Question about Miele s558 Silver Moon Vacuum
Turns on but won't run, red triangle showing up.
I have my little robot on his back wit a red triangle
needs charging or overheated. Check the instructions or google the manual.
Feb 12, 2017 | Vacuums
I do not find the same problem
anythin stucked in main wheel,,check thoroughly
Feb 12, 2015 | Vacuums
Red triangle and roomba stopped
If you get a red triangle with the two tone beep, and no voice prompt, roomba 770 runs for a few minutes or just immediately goes to red triangle...if you have thoroughly cleaned moving parts and find no obstructions, you may have the problem I had that stumped me for a week. Remove the trash bin, with roomba upside down, and there are 4 silver contacts that connect to two metal tabs on the trash bin. Over time the contacts lose some of their contact pressure. Use needle nose pliers to slightly rebend them so they make good contact to the trash bin contacts. These contacts feed the vacuum motor inside the trash bin. That fixed mine.
Dec 27, 2013 | Roomba 770 Robotic Vacuum
Roomba 4210 won't start
  • Lift Roomba off the floor and place it in the center of the room and restart the clean cycle.
  • If Roomba did not resume cleaning, lift Roomba and turn it over.* Inspect the Side Wheels for dirt or obstructions.
  • Test the Side Wheels by pushing them in and out and making sure they rotate freely. Place Roomba in the center of the room and restart the clean cycle
    Dec 22, 2012 | iRobot Roomba 4210 Bagless Robotic Vacuum
    Brissell proheata 2x doesn't have suction or the red brushes won't rotate on the hand tools?
    Check the brushes for hair or some other clogging material and remove it. If the brushes can't spin freely, there is not enough suction power to make them spin.
    Sep 17, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
    After changing bag, won't run. Is there a reset somewhere?
    Look in the back of the machine toward the bottom by the silver tag. Red or white reset button. the early models did not have this.
    If you need any help contact me.
    Tim
    TheVacCenter.com
    Jul 31, 2011 | Simplicity Vacuums
    Miele Red Star Powerhead overheats and turns off
    be sure at 1st there is no materials blocking the hose then it seems to me your m/c is good if normall condition around
    try to test your cleaner by use less length hoses
    thanks
    Jul 04, 2009 | Miele Red Star Bagged Canister Vacuum
    Miele Silver Moon 558 displays red triangle and won't start.
    Meile vacuums are great when they work but they are expensive when they dont work you have to pay out of the rear end to fix them if it isnt something like a clogged air filter
    Feb 27, 2009 | Miele s558 Silver Moon Vacuum
    Connecting hoses on Kirby G4
    The hose attaches in place of the beater-bar head unit. To remove the head unit, lift the headlight assembly, then turn the square gray Kirby emblem counter-clockwise 3/4 of the way around until the red triangle on the square portion aligns with the red triangle on the base unit (this disengages the belt). Then flip the silver metal fastener that was underneath the headlight to release the head unit and remove the head unit. To attach the hose, simply line it up so that the safety button is engaged by the hose assembly and then use the metal fastener under the headlight to secure the hose to the base unit.
    Nov 17, 2008 | Kirby Generation 3 Bagged Upright Vacuum
    Miele s558 Silver Moon Vacuum Logo
    20 people viewed this question
    Top Miele Vacuums Experts
    Mack Baxter
    Colin Stickland
    Colin Stickland
    Are you a Miele Vacuum Expert? Answer questions, earn points and help others
