Question about Sewing Machines
Onn cdplayer instructions
How do I return to the exact location I was on if I shut it down
Bernina feed dog down and will not return to normal position by switch
1. Clean and lubricate entire machine following the MANUAL instructions.
2. Try to "lower" it again then try to raise it - several times.
If this does not solve it, see a service person.
Jul 08, 2014 | Bernina 1008
What is the hook race
The hook race is the part of the bobbin assembly that revolves when the bobbing case is removed. You would put a small drop of oil directly on the inside of the part that revolves, then return the bobbin to its proper location. Hope this helps. You can also view a great video on youtube that shows you exactly how to take care of it.
http://www.youtube.com/watch?v=hJCRfpO_MVo
Dec 04, 2013 | Bernina Artista 180
Instruction Manual for old Singer Sewing Machine
http://www.singerco.com/uploads/download/2645bb4d16795d9b408b835f7bc60cc89b29293f.pdf
Many manuals from the early 1900s are almost exactly the same. Your 24-30 is the same as a 24.
Jul 12, 2012 | Singer Sewing Machines
Need manual for white sewing machine 1409 can I down load for free
go to the singer website---free pdf download
click on customer support- there's a drop down menu
choose instruction manual
in the box type w1409---exactly the way it shows here
click search
it's a free pdf file
Jan 18, 2012 | White Sewing 1409 Mechanical Sewing...
Sewing instructions for simplicity pattern 3553
if you copy this link into your browser window you will see the pattern details including Instructions, its a tab down the screen under the image, "Fabric and Notions" "instructions" and "size chart"
http://www.sewingpatterns.com/sub_item.php?item_num=3553SIM&model=%&new_category=search&view=gallery&brand=&category=search&pageGoto=0&pageFormat=3'186'186&pageCount=18&search=3553&return=yes
Looks pretty easy, sew the inside leg seam of each trouser leg together,
then sew the ****** seam and do the waistband.
Dec 18, 2011 | Sewing Machines
I need instrutions for using an onn digital slow
do you know where I can get instruction for an ONN digital slow cooker, please
Dec 17, 2009 | Sewing Machines
Need instructions on using button hole attachment
Without the exact make or model to go on.....the general issue most folk have is the location of the lever that is drawn down from the body of the machine.
Once the button is firmly held in the buttonhole foot, the lever MUST be located between the two protrusions on the foot so that as the sewing reaches each extreme point the lever is triggered to stop and then set off in the new direction....
If all this is a little confusing, any friendly sewing shop ought to be able to show you if you ask nicely....maybe even buy some goodies you need to sweeten the deal.
Sep 07, 2009 | Sewing Machines
Looking for a manuel where can i get onne
If it is the singer model then here is the manual for it :
http://www.sewwhat.net/millie/Manuals/CEX300k.pdf Hope this helps.
Jul 08, 2009 | Sewing Machines
How many Watts does my machine have?
Watts is Current ( listed in Amps and normally shown on a tag of some sort on your machine ) times Voltage ( 120Vac) so if you had
For example.. if it listed 10A as in 10 amps @ 120 V then you would have 10 x 120 or 1200 watts.. This should get you in the ballpark.. If you can provide the exact model number of your machine.. I couold get the specs on it and give you a better answer.. Hope that helps...
Aug 21, 2008 | Singer Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
