First time installation Toshiba 22BL702
I am having trouble getting past the Installation part of the unit. The switch at the back only turns it on and off, I can't seem to toggle up or down or press it to select 'OK'. Is there any other way to get past this?
  • 1,824 Answers
I would recommend you to call a specialist and fix the problem.
Posted on Jul 25, 2013
  • 476 Answers
SOURCE: Can no longer connect laptop to television
Hi there Susie
Assuming your running XP....
Go to Start
go to control panel
then display
settings
there should be two screens visible
click on screen 2 and then IDENTIFY
the video card should then put a Number 1 or 2 on the screen if its connected and turned on,
If there is only one screen visible in the display SETTINGS
then you will have to uninstall the device and reinstall it.
How to Uninstall....
Go to start
Right click on My Compter,
Properties
Hardware
Device Manager
Right click on Display adapters
Uninstall
Reboot to save settings when done and restart
On start up the Operating System should auto recognise the device and reinstall it,
It will tell you when its installed and ready for use ,
or,
give you a device install failure message
Try again.
Once this is done the device should be up and laughing again.
As far as how did it happen???
Did you do any device updates or software installs lately?
Sometimes default settings of different softwares conflict with each other and the only way to sort them out is turn them off and start again.
I hope this helps,If you need any more help , please just ask
Posted on Aug 19, 2008
acdr
  • 1913 Answers
SOURCE: Installation failure- HDD not detected
may be your harddisk is not detected.
check in bios settings.
and disable sata otion .then try.
Posted on Dec 29, 2008
SOURCE: New Lenovo Y430 keyboard and touchpad does not work
I bought two y430s. I've had both y430's go bad, one at 8 months, one at 16 months. Both were motherboards. 1st on warrantied, second was not. $600 pieces of garbage.
Posted on Apr 12, 2010
greg_margo
  • 1959 Answers
SOURCE: Compaq Presario CQ56-100SJ [XL580EAR] The clock
Assuming you don't have a virus, the laptop's internal (CMOS) battery may be bad. Apart from keeping the time current, it holds onto your machines bootlog. If the machine starts up in Safe Mode, it would likely be the CMOS battery that's bad.
Posted on Oct 18, 2011
Geekman
  • 32281 Answers
SOURCE: Water damaged Laptop
Attaching an external keyboard does not help because the keyboard controller is damaged.
I recommend you put your money towards a new laptop as the cost of repair maybe too expensive or beyond repair. Most computer repair shop charge for a quote and may drop this charge if you go ahead with the repair.
If the hard disk is OK then I suggest you remove it from the laptop and insert it into an USB hard drive adapter case and use it as an external USB hard drive for backups and data transfer etc.
Posted on Mar 05, 2012
Toshiba laptop will not go psat the toshiba logo
There are a number of stages to go through. For all these please ensure that the laptop is switched off. First, remove the battery, then plug the mains charger lead in and try to boot, if you get past the splash screen than it is the battery at fault, if not then the next step is to switch the laptop off close the lid and turn it over, on the bottom you should see an access door with either one or two screws, open this access panel up and remove the hard drive, turn the laptop back over and try to boot up again, it should go past the splash screen and the detect that there is no hard drive installed, if it dose not get past the splash screen then turn the laptop back over re install the hard drive, try again to boot up, if still no good then try removing one of the memory chips, these are found under the same access panel. Try again if still no go then remove the other memory chip and replace the first one you took out. If no joy after all these steps, then sorry I have no further suggestions. Good luck.
Feb 03, 2014 | Toshiba Tecra R850 Series Black Notebook...
Every time I try to use the remote on my Toshiba RD-XS32SU Video Recorder I get the following code displayed on the unit: DR-OFF I do not know what it means and how to resolve the problem.
