Question about 2008 Chevy Equinox - All Equinox models - Punch Grille
2008 Chevy Equinox Grill Replacement
Im trying to replace the grill on the front of my 2008 Chevy Equinox. I think that I am going to have to remove the bumper in order to do it. I thought I would look into it a little more to see if there is another way. Thanks.
  • 884 Answers
Yes, removing the bumper cover is not a real big deal.
Posted on Aug 17, 2013
How do I replace a windshield washer nozzle on my 2005 equinox (front)
In a nutshell, the process to replace the washer nozzles is,
1. Remove Wiper Arms
2. Remove the Air Inlet Grill
3. Release the nozzles from the inside of the Air Inlet Grill assembly
4. Install in reverse order
The wiper arms are each held in place with a single nut. Try to resist the temptation to pry the arm away from the shaft, gentle wiggling should suffice to get them free once the nuts are off.
When installing the arms that should have been removed while the wipers were in their parked position, line the end of the wiper to the little dots in the bottom blackout strip of the glass. Use a flashlight to see those dots under the glass. After replacing the nuts, torque the nuts to 21 foot pounds.
The Passenger side of the Air Inlet Grill is the cover access for the cabin air filter. If you've never changed that filter before, this would be a good time. It's probably pretty bad after some 10 years. There are 5 reusable plastic fasteners holding that cover down. There are 2 more on the far drivers side of the Air Inlet Grill. Carefully pry the center tab up to release tension on the fastener, then pull the whole fastener out. If the fastener comes apart, it's easy to reassemble in the center backed out position in preparation for reassembly.
The Washer Nozzles have compress to release clips accessed from inside the Air Inlet Grill assembly. Attempting to remove these from the outside will only damage the Air Inlet Grill. Replace and snap the new nozzle in place, before starting the reassembly steps.
Best of luck. I think a person with a reasonably talented set of hands should be able to do all of this, but don't rush.
Mar 09, 2015 | 2005 Chevrolet Equinox
How do you change the front turn signal bulb on a 2005 Chevy Equinox Thanks
you have to remove the front grill assembly then remove the light assembly
Mar 02, 2011 | 2005 Chevrolet Equinox
How do i change the driver side headlight bulb on a 2005 chevrolet equinox?
open the hood - find the 3 or 4 plastic clips that hold on the grill ( the center of the clip will pry up with a small screwdriver ) once the plastic clips are removed pull the grill towards you and gently pull on the headlight frame assembly. The grill will not come off so don't try to force it. Once you have the headlight assembly out remove the bulb that beeds replacing ( when replacing do not touch with bare skin use a rag or paper towel ) Put it all back together reversed from removing it. Hope this helps
Dec 06, 2010 | 2005 Chevrolet Equinox
How does one install a front grill on a chev equinox 2006 lt
Open the hood of your Equinox and raise the support rod to prop it out of the way. Locate the retaining clips around the front grille of your truck. Pull each of the eight retaining clips straight up off the grille. Pull the grille out away from the front of the truck.
Aug 13, 2010 | 2006 Chevrolet Equinox
How do i fit a replacement headlight bulb on a new (2008) smart fortwo (city coupe)?
For 2008 + it is very easy , look at the from grill , you will find 2 latches on the top corners of the grill. Pull from the inner corner , then you will be able to open the top panel of the front section which allows you full access to the headlights , replace the bulb , then put the top panel back and lock the latches.
Good luck
Nov 10, 2009 | 2008 Smart fortwo
Change the headlight on a 2006 Chevy Equinox
The front bumper cover does have to come loose at the top. Remove the retainers along the top of the front bumper cover on top by the radiator and loose the part of the grill that goes over the headlamp. cover with tape to avoid scratching the lens . then remove the 3 bolts for the headlamp. Two at the top and one down at the bottom inboard side. Then pull the headlamp at the outobard bottom to release the retainer and remove the headlamp.
Aug 17, 2009 | Street Glow Streetglow Streetglow H894...
How do i replace the headlights in my 06 chevy equinox?
you have to take the clips out of the grill and pull it foward while pulling the light towards the grill and it will come out.
Jul 01, 2009 | 2005 Chevrolet Equinox
How to replace headllight lamp
I know your frustration! I cannot believe the complexity of changing the headlights. Chevy has tried to make this a dealer item only just to change a headlight bulb. I will try to explain the procedure unfortunately I do not have photos. First you will need to remove the wheel well liner (two bolts and two plastic push pins). Pull the wheel well housing back (you will need to turn the wheel/tire to gain access) and using a 7mm socket remove the plastic support piece that holds the bumper in place (two bolts). Pull the corner of the bumper down until you can locate the bottom bracket of the headlight assembly that is held by a 10mm bolt. Remove it. (Oh did I mention this is a two person job!) Next move to the front of the vehicle (hood up) and remove all the 10mm bolts holding the upper part of the grill (I think there are eight of them). Now remove the obvious top two bolts on the headlight assembly! With two people - one to work the headlight assembly and one to push down the bumper and pull out on the grill assemble, slowly and carefully pull the headlight assembly straight forward. You will need to be mindfully of the small tabs on the headlight assembly that like to get caught on bumper/grill. If you are just replacing the bulb, you should be able to move the headlight assemble far enough forward to gain access to the bulbs without totally removing the headlight assembly. What a ***** job! SHAME on GM.
Oct 11, 2008 | 2008 Chevrolet Suburban
2006 Chevy Equinox
It is in the front, driver's side, just behind the grill.It is covered with a plastic cover that's screwed on with three Phillips head screws and has a 5" x 5" electrical box sitting on top.
May 21, 2008 | Equinox (210120)
2008 Chevy Equinox - All Equinox models - Punch Grille Logo
313 people viewed this question
Top Putco Vehicle Parts & Accessories Experts
L Pfaff
L Pfaff
Jim Hoak
Jim Hoak
Are you a Putco Vehicle Part and Accessory Expert? Answer questions, earn points and help others
