Question about Car Audio & Video
Aftermarket Receiver Has Constant Static White Noise Sound
I had a Pioneer DEH-P3000IB car receiver installed in my BMW E46 325i. Ever since, there has been a static white noise sound coming from my speakers. The static white noise sound increases/decreases as I adjust the volume knob and it is present when I am playing the radio, cds, or auxiliary. The static white noise sound only goes away when I turn my receiver off. Any help to get rid of the sound would be much appreciated. Thank you.
Duncan
  • 218 Answers
SOURCE: car stereo static
Sounds like you may have an output transistor/module about to go out.
Posted on May 11, 2007
SOURCE: sound quality
Will not turn on get blue screen with eq band only after leaving it on for some time i get some function out of it only at low volume setting if i try to turn it up reception and sound quality breaks up
Posted on Jun 19, 2008
SOURCE: popping & hardly any volume
i had the first problem and you can probably fix it by turning the volume knob all the way up and down about 20 times. it worked for me. supposedly the potentiometers in the z-5300 get dirty or worn out, somehow this might fix it. for the second problem maybe try plugging it into the laptop and unplugging it again seeing if it goes back to normal?maybe its a problem with the amp?
Posted on Aug 14, 2008
  • 30 Answers
SOURCE: kenwood kdc 3011 cd player
Have you tried the balance and fader control?
Also make sure the ground or - negative wire has a good connection for that speaker from the back of the unit. Or it could be the internal amplifier it self.
Dan
Posted on Aug 27, 2008
SOURCE: Microsoft VX-6000 audio problem - static noise coming from speakers
i get a ground hum on audio. video ok
Posted on Oct 17, 2008
No sound from new install Pioneer DEH-X6600BT
You may be using the wrong adapter. Your Durango has a DK GRN/RED wire that supplies power to the separate amplifier. Your adapter may not have provisions for connecting the steering wheel controls to your new radio. Also check 15A FUSE 4 in the junction block in case it is open.
Dec 29, 2013 | Pioneer Deh-X6600bt Car Cd Receiver...
NO SOUND OUT OF NEWLY INSTALLED PIONEER DEH-X6600BT
Did the Durango have the Infinity sound system? If so, there is a separate amplifier that is probably not being activated. Look for a blue or blue/white wire on the harness adapter and connect it to the Pioneer's blue/white wire. If it does not have blue/white, use the solid blue one.
Cant set the clock on my pioneer deh-P3000IB deck
According with the P3000IB User Guide...
Hope helps (remember to rate this answer).
May 13, 2011 | Car Audio & Video
I have a pioneer deh-p3000ib my neice lost the plug for it, ordered a new one it came with 2 sets of purple wires none of witch have black strips. So i need a wire diagram to show the plug and wire...
try looking at the gray, white and green wires and see which position the wires with the black stripe are. you should be able to get a good idea which should be the purple/black from that.
Dec 14, 2009 | Pioneer DEH-P3000 CD Player
IM w/out a wiring diagram for a sterio/cd player (pioneer)# deh-p7500mp. It has a 24 pin plug in and a 12 pin plug in port.Please identify pins...
red is accesory key switch yellow is battery constant power,black is common ground,blue is remote,green black is left rear negative and green is positive,violet black is right rear negative and violet is positive,white black is left front negative and white is positive,gray black is right front negative and gray is positive.
Sep 11, 2009 | Pioneer DEH-P2900MP CD Receiver...
Wiring Diagram for Pioneer DEH-P3000IB
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Aug 29, 2009 | Car Audio & Video
Need speaker wiring diagraham for pioneer DEH-2900 MP
You can follow this link for the User manual
http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/In-Dash/CD-Players/DEH-P2900MP?tab=D
Apr 04, 2009 | Pioneer DEH-P2900MP CD Receiver...
Need to know what connectors to buy to install my pioneer audio?
You can usually purchase a wiring harness for your vehicle to ease the connection to factory wiring. Two examples would be here:
Toyota Into Car Harness
Toyota Into Radio Harness
Feb 01, 2009 | Pioneer DEH-P3000IB Connect an iPod nano...
PIONEER DEH 245
Most aftermarket radios follow the same color code. W G G P, White, Grey, Green, Purple. LF, RF, LR, RR. red is switched ignition, yellow is constant battery, black ground.
Sep 02, 2008 | Pioneer DEH-245 CD Changer
Car Audio & Video Logo
90 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
