Question about Garden
Carburetor diagram bolens
Ineed to see the diagram for where the two springs attach on the throttle for the 3.5 hp bolens edger 25A-550A163
  • 313 Answers
SOURCE: Lawn mower
check out murray & tecumesh website
Posted on May 29, 2008
  • 7 Answers
SOURCE: lawn mower R484P
Why not let Black & Decker dealer service take care of if for you?
I have used their service on my 14-year old Black & Decker mower on the few occasions that I needed repairs and paid a very small price.
Posted on Nov 01, 2008
SOURCE: throttle assembly
WELL IT TURNS OUT YOU NEED TO ROTATE THE SPRING TWO ROTATIONS AND CLIP IT TO THE THROTTLE PLATE THAT ATTACHES TO THE THROTTLE CABLE
Posted on Nov 19, 2008
Dolfoff
  • 148 Answers
SOURCE: craftsman Trimmer/Edger 4.0 HP Engine races...
Most likely, the mechanical governor is damaged inside the engine. If you have tools, a sense of adventure, and lots patience, this can be replaced for a modest cost in parts.
If not, take it to a reputable repair shop.
The governor replacement involves engine removal, opening the crankcase, lots of parts-cleaning, and attentive reassembly.
Would be happy to help you if you decide to tackle this repair.
Hope this helps.
Posted on Oct 04, 2009
SOURCE: ineed to sharpen my wood chipper blades on my
It takes me about 5 minutes to Remove, Sharpen, and Re-install my chipper blade for my Bolens mc2500. First, If your using a screen or rollers in the discharge, then remove them. Look underneath, and you will see the thick flywheel. Make sure the spark pug wire is disconnected, then slowly turn the flywheel by hand until you see the two hex head bolts that hold the chipper blade to the flywheel. Also remember which way you take it off, so it goes back together the same way. using an open end or combination wrench remove the two hex bolts. Now to sharpen, I use a medium/ coarse honing tool made for lawnmower blades. I clamp the blade to the top edge of my Bolens with a pair of visegrips, then a little oil, and the sharpening tool, and I'm done sharpening in about 2 minutes, and then re-installing, reversing the removel process. I hope this helps.
Posted on Sep 01, 2010
Ryobi weedeater throttle not working
Check the throttle cable connection at the carburetor throttle linkage, it (cable) may be broken or the carburetor linkage is broke.
Jul 09, 2016 | Ryobi Garden
Need a throttle linkage diagram for a briggs & stratton engine model 9S502 type 0620-B1
David, This is what I found in google search for B&S carb. linkage diagram, you can also do a search because there are lots more.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Linkage Spring replacement on Briggs Stratton Quattro 4 HP Murray Lawn...
Repairing Lawnmowers For Profit Part 61 Governor Spring Help
briggs and stratton governor linkage diagrams Google Search
briggs and stratton carburetor linkage diagrams Google Search
Jun 10, 2016 | Briggs & Stratton Garden
How do I adjust the brakes on my bolens lawn tractor
depends on what gear box you have but usualy the brake is on the left side of the gearbox,there will be a rod or spring attatched to an arm, in the centre of the arm at the bottom will be a nut,either a nyloc nut or a castleated nut which will have a split pin running through it. all you have to do to adjust the brake is turn the centre nut clockwise. i have attached a pic of a gearbox and the arm i mentioned is number 41 in the diagram
Mar 06, 2015 | Bolens 13.5 HP Manual 38-in Riding Lawn...
Replaced fuel lines and primer bulb ON A BOLENS LB 160 25 cc TRIMMER. Primer bulb stays in and wont pop out. it pops out after abouot 3 minutes or if I loosen the primer bulb mounting screws
Check the carburetor internal filter screen for clogging. Also the primer assembly itself maybe bad. If the primer assembly itself is bad a new carburetor is in order.
Feb 09, 2015 | Garden
HOW TO TAKE OFF CARBERTOR ON BOLENS LAWN TRIMMER MODEL 2006 BL 150 31 CC
Remove air filter.... remove gas line after tank is empty and in a place that will not be damaged by gas, remove throttle cable, remove the two screws that attach the carburetor to the engine block and carefully remove trying not to damage the paper gasket seal between the block and carburetor.
Oct 16, 2014 | Garden
I need a diagram of a bolens 15.5hp 38'' belt
i am looking for a spring and belt diagram for my bolens 38" cut lawn mower
Jul 29, 2012 | Garden
My throttle continues to stick. The motor races and it sounds like the engine is about to explode because of its speed. I opened up the handle and the spring seems out of place. When I squeeze the trigger...
You should see some small wear marks inside the handle where the spring is supposed to rest. Also, check the throttle cable where it exits the plastic engine housing and goes to the throttle plate on the carburetor. Make sure it is connected correctly and not binding on anything on the way to the carburetor. There really aren't any diagrams or pictures available on the net of the insides of a Ryobi weed-trimmer's throttle trigger and spring.
When you squeeze the trigger the steel cable should move, the cable housing should NOT. If you look closely, you will maybe see how it works and all goes together. It is not that complicated.
May 21, 2011 | Ryobi Garden
I need the linkage diagram for a 20 hp briggs and statton model 407777-0167
Besides the service manual you can view parts diagrams at a dealer like www.arcolawn.com. You can purchase the service manual at a dealer and it will show you how to hook it up.
The throttle linkage hooks up to the throttle shaft closest to the engine. the governor spring attaches the governor arm to the throttle linkage.
The choke cable attaches to the shaft farthest from the engine. I hope this helps.
PS your engine has two factory service bulletins on it.
Joe
Feb 15, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
232 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
