Remove the black hub caps, then pull off the metal push nuts, then pull the wheels off, this will give you access to the motors and gear boxes, you'll then have to remove the two screws that hold the gearbox in, then you should be able to finagle the gearboxes out
SOURCE: do I need to replace all tires on peg perego john deere
Hi!
On these, only the 2 rear wheels are the gear wheels. You will just need to replace the tires on those with the rubber ones if you choose to go that way.
SOURCE: Peg Perego John Deere tractor 12volt will only
check all wre connections are not dirty or loose!
lift out pedal swith to check there too!
Cheeers Rob
SOURCE: We bought a Peg Perego john deere hpx. where can
You could try here. http://tigerimports.net/sunshop/
SOURCE: how to replace rear tires on peg perego john deere tractor
remove the center cap of the tire, the remove the metal push nut, then pull the wheel off, do not pull out the axle there are spacers by the gearbox that are on the axle
SOURCE: HI, I HAVE A PEG PEREGO JOHN DEERE LOADER.I NEED A
you can order one here www.powerwheelsoutlet.com
