite probably the master cylinda short of fluid or again leaking air. system needs ot be blead to get it working if it happens again change the cylindas one at a time .
Aug 21, 2014 | 2005 Volvo S40
2005 Volvo S40 with key stuck in ignition. It turns off but key doesn't come, out of the steering wheel. Please advise needed, if lock change is required estimated cost of part and labour please.
Some ignition system locks will not release the key unless you push in towards the column while turning further off. It is a safety device to stop in advertent removal of the key while moving. Try that first.
Apr 08, 2013 | 2005 Volvo S40
2005 Volvo S40 Immobilizer
you need a scanner having your car's program and to do the alarm reset to reset the alarm.
Aug 28, 2012 | 2005 Volvo S40
Brake light switch on 2001 volvo s40=my brake lights work sometimes and don't work sometimes. I have checked all fuses and bulbs. I have tried fiddling with the brake light switch and can make the brake...
Yes switch is the problem. Volvo claim they sell very few switches, probably because people bought new cars instead. Problem can be associated with failed ignition coils (2 of) but one does not cause the other but very confusing. Engine fails intermittently or conks out.
Reset battery earth connection on chassis bad design here. Clean off paint and thread also bolt coating. Even better, use brass bolt but do not overtighten. Volvo will try to get you to replace alternator which is not necessary.
Failing battery will light up all the warning lights but will not isolate the battery so if it shorts car will die and not run on alternator. If this happens disconnect battery until you get to garage.
Now you know you can buy an old S40 with confidence great car and very cheap for what you get.
May 14, 2010 | 1991 Volvo 740
Changing a serpatine belt on s40 volvo
Use a rachet to relieve the tension on the idler wheel, remove old belt, install new belt using the guide, either under the hood, or from the manual. Again use the idler tension relief to finish. when the rachet is on the idler wheel it is usually used to lift wheel off belt, to relieve tension.
Dec 28, 2009 | 2005 Volvo S40
2006 Volvo S40 - key won't turn all the way off to get the key out. We can turn it until the engine shuts off, but the key won't turn any further to the locked position to remove it. The transmission is in...
We had the same problem on ur 2004 v50. dealer said we need to replace the SCU (ignition switch) $600!!
Any thoughts on how we can get volvo to pony up?
Dec 07, 2009 | 2006 Volvo S40
Warning lights is on the red triangle volvo s40 2005 2litter
Sounds like the instrument cluster has gone bad or a bulb in the cluster has burnt out. You will need to remove the cluster and check the bulbs to see if they need to be replaced.
Aug 07, 2009 | 2005 Volvo S40
How do I remove the trim inside my 2002 Volvo S40 boot so that I can replace one of my License plat bulbs? The trim appears to be held on by plastic plugs needing a posidrive or philips screwdriver bu t...
Just take a small screwdriver or a knife with a good tip and pop out the center piece that looks like a screw,when you put them back in,you just press them with your thumb.
Please rate this solution.
Jan 20, 2009 | 2005 Volvo S40
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
