Question about Bissell 7950 ProHeat Upright Wet/Dry Vacuum
Bissel sc 1632 Deep Clean Carpet Cleaner
Where can I obtain a water pump for a Bissell SC 1632 machine?
  • 184 Answers
SOURCE: bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Posted on Feb 13, 2008
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
  • 10 Answers
SOURCE: bissell proheat 7 will not spray water or cleaner
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! g
Posted on Sep 26, 2009
Vac Belts
  • 701 Answers
SOURCE: where can i obtain a manual for a power steamer
You can view the manual here:
Bissell Powersteamer Manual
Posted on Dec 02, 2009
  • 4 Answers
I have owned three Bissell cleaners and experienced clogged hoses each and every use. Do not put carpet cleaning solution in these machines. They are not designed correctly. If you have a tough spot, just use some liquid dishwasher detergent and a scrub brush. It will get almost anything out! Try it! Then, use the Bissell with hot water only to clean up any detergent residue.
Have a great day! Bissell Sucks!
Posted on Aug 31, 2010
How can I download Bissell Little Green Clean Machine manual?
direct
https://canada.bissell.com/support
or the first link has it, also videos
  • BISSELL LITTLE GREEN 1400 SERIES USER MANUAL Pdf ...
    www.manualslib.com > ... > Vacuum Cleaner > Little Green 1400 SERIES
    Bissell LITTLE GREEN 1400 SERIES User Manual. ... Vacuum Cleaner Bissell Little Green 1400 SERIES User ... Rcvd a used bissell little green machine w stagnant ...
  • Bissell Little Green Machine ' Walmart.ca
    www.walmart.ca > Walmart.ca > Appliances > Vacuums > Steamers
    • 4.1/5
    • 185 REVIEWS
    • $99.96
    Bissell Little Green Machine for sale at Walmart Canada. ... Powerful suction lifts stains and spots with water or any of the Bissell cleaning solutions.
  • Little Green® Portable Carpet Cleaner ' BISSELL®
    www.bissell.com > ... > Browse By Type > Carpet Cleaners > Portable
    The Little Green® portable carpet cleaner is produced with a minimum of 50 ... Coupon code for purchases on bissell.com: ... (including all accessories and manuals) ...
  • BISSELL LITTLE GREEN CLEAN MACHINE PDF - fenbook.me
    fenbook.me/get-it-free/b/bissell-little-green-clean-machine-manual.pdf · PDF file
    Get Free Read Online Ebook PDF Bissell Little Green Clean Machine at our Ebook Library. Get Bissell Little Green Clean Machine PDF file for free from our online library
  • Bissell Little Green Owners Manual ; Bissell Little Green ...
    www.youtube.com/watch?v=PpQji8obNz4
    • BY BOTHSHOOP
    • 4 MIN
    • 11K VIEWS
    2012-11-07 · Video embedded · Bissell Little Green Owners Manual ; ... Bissell Little Green Owners Manual ; Bissell Little Green Machine ... How to fix a Bissell Carpet
  • Bissell LITTLE GREEN 1400 SERIES User Manual
    May 24, 2016 | Bissell Vacuums
    Brushes don't rotate on proheat2X,
    How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
    ? 2:11
    https://www.youtube.com/watch?v=Jj_43IHz9U4
    Dec 28, 2012 - Uploaded by eVacuumBags
    How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
    Brushes Will Not Rotate Deep Clean Essential - YouTube
    ? 0:53
    https://www.youtube.com/watch?v=gbEXY5jkWSc
    Apr 9, 2015 - Uploaded by BISSELL
    If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
    bissell pro heat 2x brushes wont spin Questions & Answers ...
    www.fixya.com > Forum > Tags
    ... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
    Feb 03, 2016 | Vacuums
    My bissell proheat will not suction dirty water. What should i do?
    take it apart and clean the pump, its clogged for sure.good luck
    Jul 31, 2011 | Bissell Carpet Cleaner Powerbrush Deep...
    It just wont put any water out to clean carpet....Everything else works
    That means that you need to replace the pump belt. Here is the belt you need, it includes instructions:
    Bissell Proheat Pump Belt
    Apr 13, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
    Water doesn't come out of my Bissel Deep Cleaner
    Did you use TAP water...not a good idea.Use de-mineralized water you can get at most pharmacies,there is probably mineral buildup in the lines.
    Mar 23, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
    Bissell proheat does not pump outwater into carpet
    Remove the water tank and shampoo dispenser, unplug the machine, turn it over and check for any obstructions, carpet fluff or pet hair is usually the problem. Hope this helps.
    Oct 04, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
    I have a Bissell pro heat carpet cleaner, the water spray wont come out to clean the carpet.
    Bissel proheat turbo 2x ipx4.
    I don't have the instruction the this machine if you could help me with where to put the water and cleaning solution and how much, also how to use it.
    Thankyou,
    Please email me at carolynsst@yahoo.co.uk
    Mar 01, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
    Bissell 7950 ProHeat Upright Wet/Dry Vacuum Logo
    243 people viewed this question
    Top Bissell Vacuums Experts
    Jim Parker
    Jim Parker
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
