Question about Lexmark Office Equipment & Supplies
Drivers 4423 002
How to reset printer
How to reset the software of monolaserprinter
Dear Robert
I am bit of confused, which printer and what software you need to reset.
I think the software (printer driver), simply un install and reinstall it. few driver comes with maintenance feature.
If give detail in comment, I may try.
thanks.
Mar 13, 2015 | Office Equipment & Supplies
How to reset counter hp lasserjet C4096A toner
Its simple thing to reset your counter volume for ink or print setting values. As latest drivers installation will make to default values from their you can easily reset the values. download and install the latest drivers.
HP Laserjet 2100 Printer Driver Free Download For Windows
May 13, 2014 | HP LaserJet 2100 Printer
Factory Reset
try driver from www.seagullscientific.cam driver, it will help to reset to factory default.
Feb 28, 2014 | Zebra QL 420 Plus Thermal Label Printer
HOW TO RESET PRINTER CANON LBP3000
hi it is different between driver and reset!!!!
all post about driver but question about reset software pls put a useful link
Jul 05, 2011 | Canon LASER SHOT LBP-3000 Printer
How to reset for factoey settings canon LBP 3300? Reset the copy counts.
Uninstall the printer driver on your system
Again install the Printer Driver.
reset the Option fro printer driver
Thank you
Feb 26, 2011 | Canon LASER SHOT LBP 3300 Printer
Printer
You can download and install the Canon printer drivers from the
Canon WEB site. Please click on this link and select your model printer :-
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Jul 15, 2010 | Canon PIXMA MP150 All-In-One InkJet...
How do i reset my epson d92
To reset Epson D92 you need to follow these instruction:-
1) Click on the Start menu, then Control Panel.
2) In Control Panel, open the printers folder.
3) In the printers folder, open the Printer Driver.
4) Follow the section appropriate to your printer type to change the settings in the driver:
  • Start in the Main tab of the printer driver.
  • Click on the Reset Defaults button located in the bottom-left of the window.
5) The printer driver will now be restored to the default settings, or set to the changes you have made.
For more description visit:-http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-D92-Printer/Drivers-Support?target=article&extn=.html&articleId=1440
Have a nice day...
Dec 05, 2009 | Epson Stylus D92 InkJet Photo Printer
When printing duplex the even pages print portrait and the odd pages print landscape...
This could be a setting on the printer, in the driver on your computer, or the document you are printing.
First, try printing a different document and see if the problem persists.
Reset the printer to factory default settings, also referred to as a cold reset. HP has instructions on their website here: HP LaserJet 2300 Printer Series Resetting the Printer Cold Reset
You can also go into the printer driver on your computer and reset settings there, or uninstall and reinstall the printer.
Sep 08, 2009 | HP LaserJet P3005 Printer
Ip4200 - printing issues!
Hi, Perhaps you can try: remove the USB connection of the printer; uninstall and remove all drivers of the Canon IP4200; reboot your PC; plug in your usb to the PC from the printer; power on your printer; let windows auto detect "New Hardware found"; let windows auto install drivers; test print. If after plugging in your usb and powering your printer Windows did not auto detect "New Hardware found", it's possible that your printer's usb cable is defective. If Windows auto detected the Canon IP4200 and auto installed all the necessary drivers but failed in the test print, repeat above steps but instead of auto install, use the original CD driver and not the new drivers (Let me choose which drivers I want". RESET - User manual is available from the Canon site. There are 2 versions, 1 is a Quick Start Guide in pdf and the other is a User's Manual (On-Screen). Both does not say anything about reset, however you may want to google "fix your own printer" and variations of resetting all sorts of printers are available. Some works, others are ... well you can always give it a try. Or in the On-Screen Manual,you can also try the Troubleshooting/Printing Does Not Start. Another thing that you can try is installing the printer in another PC using the old CD drivers and see if it works. If it does, then it is a driver issue with the new PC. If it does not, you're back to reset . Hope this be of some help to you. Good luck and kind regards.
Jul 30, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
22 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
