Question about Exercise & Fitness
Nordictrack c2150 panel not working
My Nordictrack c2150 is plugged in and has the safety pin on, but the panel doesn't work and just flashes 0's. However, the only button that works is the 1 mile an hour button, and that's useless. It was working just fine a few weeks ago, and I already checked the panel for batteries. Please help!
    Top Expert:
  • 12,223 Answers
Adjust the Reed SWITCH, see the diagram attached it. Clean it, test it of open or faulty. Tight the connector very well. Replace and clean the contacts batteries( if they have).
Tight the ribbon cable inside.
If the problem persist, after you did, replace control display board
God bless younordictrack c2150 panel not working - 099b95f6-0273-44db-b9a8-431d1bfaedf5.gif
Posted on Jul 26, 2013
  • 64 Answers
SOURCE: My Nordictrack treadmill has the electronic panel
Your treadmills needs a motor controller. It could probably use some belt lubricate also. The heat that's created from the friction of the walking belt and the board under it causes an extra drag on the motor. The control board sends more power to the motor to make up for the loss of speed. This will eventually kill the controller. So lubricating could be a key factor to not damaging a new control board right away. Hopefully this helps.
Posted on Nov 18, 2009
SOURCE: I have a Nordictrack Solaris C2050 with the
I have the same issue I don't think anybody (including the supposed "experts") really know what they are talking about. The buttons work until they don't and then a bunch of them all stop functioning at once. The advice I always get is "replace the console" which amounts to saying "I don't know what's wrong" If I had to guess I think a static discharge has damaged the contoller board which doesn't manifest itself until the machine (and hence the board) warms up. Anyhow I haven't found a real solution to this issue if anyone has any real knowledge please post your solution.
Posted on Apr 12, 2011
ercupa190
  • 12223 Answers
SOURCE: My nordictrack 1000 turns on, but the track does not move?
1) Check the sensor reed switch see the diagram by 1/8"
2) use the calibration software for easy diagnostic and fix it. see your owner manual and go under the hood for instruction step.
3) exchange the battery by new ones for console.
4) Measure the input 115vac for motor without load
5 Test the main motor board for output +5vdc for Display board.
See the block diagram for easy diagnostic that I did designed for quicly adjusting and fix it.
Sincerely Merry Christmas,.
ernesto cuadra
managua, nicaragua. c.a
12_24_2011_6_16_18_pm.gif12_24_2011_6_16_37_pm.gifhttp://www.fixya.com/support/r10786838-test_procedure_dc_motor
see my tips
Posted on Dec 24, 2011
ercupa190
  • 12223 Answers
SOURCE: treadmill nordictrack c 1900 motor doesn't run, belt doesn't turn
1) Lube the deck belt, in according with the instruction manual.
2) Lube the rollers bearing, with the i. manual
3) Test the input voltage motor, if there are the motor need repair
4) Test the output voltage board, for input voltage motor, if there are Not the board is faulty. God bless you
Posted on Jun 03, 2012
ercupa190
  • 12223 Answers
SOURCE: Nordictrack ASR 630 display won't start
see the steps and fix it according. God bless you
Console 1
Remove the bolts or screws securing the console to the upright assembly. Lift the console and confirm that the cable connections are secure. Remove the cover from the console's battery bay and install a fresh set of batteries. Replace the battery cover.
Detach the ends of the pedals from the crank axles. Remove the left and right disc shields and side shields. Inspect the interior of the base unit and locate the flywheel.
Inspect the flywheel as it turns. Locate the magnet installed on the flywheel. Turn the flywheel until the magnet passes in front of the nearby reed switch. Loosen the screw securing the switch in place. Rotate the switch to reduce the gap between it and the magnet. Tighten the screw.
Replace the left and right disc shields and side shields. Reattach the ends of the pedals to the crank axles.
Posted on Nov 19, 2012
Belt not working
I believe your talking about the Controller, not a computer board. This device may turn on, however; the instructions and sequence of activity will not work. Many reasons for this to happen; and usually the problem is traced back to a power surge. Major components and equipment need to be plugged into a UPS (Uninhabitable Power Supply) with special protection to avoid damage to vital electronics. If plugged into the wall (directly) there are no protection devices and current can pass through a device and damage the controll unit.
Mar 25, 2014 | Nordic Track NordicTrack C2150 Treadmill
Nordictrack 5.7 buttons don't work
Call the 800 number on the front of your owner's manual (downloadable at iconservice.com) for service. Most likely your console is shot. It is easy to swap out, but costs a little bit. Also, make sure your safety key is on. Consoles do not operate without that little red key in the front.
Dec 01, 2012 | Nordic Track Nordictrack T 5.7 Treadmill...
When I plug my Nordictrack A2250 in the fan runs and the screen is blue, none of the buttons work. This is without the safety pin attached.
Adjust the REED switch, test it, clean it, and tight the plug or connector very well.
2) replace batteries with the same type, same mark, same polarity
3)clean contacts spring with c. cleaner spray. buy it from some electronic store.
God bless you
Nov 29, 2012 | Nordic Track Nodictrack A2250 Console...
NordicTrack ASR 630 Elliptical Console isn't working
1) replace new batteries with the same type, and o.k polarity.
2) clean the contacts batteries with c.cleaner and retight the spring with plier for a GOOD contact.
3) adjust the REED swtich, test it , clean it and tight the plugs
4) tight the ribbon cable inside for a good contacts keypads.
God bless you
Nov 27, 2012 | Nordic Track Nordictrack Asr 630...
How to replace the walking belt on the c2150
see the video and proceed according at your common sense and logically: GOD BLESS YOU
Jul 25, 2012 | Nordic Track NordicTrack C2150 Treadmill
I have a ge dsxh47egww that until reecently worked fine. Suddenly it would rapidly flash the signal, extra care and start button intermittently and not work. Now it doesn't do anything. what is
is there an error code displayed,then check tech spec sheet located inside unit? if no code,try measuring between pins 1 & 2 on plug J-4 if you have 120volts a.c. its the control board,if 0 volts are found then its the door switch
Apr 26, 2012 | GE DSXH47EGWW Electric Dryer
I have a Nordictrack Solaris C2050 with the controls not always working. Sometimes the panel and contrals with perfect other times only a few buttons work, like the 7MPH, reduce speed. This problem is...
Apr 09, 2010 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
183 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
