Where on the monitor is the plug for the camera.
The plug for the camera came out of the monitor. The monitor is behind the dash and is difficult to reach. I located the power plug and need to know where the camera plug is located relative to the power plug.
  • 27,725 Answers
If its webcam plug it in to the usb port if the monitor has one if not into one of the computers usb ports.
Click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark ?
right click to reinstall drivers or update driver xp.
Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: webcam name webcam driver you might have to try a few times to get it right
software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
It might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
This will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you
want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
Some webcams and programs require additional software, although that should be installed with the webcam if things are right.
But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date.
But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing.
Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c Windows Vista: DirectX 10).
http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer
If you still have no webcam installed
Run the "Add a device"application, accessed by clicking on the "Start" button, opening the "Control Panel," and then double-clicking on "Add a device."
The "Add a device" window will open and Windows will search for devices connected to your system but not installed.
Click on the webcam name that shows in the search box and then click "Next."
Choose whether you want Windows to search for the webcam device driver using Windows Update over the Internet, or if you'd prefer to have the device manager search for the driver using a disc supplied by your laptop manufacturer.
Most drivers can be found on the system recovery disc included with your laptop, if you choose to add the driver from the provided disc.
Place a check in the box next to your choice and then click "Next" to continue.
Wait while Windows searches from the driver using Windows Update, if this was your choice.
An active Internet connection is required for Windows to successfully do this. Allow the computer to install the driver and then reboot the system for the webcam to become recognized by the system.
Otherwise, you can use the system recovery disc or a driver downloaded directly from your laptop manufacturer to install the driver without using the Windows Update search feature.
Open the CD/DVD-ROM drive and insert the system recovery disc, or place the driver downloaded from the manufacturer in an easily accessed file directory on your PC, such as on the desktop, or in your "My Documents" folder.
Choose the option "Install the software automatically (Recommended)" in the "Add a device" application, and press "Next" to begin searching for your webcam driver.
The hardware wizard will search the system recovery disc and install the driver automatically. Press "Finish" to close the wizard and then reboot the computer to allow recognition of the webcam.
Choose the option "Install the software manually" in order to browse to the driver location where you saved the driver and install it from there.
Use the opened file manager and locate the driver.
Click the "Next" button to install the driver, then reboot the computer to add webcam functionality.
Posted on Jul 25, 2013
Where is the blower motor located
Behind the dashboard with the heating matrix. You may be able to get to the blower motor from under the dash but it will be difficult. The ideal solution would be to remove the dash it's a pain and you will need a set of hex bit sockets.
Apr 09, 2012 | 2000 Isuzu Amigo
I accidentally unplug the cord behind the monitor so i put it back back the power was gone totally
You might try replacing the power cable. If that doesn't solve the problem, the receptacle is most likely faulty. However, it's more difficult to replace.
Aug 11, 2011 | Computers & Internet
Where is the master brake cylinder located on a 1988 mitsubishi L300 van?
If it's like the 1995, it's behind the dash. The brake booster is behind the master cylinder, on top of the pedal box. You have to drop the steering wheel and pull the dash off to get access. Even then it's extremely difficult to do anything.
Apr 14, 2011 | 1990 Mitsubishi Minivan
I have gmc jimmy 2000. The heater fan making noise. Is it difficult to replace the fan motor. thanks for your immediate assistance. Manny
Manny:
The heater is behind the dash. You will need to take the dash out of the truck.
Good luck
Dec 31, 2010 | 2000 GMC Jimmy
How difficult is it to replace the blower motor resistor on my 2004 Chevy Trailblazer LS - is it behind the glove compartment or do I have to get into the dash?
BLOWER MOTOR RESISTOR IS BEHIND GLOVE COMPARTMENT.FIRST TURN OFF RADIO THEN REMOVE NEGATIVE BATTERY CABLE AND LEAVE IT DISCONNECT TO DISARM AIR BAGS WAIT 20 MINUTES ALLOWING AIR BAGS DISCHARGING.BEFORE WORKING AROUND STEERING WHEEL OR DASH AREA.
Aug 01, 2010 | 2004 Chevrolet TrailBlazer
Need to locate scanner plug optima lx 2001
for the most part its under the dash on the driver side are under the hood on the driver side give these websites a try www.autozone.com and www.alldatadiy.com wish you the best Michigan Man.
Nov 21, 2009 | 2001 Kia Optima
Heater fan makes a noise when i turn it on ..how do i get to it .it seems some thing is rubbing ..against it..1998 corolla
Sounds like some leaves or debris may have made its way into your heater fan. heater fan assembly is under the passenger side dash in behind the glove box. You can get at it (or at least see it) by looking up in behind the dash while lying on your back, but this is difficult working position. Easier on back & arms if you remove lower dash section.
Apr 24, 2009 | 1998 Toyota Corolla
Heat not working (99 Sunfire)
check the "blower" fuse it may be labled as heat. A/C heat, or blower. if it is not the fuse then it is most likley the fan itself, it is located behind the glove compartment, look up under the dash behind the glove box (you may have to remove the lower panel to see) should be three small bolts holding the round base of the fam, unhook the plug and remove the bolts, not very difficult to replace it yourself
Dec 11, 2008 | 2001 Pontiac Sunfire
Needles on gauges don't light up on my Accord 2.2 LX non-V-tech
It is the bulbs behind the dash. Not to difficult to take the dash apart, I've done it several times.
Jun 30, 2008 | 1995 Honda Accord
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
