Question about Garden
Stihl ms 361
No spark on 361 replaced ignition mod, and plug still no spark. has compression just no spark
    Sergeant:
  • 458 Answers
Make sure the wire going to the kill switch is insulated (no missing insulation) and not pinched the case. Test the switch to see if the contacts are open with the switch in the run postion.
Posted on Jan 27, 2014
4 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: stihl mod ms 361 would
A business card placed between the flywheel and module works quite well (the magnetic attraction even holds it in place).and is easy. Rotate it by hand when done to ensure there is no contact. HTH
Lou
Posted on Sep 24, 2009
  • 173 Answers
SOURCE: Hello, A stihl MS 361 with
It Could BeTwo Things.One is condensation from sitting for along time.Two is if it was setting outside in thr weather.the water could have seeped through the reed valve.If it is seized up your best bet is too replace it.
Posted on Nov 17, 2010
2strokeJim
  • 577 Answers
SOURCE: Stihl MS 290 won't fire even when primed directly into cylinder
crank seals are probably shot :-(
Posted on Nov 29, 2012
No ignition spark on stihl ms 361 chainsaw
Coils do not go bad very often. It is normally something else. Check the 'kill' switch under the air filter cover for correct movement and operation.
1) disconnect the 'kill' switch wire at the coil. Retry. You will need to remove the recoil cover to do this, then reinstall.
2) How do you know there is a 'no spark' condition. Have you checked the spark with a spark tester. A very inexpensive tester from a parts store will work
3) The spark plug can be bad. Is it soaked with fuel?
Jan 07, 2017 | Stihl Garden
Part # for spark plug wire on stihl saw model ms 180 c
spark plug wires on small engines are normally part of the coil so you may have to get a new coil pack
talk with stihl service parts or service shop
Jul 30, 2016 | Stihl Garden
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
Stihl ms 290 wont start
Try replacing the spark plug and fuel filter to start with. Need to ensure you have fuel and spark. We have a list of things to check as techs but if it has spark fuel and compression it should run albeit poorly. If no spark check the ground circuit and if thats good replace the ignition module. If you have spark check the carburetor. It will most likely require a kit and cleaning
Jan 16, 2013 | Stihl Ms290 Ms310 Ms390 Air Filter &...
Stihl ts400 no spark
I have never seen a flywheel de magnitise, it will be an ignition unit problem
Jan 11, 2012 | Stihl Saws
Hello, A stihl MS 361 with apparent seized piston; spark plug is rusty orange as well as 50% top of piston! Water in fuel?
Nov 16, 2010 | Garden
Stihl mod ms 361 would not start verry week spark replaced ign module no spark at all magnets on flywheel seam strong enough even made shure wire on on off switch wasnt grounded and set gap at 0.10 any...
Lou
Sep 23, 2009 | Garden
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
