Question about Frigidaire Affinity ATF7000E Front Load Washer
Atf7000eso how to fix when wont spin
HOW fix myadmiral washer model AED4475tq0
check the clutch may be slipping and for good measure check the door switch with multi meter for continuity
Jan 14, 2015 | Admiral Washing Machines
My atf7000eso starts then stops over and over.
The door lock is bad, remove the spring on the boot to gain access it easy to fix.
Apr 11, 2011 | Frigidaire Washing Machines
Westinghouse LF708B washing machine wont spin,drains but wont spin Use to work when you thump machine but now wont spin at all
I have found that it is a blockage I manually drain the water through the botton of the machine then the cycle continues as a short term fix. I am not a professional though
Mar 09, 2010 | Westinghouse Washing Machines
Wont spin or drain it only only hums when turn on
Either your drain pump is bad or something is stuck in it.  It won't spin until it drains so fix the drain pump, and it will spin.  You should be able to get at the drain pump by taking off the bottom panel, or back panel.
Dec 19, 2009 | Kenmore HE2 Plus Front Load Washer
Ps2 wont spin disc!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
you said that it wont spin right? if you mean that your fan wont spin then you have a bad connection or a bad motor. there easy to get, and easy to install. if you mean your disk tray. then it is still the same problem. a bad connection. or bad motor.
Nov 08, 2008 | Sony PlayStation 2 Slimline Console
Frigidaire Affinity ATF7000E Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
