Question about Zanussi Dryers
I have a Zanussi ZDE 5714W tumber dryer. It started blowing cold air only and after a couple of minutes the End/Anticrease button lights up and beeps continually - any ideas whats wrong with it?
I've cleaned out the filters (which are done after each crying cycle anyway). Can't think of what else to try
    Top Expert:
  • Zanussi Master
  • 12,223 Answers
You must replace the control board.
God bless you
Posted on Jul 25, 2013
  • Angela Jul 25, 2013
    Thank you - I had a feeling it was going to be expensive!
  • ernesto cuadra
    ernesto cuadra Jul 26, 2013
    o.k God bless you
jsrock516
  • 5911 Answers
SOURCE: WHIRLPOOL AWZ2303 TUMBLE DRYER ONLY BLOWS COLD
It's call a bad thermal cut-out. You should have a thermal cut-out and a high limit thermostat located adjacent to the heating element (usually mounted right on the heating element housing). They both should read a short or fairly low resistance in the case of the thermostat. If the thermal cut-out is blown it is not a resettable device and must be replaced. The tco is usually sold along with the high limit thermostat. It is HIGHLY recommended that you replace BOTH at the same time. DO NOT attempt to bypass any of these devices either. They are there as safety devices to prevent overheating. You could end up with a fire if you do. Now...with all that said, the tco will blow for a reason. Not cleaning the lint trap will contribute to it, but the big item is the ducting. If the vent ducting is clogged you will experience longer dry times and eventually the tco will trip again. Take the time to THOROUGHLY clean and/or replace your vent ducting from the wall all the way to the vent opening outside. In addition, while you have the dryer open THOROUGHLY clean the inside as well. This includes the air baffle where the blower fan is located. Rule of thumb: if you have lint INSIDE the dryer, it's clogged somewhere. Good luck and I hope this helps you.
Posted on Sep 22, 2007
IFIXALL
  • 868 Answers
SOURCE: Bosch Maxx 6 doesn't dry anymore?
Yes,it is the first thing to check ,If you can somehow see if its glowing when you start the dryer.It may also be a thermal fuse.
Posted on May 23, 2008
SOURCE: Frigidaire Gallery Heavy Duty Front Load Dryer problem
it's probably the nylon bushings that the drum rides on. they wear out and the drum rides directly on the pad that the bushings attach to.
Posted on Sep 02, 2008
SOURCE: bosch maxx wtl 6300 dryer when
Hi Guys...
At least I can shed some light on how to open the bottom part.
When you are looking into the dryer with the door open, take a look at the bottom hinge of the door. There is what looks like to be button popped out slightly..
Place your thumb on it and press. This should open the bottom part of the dryer.  Then clear out the gap between where the lint filter connects to the other units below it (when the door is closed...)
Hope this makes sense... there seems to be a sensor there..  I just cleaned mine so praying that the beeps stop.. Its been driving us mad for the last 8 months!
Posted on Oct 25, 2008
kachbibi1
  • 979 Answers
SOURCE: Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Posted on Jan 15, 2009
START BUTTON SWITCH REPLACEMENT FOR DRYER ZDE
-Why replace it...? Broken...?
If so replace it.
Good Luck
mai
Nov 13, 2014 | Zanussi TC7102W Electric Dryer
Zanussi washing machine is making five beeps and not workign - what does this mean? It is not in the manual
My Zanussi Fs1555w is not finishing it's cycle and beeping 7 times. If I put on spin the cycle lasts less than a minute before the end button beeps, then it will beep repetitively 7 times until turned off. Please help
Feb 05, 2010 | Zanussi FS1455W Front Load Washer
Broken Zanussi tce 7127 w dryer
the dryer is telling you a trouble code like in a car when something is malfunctioning with it, try to call your manufacturer and ask them to tell you what that code means.
Nov 06, 2009 | Dryers
The tumble dryer is work but is only blowing cold air
sounds like a heating element. not to hard. remove the back and its is right there.
Jun 07, 2009 | Zanussi TC7102W Electric Dryer
Zanussi zdc46130w Fault.
I think you should read the instruction manual . 3 beeps means some information to begin a solutin.
Feb 15, 2009 | Zanussi TC7114W Electric Dryer
Electric dryer blowing cold air
You either have a blown fuse, breaker, burned out element, wiring that has come loose. They all can be checked within 5 minutes. However, I believe it is in the thermal fuse which is located below the top of the dryer. You can access that pretty easy though. To check it, just bypass it and put the 2 wires together and see if it runs. The fuse is only 15 dollars or so. I am assuming you have an electric dryer.
Jan 26, 2009 | Zanussi TC7114W Electric Dryer
Dryer will run for a second and sound three beeps and stops.
Sounds like the door switch has gone bad., but your description is confusing.
First, it takes a few minutes for you to feel the air blowing hot, particularly when the dryer is in a cold garage. The heating elements have to heat up the mass of the metal, and any clothes in the dryer.
The timer design is such that it can not speed up (the motor inside wont start running faster, due to it's electrical design.).
I am suspect that the door switch has failed for some reason, because reading between the lines, I think you are saying when you release the Start button, the dryer quits operating. If the door switch is bad, then it will cause that condition to happen.
Jan 18, 2009 | Kenmore 62802 Electric Dryer
Jan 15, 2009 | Zanussi TC7102W Electric Dryer
Zanussi TCE 7276 W Condensing Dryer
hi i have a problem with the zanussi 7276w model all lights are on ready to start but the tumble dryer will not start
Sep 21, 2008 | Zanussi TC7114W Electric Dryer
Dryers Logo
129 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
