Question about Garden
Troy bilt tb210
My mower starts right up, but then stalls out, i've added stabil and have checked the spark plug and throttle wire. anyone have any suggestions?
Dusterz
  • 46 Answers
SOURCE: Troy bilt mower ran fine then died and now it wont
Remove the air filter and set aside.
Take a can of carburetor cleaner and spray the inside of the carburetor.
Let it set for a moment and then try starting the engine. It should run a few seconds. Repeat. When it starts squirt a small shot of cleaner in the carburetor to keep it running. That should remove the varnish the gas leaves as it evaporates over the winter.
If it still won't keep running then there is trash in the float bowl plugging the needle valve seat and the jets.
1) Turn off the gas or remove the gas line and plug it with a small screw or stick to keep it from leaking out of the gas tank.
2) Look on the bottom of the bowl for a nut .
3) Remove the nut and drop the float bowl.
4) Carefully remove the pin holding the float and needle valve assembly.
5) Take the carburetor cleaner with the straw it comes with and spray every hole in the carburetor to clean the jets . (up through the needle valve seat, down top of the carburetor , see a hole, spray it with the cleaner.)
6) Clean the float bowl.
7) Reassemble and make sure the gas isn't leaking and try to start it again.
Posted on Jun 06, 2010
  • 4 Answers
SOURCE: Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
Posted on May 05, 2009
  • 6 Answers
SOURCE: troy bilt tc 300 tiller that will not start. Have
Pull several times with choke set full if spark plug is not wet you have carborator issue. If spark plug is wet you probably have a bad connection to spark plug in boot or issue with spark lead. Pull spark plug, replug into lead, lay on head and pull rope to see if you have spark. Do not hold onto plug or you may get shocked.
Posted on Aug 21, 2009
brado83
  • 106 Answers
SOURCE: What is the spark plug gap on a 4.5 HP 21" cut
With out the model # of engine or plug not 100% certian but 99% of those mower engines run a .8 or .9mm plug gap you will be preety safe setting it at that
Regards
Brad
Posted on Feb 05, 2010
  • 36 Answers
SOURCE: Troy Bilt Rear tine tiller model 643 Bronco, won't
did it run out of gas when you added gas it could be that the fuel line has plugged up with something from the bottom of the tank take the fuel line off and try blowing threw it and take a air hose and blow out the carb and carb cleaner
Posted on Jun 05, 2010
Very hard starting and won't run full throttle
try valve clearences check air cleaner and check pilot and main jet again in carby
Jun 19, 2013 | Husqvarna Garden
Hp gas
Follow gas line from tank to carb. Observe bottom of carb. Remove screw holding carb bowl to carb. Clean bowl. Pinch off gas line with pliers. Ensure float falls down easily. Float up no fuel flow, float down fuel flow. Observe screw that hold carb bowl to carb, see if it has a whole thru it, clean with small wire, bread wrapper works good. Observe center fuel port, clean with wire. Remove pin that holds float and meter needle, clean port with wire. Reassemble. Ensure air filter is clean, oil is full, 30w oil, spark plug is clean and properly gapped. Replace air filter and spark plug once a year. Empty old oil out if any grey is observed in oil, this is moisture, can accumulate after winter storage. Clean out side of carb with carb cleaner to ensure choke can rotate freely. Always use Stabile in gas.
All newer mowers have a low oil shutoff.
May 09, 2013 | Troy Garden
2000 jeep grand cherokee 4.0 stalls when brakes are applied.
definately a vacuum problem, try changing your pvc valve its under $5.00 and easy
Feb 04, 2013 | 2000 Jeep Grand Cherokee
Toro Electric Start Problem
Remove spark plug and observe condition. Fouled with oil, bad motor. With plug removed pull rope several times to blow out cylinder. Spray WD40 in spark plug hole, pull rope several times see if oil blows out. Spray a lot of starter fluid in spark plug hole, replace plug. Spray starter fluid in air cleaner area of carb, try to start. Replace spark plug, try to start. Ensure oil is full, all mowers have a low oil sensor now. 30w oil. Always use Stabile in gas.
Jul 04, 2012 | Toro Garden
My mower won't start
try running it with the gas cap loose the vent might be plugged
Apr 13, 2012 | Garden
How do you check the oil in a Weed-Eater-500-Series Side Discharge Mower, Model 10854261. It has a basic Briggs Stratton engine. I have a lost the manual and cannot figure it out!! HELP!!!!
most mowers have a dip stick like a car and the oil should be changed often and acting as if it wants to stall try fresh fuel gas is only good for 30 days in small engines
Mar 27, 2012 | Briggs & Stratton Garden
1996 jeep cherokee stalls, I've replaced the throttle position sensor, MAP sensor, and carbeurotor. What else could it be?
You replace sparkplugs,plug wire,tps,map,cap and rotor.Thats good,If the vehicle runs and you come to a stop and it stalls,That is the IAC (Idle air control) you say it ran fine for a week now its acting up, Service the IAC or get it replaced.
Mar 21, 2012 | 1996 Jeep Grand Cherokee
I've a push mower that lately has been stalling out after running for 15-30 seconds. Reciently the spark plug was replaced but didn't solve issue.
check to see if your fuel plug is clogged it's the nut holding the bowl and should have a hole near the head that goes all the way through and one down the center connecting
Jul 18, 2011 | Toro Power Lawn Mower
Brand new Ariens ST624e seized after 15 minutes of operation?
if there is oil on the sparkplug, you have blown a cylinder seal. It will need repair.
Dec 24, 2008 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
70 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
