Question about Garden
Where is the vacuum hose attached on a J.D. GX-345
Fuel pump will not pull gas from the tank. I took off the fuel line, poured some gas into the line added a little pressure and the engine started/. I think the vacuum hose has a leak but I only see it attached to the engine block?
  • 2,239 Answers
This type of pump takes a pulse from the engine as the piston rises and falls, this is fed to a diaphram in the pump which then pulsates and pumps the fuel, if there is a loose or cracked pipe it will not work, if the diaphram is split or has hardened you will need to replace the pump as it is not sevicable.
Posted on Jul 25, 2013
redbeard00
  • 957 Answers
SOURCE: Occasionaly the engine shuts off and won't start on JD gx345.
If the fuel pump is working correctly then the problem is between the tank and the pump. run a fuel line from the pump to a gas can. If the pump is working it will siphon the fuel into your filter. If the pump is fine then there is blockage, broken fuel line (sucking air), or something blocking the pick up inside the tank.
Posted on May 23, 2009
  • 25 Answers
SOURCE: briggs and statton carb pouring fuel out
Could you have possibly lost a plug in the carb ?
Posted on Jun 23, 2009
  • 218 Answers
SOURCE: Mower won't start
Hi..my name is Keith and some mowers do have a fuel pump..if the fuel tank is lower than the carb...and they are operated by vacuum thats created in the crankcase and they are usually located on the carb...but i would check to see if some trash didnt stop up your fuel line..also..if you have old gas in it..a lawn mower engine doesnt or wont run on it..i hope this has helped..if not..write me back
Posted on Jul 01, 2009
  • 218 Answers
SOURCE: Engine stalls after 45 minutes?
Hi..my name is Keith...i would suspect either the fuel cap isnt venting..or if you have a fuel pump..that it is bad..i hope this will help..if not please write back
Posted on Jul 09, 2009
  • 13 Answers
SOURCE: I have a John Deere GX345 with a Kawasaki liquid
Sounds like you may have a problem with Choke adjustment, or perhaps a broken choke cable. Do you have a workshop manual?
Posted on Oct 25, 2010
Fuel pump leak
Looks like it may be a fuel return line from the fuel manifold . It may be split or loose . Probably both . Get a new section of fuel hose and some good clips and replace it
Feb 22, 2014 | Acura Cars & Trucks
I just installed a holley blue electric fuel pump and regulator. When I get on the highway I cant go more than a couple miles before I lose fuel pressure and have to pull off the road to refill the bowls...
Several things for you to check. I'd start with the fuel cap. Try to run the truck without a fuel cap on it and see if the problem occurs, perhaps the fuel cap is creating a vacuum and keeping the gas from flowing. Then, try taking a long hose and run it from the electric fuel pump back to the gas tank, and run the pump and see if the pump will pump continuously for 10 - 30 minutes. If this does not work, perhaps the fuel supply is blocked or the fuel line hose is collapsing between the pump and the gas in the tank.
Another thing could be is the fuel filter on the carburetor itself. Many carburetors have a screw-in fuel filter right where the gas line attaches to the carburetor that has a metal or paper filter inside. If this got dirty with all your work, perhaps that is it. Be blessed.
Nov 11, 2013 | Cars & Trucks
No fuel flow to Briggs & Stratton Intek, 18.5 hp
blow air back threw the line towards the tank you have something clogging it or you forgot to turn the fuel on
Jul 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Leaf blower not pulling fuel into carbeurator
Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to replace carburetor.
Dec 31, 2011 | Craftsman Garden
How to change a fuel pump on a 1992 Toyota carolla
Electric Fuel Pump-Fuel Injected REMOVAL & INSTALLATION The electric fuel pump is contained within the fuel tank. On 1988-92 models, it is necessary to remove the fuel tank from the vehicle in order to reach the pump. On 1993-97 models, the fuel pump can be accessed by removing the rear seat cushion and service hole cover. 1988-92 Models Fig. 1: Exploded view of the electric fuel pump 88275g77.gif
NOTE: Before disconnecting fuel system lines, clean the fittings with a spray-type engine cleaner. Follow the instructions on the cleaner. Do not soak fuel system parts in liquid cleaning solvent. CAUTION
The fuel injection system is under pressure. Release pressure slowly and contain spillage. Observe "no smoking/no open flame'' precautions. Have a Class B-C (dry powder) fire extinguisher within arm's reach at all times.
