Question about Kohler K-560-VS Bellera Bellera Pull-Down Kitchen Faucet, 7-7/8" Spout
Bellera screen aerator removal
How does one remove the aerator/screen in the bellera 560 faucet head?
3 Suggested Answers
costelturcus
  • 43 Answers
SOURCE: Water "spits" along the edges of the flow from the
reduce presiunea de la intrare robinet.
Posted on Feb 26, 2011
  • 3 Answers
SOURCE: I recently removed and reinstalled my kitchen
take the unit apart, starting with the handles and check for small rocks or derbis blocking flow.
Posted on Mar 24, 2011
What are the part numbers for Kohler kitchen face K560 for faucet valve set
Hello Rhonda Tweedus,
Sorry it took me so long to understand such a clear question...
Your style: Bellera (couldn't find an answer either)
I looked around for PARTS LISTS...
Clever sales tactic ...
Perhaps FAUCETSDIRECT.COM
might help... (see bottom URL).
Their attached has three PDF data sheets... none of which give the DETAIL YOU REQUIRE...
I suggest you CALL Kohler direct at
1-800-4KOHLER (1-800-456-4537)...
They can IMPROVE if they don't know the have
a problem
Kohler 560 2BZ Oil Rubbed Bronze 2BZ Bellera Pull Down Kitchen Faucet with...
Carnac the Magnificent
Apr 12, 2017 | Kohler Plumbing
How to remove washer from 1 above
Kohler doesn't offer a lot of online help, but you might have a look at <http://www.us.kohler.com/us/static/helpTopicsHelper.jsp?helpId=559>.
Feb 12, 2015 | Kohler K-560-VS Bellera Bellera Pull-Down...
I have a Jado bathroom faucet that has a restriction in it. Is there a screen that I need to clean?
It will have an aerator on the end of the faucet that has a screen. Sometimes these can be removed by hand carefully unscrewing. Others require an aerator removal tool (cheap). Either way, remove the aerator taking care not to allow it to separate into parts. Once removed, you can then dis-assemble noting the order in which you did so. Clean screens and re-assemble.
Aug 16, 2014 | Home
Installed a new kohler pull out spray faucet and the flow is not sufficient to start my instant demand hot water heater. Have taken out the aerator and screen and still not enough flow. Checked the...
Should be valves under your sink for the faucet. #1
Make sure they are opened up enough.
If either device is new, they should support this issue.
Old plumbing can also cause this. Build up in the lines.
They can only be replaced to fix. Some water heaters have adjustable valves, make sure if you have them they are opened as needed. Remember, too low flow can cause over heated water.
Oct 31, 2013 | Kohler K-560-VS Bellera Bellera Pull-Down...
How to take out aerator for cleaning
doesnt the bottom of the tap end unscrew as the the jet thing is behind this
Dec 21, 2011 | Hamat 3-2861ST Everest Pull-Out Kitchen...
Just put in a new moen kitchen faucet, why does it have hardly any water pressue?
You might have a clogged aerator screen. Remove the aerator from the faucet and see if the flow is normal. You can rinse the aerator off if it's clogged. It's also possible the stops (shutoff valves) aren't open all the way. Sometimes, if they're old, they don't turn on fully again after you shut them off to put in the new faucet. If you still have low pressure after removing the aerator, you may need to replace the valves.
I don't know if the instructions mentioned it, but it's good practice to remove the aerator and run a faucet to flush the water line after installing it. There's usually a lot of debris that comes through at first. That's usually why you'll have low pressure in a new faucet.
Jul 14, 2011 | Microwave Ovens
Water flow from grohe ladylux kitchen faucet has slowed down with time. What can or should I do to increase water flow?
If it has a removable aerator screen, remove it and clean it out. If it can't be removed, try soaking the entire head in white vinegar for a couple of hours. You should see a big improvement.
Jun 28, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
Remove water saver device from Blanco Grace kitchen faucet
Remove the aerator at the end of the spout. It will unscrew and once off it will have a dime sized restricter in it that can be removed this restrict's the water down to about 1.6 gpm to save water.
It will either be plastic or metal and about the size of a dime with a small holw in it to let water pass by maybe 1/8" hole just remove it and put aerator back together.
Clean aerator screen out before you put it back together.
http://www.plumbersurplus.com/pdf/07163.pdf This link has a breakdown of parts. Look at parts 8b-10 for aerator breakdown.
Jun 12, 2010 | Blanco 157-052-ST Grace Single Handle...
Kohler K-560-VS Bellera Bellera Pull-Down Kitchen Faucet, 7-7/8" Spout Logo
395 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
