Question about Acer Aspire TimelineX AS5820T-7683 NoteBook Intel Core i3 370M(2.40GHz) 15.6 4GB Memory DDR3 1066 3... (LXPTG02156)
Acer TimelineX 3820TG Will Not Power On
The laptop is not responding to the power button. No lights, no fan sound, nothing.. The AC cord has a green light on it, so it is not the adapter that has failed. I've tried to start it: - with just battery - with just AC cord - without battery and cord
    Top Expert:
  • 12,223 Answers
Make this test and fix it. God bless you
Check your laptop's AC adapter. Ensure the laptop's AC adapter is snugly plugged into the port on the back of the . Also, check its connection into either the wall socket or the surge protector, depending on your setup. Make sure the AC adapter is securely in one of these outlets and not loose. Also, if the adapter is plugged directly into the wall, try another outlet. Your existing outlet may be blown.
    • 2
Check your monitor brightness settings. Sometimes these settings get accidentally turned all the way down, which results in what appears to be a dead laptop battery or malfunctioning power supply, but is really just a simple fix. Your laptop has dedicated brightness keys at the top of the keyboard, directly above the numeric keys. Adjust the brightness settings here.
    3 Look at the battery indicator light if your laptop appears to be out of battery or suffering a power failure. If it is not flashing or indicating a power problem, your laptop's "LCD closed switch" may be malfunctioning. This switch acts as a sensor which normally judges whether your laptop is open or closed. Sometimes this switch gets stuck in the "closed" position, resulting in the laptop believing it is shut and thus the monitor's back-light staying off. This switch is located right beside either the left or right hinge at the bottom of your laptop's display . Tap this switch multiple times with your finger to attempt to free it up and get it out of the closed position.
      • 4
    Consider whether your laptop's battery has completely died and needs to be replaced. Average laptop batteries last for approximately 1000 charges, after which point they either gradual deteriorate and have trouble holding a charge, or simply fail altogether.
    Eventually your laptop's battery will have to replaced, and if none of the other troubleshooting steps yielded results this is likely the source of your perceived power supply problems. Flip over your laptop and locate the horizontal outline of the battery, which will be at the top center of the bottom of your computer.
      • 5
    Notice the battery release mechanism on the bottom of your laptop, which should be directly below the horizontal outline of the battery. Slide this release mechanism to the left to disengage the battery and gently pop it out. The laptop's power supply may now be replaced.
    Posted on Jul 25, 2013
    Acer aspire 3820TG
    Look on the RAM sockets.The label has the model# for the motherboard there.
    Aug 28, 2014 | Acer Aspire Computers & Internet
    Acer aspire D257 won't turn on
    Remove all the cables, then take the battery out. Press down the power button for 10s. But the battery back in, connect the AC adapter and try to start.
    If nothing happens, most likely HW issue.
    Apr 23, 2014 | Computers & Internet
    Acer Aspire 9110 problem
    Sounds like your video is bad or the laptop is not getting power from the ac adapter or battery. Make sure your ac adapter power cord is good.
    Mar 27, 2012 | Computers & Internet
    I have an Aspire 4520 laptop. When I turn it on, the green light around the power button lights up, but nothing on the screen. There is power to the system, because the DVD tray opens and closes like it's...
    most likely a motherbaord problem.
    unplug power cord, take out the battery.
    hold power button for approx 90 secs.
    try to power up the laptop again.
    if this fails then try a new power cord, that could be also faulty and not regulating the correct power output
    Oct 10, 2010 | Acer Aspire 4520-5582 Notebook
    Pushed the on button, the green light comes on,
    Green light comes on, what about other indicator lights? Is there activity like fans humming. Try to take out the battery and power up using the ac adapter only.
    May 12, 2010 | Acer Aspire One PC Notebook
    Acer Aspire 5920 will not boot at all...
    The power button may not work, that is most common in laptops, or you have a short.
    Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
    No response
    First follow procedure to try to reset the power.
    1. Unplug the ac adapter. Keep ac adapter unplugged.
    2. Remove the battery and keep the battery unplugged.
    3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
    4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
    5. Normally power on the notebook.
    6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
    7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
      If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
    May 23, 2009 | Acer Computers & Internet
    Acer Aspire 5610 that wont boot up
    Take battery out, press and hold power button for 10 secs, reinsert battery and try again?
    Aug 15, 2008 | Acer Aspire 5610 Notebook
    Acer Aspire TimelineX AS5820T-7683 NoteBook Intel Core i3 370M(2.40GHz) 15.6 4GB Memory DDR3 1066 3... (LXPTG02156) Logo
    388 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