It is confusing to many people this function, but not impossible to investigate (perhaps experiment with some of the functions). You can get a copy of the INSTALLATION GUIDE (if you don't have a copy for any reason) from the following:
http://tacpservice.toshiba.com/consumerproductsupport/Manuals/dvr/RD-XS32SU_Inst_E.pdf
and if you don't have a copy of the original OWNER'S MANUAL, you can also download that from the following:
http://tacpservice.toshiba.com/consumerproductsupport/Manuals/dvr/rd-xs32_om_e.pdf
(copy and paste into your browser if required - these are both FREE documents)
(Page 48 of the installation guide (not the owner's manual) tells you about IR CODE setup option using remote - read that first if you like, then try your recorder).
Hopefully this helps you a tiny bit.
Mar 23, 2011 | Toshiba RD-XS32 DVD Recorder
Toshiba U400 - when switched on the toshiba logo will appear and followed by a black screen. kindly help me with this problem. I tried F8 but F11 and pressing to reboot but nothing happens.
This probably means it can't boot off the hard disk or the CD ROM.
Make sure there's no CD in the drive.
Try holding F1 as you turn on the unit to see if you can get into the setup if it still won't boot with no CD.
Feb 28, 2011 | Toshiba Computers & Internet
I bought Toshiba Satellite U405D-S2848 around 2 years ago. I use it daily for about 2hrs only and only for Internet browsing (very few standard sites like news and office email etc). Few days ago, when I...
It may be coincidence but I presume you get the Bios menu as the laptop is loading asking you for either F2 or F12 if you wish to change your boot option. If not, plug your laptop into an external screen to check for a VGA processor errors.
I suspect the lamp driver ballast unit may have failed.
Feel free to get back to me with anymore data.
Feb 04, 2011 | Toshiba Satellite U405D-S2848 Notebook
Hi i have a toshiba satellite pro a200 laptop and i wiped the hard drive now im trying to reinstall vista but vista doesnt have the hard drive driver
Usually vista\XP dont required a driver for built in HDD. Confirm whether the HDD is detected properly @ BIOS boot up and proceed with normal installation of Vista. If required get the installation screen shots from internet and proceed.
If this still doesn't resolve your issue, please paste in the exact error message you are getting while installation.
Please come back and rate my solution if it turns to be helpful for you. Thnx
Mar 23, 2010 | Computers & Internet
SP MODE AND INSTALLATION PROCEDURE FOR TOSHIBA DP 1660.
Installation Procedure:
01.Open the machine and take out all tape
02. Open the front cover and right hand side cover + blue lock press and open the black part
03. front side two scrow (big) open
04. Out of PC Unit ( drum and developer Unit)
05. done you Two part the ( drum and developer Unit)
06. developer keep on developer
07. total Items set on the machine
08. main switch on
SP mode
01. 0+5 press and main twitch same time for AJ MODE
02. 0+5 press and main twitch same time for ADMODE
Jan 28, 2010 | Toshiba e-Studio163 Copier
ER7071
es liegt bei diesem fehler an dem dvdlaufwerk
bei mir war es ein loses kabel und eine blokade im dvdlaufwerk
nachdem ich es gesäubert hatte und wieder zud´sammengebaut läuft dvd-recorder ohne probleme
Jul 26, 2008 | Toshiba RDXS54 DVD Recorder/HDD Recorder
Help
H5-01 indicates tha the paper sensor is defective in the fusing unit. The only way you can try to reset that one is buy turning the power off, wait 30 seconds and turn the power back on.
If the error code returns the fusing unit will have to be fixed to take care of the paper sensor.
Jul 20, 2008 | Sharp AR-M237 Digital Copier
HAVE A COLEMAN MODEL DRHSO601CB --- THE UNIT WILL RUN FINE FOR SEVERAL HOURS WITH GOOD COOLING AND THEN PERIODICALLY THE TROUBLE LIGHT WILL COME ON THE THERMOSTAT AND THE UNIT HAS SHUT DOWN. TO RESTART -...
You may have a low pressure or high pressure switch tripping out the board as well. You might try cleaning both the indoor (evaporator) coil and the outdoor (condensing) coil. Be sure to turn off the power source before servicing this.
Jun 30, 2008 | Coleman Heating & Cooling
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