  1. Disconnect the negative battery cable and relieve the fuel pressure. Remove the filler cap.
  2. Remove the fuel tank from the vehicle.
  3. Remove the fuel pump bracket attaching screws, then remove the fuel pump/bracket assembly from the tank. Fig. 2: Remove the bolts retaining the pump bracket to the fuel tank 88275g78.gif
  4. Pull the lower side of the fuel pump from the bracket.
  5. Remove the nuts attaching the wires to the fuel pump.
  6. Disconnect the hose from the pump.
  7. Separate the filter from the pump. Use a small screwdriver to remove the attaching clip. Fig. 3: Pull off the lower portion of the pump from the bracket 88275g79.gif
    Fig. 4: If necessary, remove the clip and pull out the filter to replace it 88275g80.gif
  8. While the tank is out and disassembled, inspect it for any signs of rust, leakage or metal damage. If any problem is found, replace the tank.
  9. Inspect all of the lines, hoses and fittings for any sign of corrosion, wear or damage to the surfaces. Check the pump outlet hose and the filter for restrictions.
  10. When reassembling, ALWAYS replace the sealing gaskets with new ones. Also replace any rubber parts showing any sign of deterioration. To install:
  11. Install the pump filter using a new clip. Install the rubber cushion under the filter.
  12. Connect the outlet hose to the pump, then attach the pump to the bracket.
  13. Connect the wires to the fuel pump with the nuts.
  14. Install the fuel pump and bracket assembly onto the tank. Use new gaskets.
  15. Install the fuel tank.
  16. Start the engine and check carefully for any sign of leakage around the tank and lines. Road test the vehicle for proper operation.
1993-97 Models CAUTION
The fuel injection system is under pressure. Release pressure slowly and contain spillage. Observe no smoking/no open flame precautions. Have a Class B-C (dry powder) fire extinguisher within arm's reach at all times. Fig. 5: Exploded view of the fuel pump components 88275g81.gif
  1. Disconnect the negative battery cable. CAUTION
    On models with an airbag, wait at least 90 seconds from the time that the ignition switch is turned to the LOCK position and the battery is disconnected before performing any further work. Refer to Section 7 for all air bag warnings.
  2. Relieve the fuel pressure.
  3. Remove the rear seat cushion.
  4. Remove the floor service hole cover. Fig. 6: Remove the 4 service hole cover retaining screws 88275g82.gif
  5. Disconnect the electrical fuel pump wiring at the fuel pump assembly. Check for any fuel leakage while in there.
  6. Remove the gas cap, this will prevent any fuel gas spilling out of any high pressure lines.
  7. Using SST 09631-22020 or an equivalent line (flare nut) wrench, disconnect the outlet pipe from the pump bracket. Fig. 7: Disconnect the outlet pipe from the pump bracket 88275g83.gif
  8. Remove the pump bracket attaching screws.
  9. Disconnect the return hoses from the pump bracket, then pull out the pump/bracket assembly.
  10. Remove the nut and spring washer, then disconnect the wires from the pump bracket.
  11. Remove the sending unit attaching screws, then remove the unit from the bracket. Fig. 8: Pull the pump bracket with pump attached from the tank 88275g84.gif
  12. Pull the lower side of the fuel pump from the bracket.
  13. Unplug the connector to the fuel pump.
  14. Disconnect the hose from the pump.
  15. Separate the filter from the pump. Use a small screwdriver to remove the attaching clip.
  16. Inspect all of the lines, hoses and fittings for any sign of corrosion, wear or damage to the surfaces. Check the pump outlet hose and the filter for restrictions.
