Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Oil blowing out breather tube
What causes the oil to blow out the breather tube
2 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: I have an early 90's cub cadet rider and it was
Yes, over filling can cause this. The fix for this is to put the oil level back to normal, and run your machine normally, until the oil residue burns back off. Some "side effects" may be fouling spark plugs and occasionally residue build up in the muffler, so, keep this in mind. Normally, though, everything goes back to normal. It's better to run the machine for a while than starting and stopping it, to allow the machine to get up to operating temperature and clean out the exhaust system.
Best regards, --W/D-- please feel free to rate this solution.
Posted on Jul 30, 2009
1999 honda xr oil coming from vent tube
Hi, Anonymous and the usual suspects are:
1. Oil tank/system overfilled.
2. Faulty breather valve.
3. Engine breather hose bent, pinched, kinked etc.
4. Air filter has too much "pre-oil".
5. Crankshaft seal failure allowing transmission fluid to migrate.
6. Blow by drain tube cracked/split or filled to capacity.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
oil coming from hose
blowing oil out of crank case breather tube
Honda XR250R Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda XR250R Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 01, 2014 | 1999 Honda XR 250 R
I have a 2012 harley and im getting oil blowing into my air breather how do i find wear its leaking
The oil breather/separation system ends up in the induction pipe throat and the oil mist that does not get eliminated in the breather process is then sucked into the induction system and burnt n the engine. If your oil level is too high or if the breather system is defective this will cause excessive oil to end up in the air cleaner area. If the tubes etc that direct the oil into the induction system throat are missing or defective this would also add to or cause an excessive oil in the breather area problem.
May 09, 2014 | Harley Davidson FXD Dyna Super Glide...
2008 Honda CRF 250 R blows oil out of the breather hose
Hi, Devenbandazi and the usual suspects are:
For more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Losing oil from crankcase breather hose 06 crf 250r
HELP NEEDED CRF250 Putting Lots of Oil Out Valve Cover Breather
Honda 2004 CRF250R Service Manual
HONDA CRF250R 2006 Owner Manual
Jul 18, 2011 | 2008 Honda CRF 250 R
I'm getting a lot of oil blow back coming from the vent tube off the side case. What could be causing this.
Blow by is what causes it - Those motors weren't really designed to be turning RPM's all day. You will want to install a oil catch can inline to help pull the oil out of the breather assembly. There is no way to stop it unless you upgrade to the newer XB PCV breather setup.
Nov 12, 2010 | Buell M2 Cyclone Motorcycles
My troy-bilt blower/vac is blowing oil out of the carb. what are some things that may cause this? Oil level? How do I know I have proper amount of oil? If I leave the foam filter and the carb cover on, the...
Your oil breather (on the side of the engine opposite the carb) may be malfunctioning/defective allowing the carb to **** oil from it. There is a breather tube that crosses over the top of the cylinder connecting the crankcase( oil) breather to the air filter housing. Check the oil level and the condition of the air filter and esp. the oil breather. It serves the same function as a PCV on a car engine.
Aug 09, 2010 | Troy Garden
Oil blowing out of trans breather tube
hi 81 yamaha i am concerned about the fuel smell coming out with the oil. could be the carbs flooding filling your crankcase with fuel? if not it sounds like you have blow by which would cause your crank case to be slightly pressured. this is caused by worn piston rings. do not plug your crank vent. if you leave your vent open install small filter to stop dirt from entering jim
Mar 21, 2009 | 1981 Yamaha XJ 650
Oil blows out of tube
You either have a head gasket going bad or your piston rings are shot which causes air to go down into the crankcase building up pressure which exits through the breather tube.
Jan 31, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Blowing oil on an 8HP craftsman snowblower
That is a breather tube, I can't picture the motor off the top of my head but that tube is either connected to the valve cover or if the tube seems to go up over the motor then that tube goes down into the motor. If it's the one thats connected to the valve cover then it's possible there is to much oil in the valve box. If it's the one that seems to go up over the top and in then if your just alittle to much over full you'll get oil out of that tube cause that tube sits alittle above the oil level.If your oil level is right on the line then I would run it for a bit then check the oil level. If the level is still good then you should be ok but keep an eye on it if it continues to blow oil out I would take it in to get looked at futher.
Jan 04, 2009 | Craftsman 4 Cycle Blower/Vac
2006 Suzuki DRZ400S oil leak from bottom of air cleaner.
Often times there is a engine breather tube that has to do with emissions that runs from the engine to the air filter breather box. This tube can in some cases blow oil through it when the engine is run hard. Make sure you're not over filling the engine with oil when you change it because this will cause the oil to "blow off" the excess and the air box is where it often goes.
There is also another possibility, are you using too much oil in your air filter after you clean it? This too is a common cause for oil in the air box, if that's the case I would not worry about it.
The last case scenario is one you don't want, that would be washed out rings which cause blow by and that in turn causes the engine to blow oil out of the breather tube which I'm confident it venting into the air box.
Please let me know if these resolve your question and if not give me more details and I will be happy to assist you further.
Regards,
RSelvy
Dec 08, 2008 | 2006 Suzuki DR-Z 400 SM
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