  17. When reassembling, ALWAYS replace the sealing gaskets with new ones. Also replace any rubber parts showing any sign of deterioration. To install:
  18. Install the pump filter using a new clip. Install the rubber cushion under the filter.
  19. Connect the outlet hose to the pump, then attach the pump to the bracket and tighten to 22-25 ft. lbs. (29-34 Nm).
  20. Engage the connector to the fuel pump.
  21. Install the fuel sending unit to the pump bracket.
  22. Install the fuel pump and bracket assembly onto the tank. Use new gaskets. Tighten the pump bracket retaining screws to 34 inch lbs. (4 Nm).
  23. Connect the return hoses to the pump bracket.
  24. Install the service hole cover, then the engage the fuel pump and sending unit connector.
  25. Install the rear seat cushion.
  26. Start the engine and check carefully for any sign of leakage around the tank and lines. Road test the vehicle for proper operation.
Jan 24, 2011 | 1992 Toyota Corolla
How to change afuel pump on a 1993 Aerostar ford van
put the van up on ramps in the rear, unbolt gas tanks straps, hopefully u take gas out before, take clamps off filler neck and pull big and small hose off let tank down slow and disconnect wiring plug and fuel lines to pump then pull tank out from under van. very carefully unscrew big washer that holds pump in, put in new pump and reassemble the way you took it out, good luck, remember be gentle with fuel lines and wiring
Jan 05, 2011 | 1993 Ford Aerostar Extended
My briggs 12 hp runs when gas poured in carb but only 10 to 20 secs. there is some sort of module w/ 3 quarter inch rubber hose to it. does anyone know if this is essential to the running of the engine? i...
THe module with the 3 hoses, quarter inch each, is the fuel pump. Pull the fuel line off the carb and hold into empty can, crank the engine with the starter. If the fuel pump is good it will pump a stream of fuel into the can ( the stream will pulse as the pump works off of engine vacuum). Check the fuel you have caught in the can- is it stale or does it have water in it? If no fuel comes out then remove the fuel line from the tank to the pump and make sure you have fuel getting to the pump. The third line is the vacuum line from the valve cover and should not be an issue unless it is cracked and broken.
If the pump checks good and you are getting good fuel to the carb then rebuild carb.
The air filter assembly is essential for keeping the carb from ingesting dirt and ruining the motor but has nothing to do with the function of the carb.
Nov 29, 2009 | Briggs & Stratton Garden
How do I empty gas tank on a 6 deville?
Hoggins12
I assume that you need to change the fuel pump. Before you do this loosen the gas cap and try to run the car. Cadillac and other new cars have a vacuum pump to pull vapors back to the engine. If that pump does not work the tank builds up a vacuum and the car will not KEEP running on the road. It could be the vaccum pump and not the fuel pump---Check the fuel pressure at the fuel rail. If you determine that the fuel pump is, indeed, the culprit; it is possible that the fuel can be sucked past the fuel pump. To do this; determine which is the line running to the fuel rails--it is about 5/16 " diameter/Black in color.
If you plan to cut this line to apply suction/pump--have a repair plan in place as these lines are NOT available even from Salvage yards.
Simple hose and clamps will not do it--they blow off on the road.
Glue---Sections of tight fitting over fitting hose and more glue---clamps--retaining wire---do it all !!!.
The tank can be dropped with a floor jack in the center of the tank---disconnect the holding straps from the back of the car--the tank will drop at the front enough to disconnect the various hoses from the pump/guages .--The fuel pump can be removed this way without taking the plastic fuel tank completely out or the gas out of the tank--------The front of the tank will slide down the straps and push to the back allowing work to be done. Get the car off the ground about 18 inches. DO NOT use and incandescant bulb for light as it can ignite gas fumes---Be concerned !!!
When you work on this problem---match mark everything including the hose routing to the tank--you might think that you will remember---but pulling th tank down again to reposition a hose route is a pain--been there---done that !!--best to use spray paint for hose routes. Be sure to mark the hose ends that go closest to the tank.
Be sure not to bend the float assembly when removing the pump. The fuel guage will be affected.
At the back of the tank/top there is a wiring harness that needs to be unplugged---do it. Do it first.
I hope this helps--Rick
Dec 13, 2008 | 1995 Cadillac DeVille
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
