Question about Neff S51M53X0 24 in. Built-in Dishwasher
Dishwasher door will not close properly
Hi guys, Our Neff dishwasher is just out of warranty and the door is not closing properly. We have not fitted the child lock and it was working fine in the last cycle so i cannot understand why this is happening. Its just not clicking in to place. They want to charge a lot of money to send someone out but im sure there must be a reasonably easy fix for this.
    Master:
  • 966 Answers
Usually d/w doors are fine for long time.
1. check if anything blocks it to close securely e.g. the cutlery basket or the dish racks not fully sliding in or may be off track/chanel.
2. try running a cycle empty and see if it closes after doing #1.
Posted on Jul 26, 2013
3 Suggested Answers
  • 10865 Answers
SOURCE: Neff dishwasher door catch not corking, door does not close ?
look carefully at the catch and the latch as almost all can be adjusted with just a screw driver.
Posted on May 31, 2009
SOURCE: adjusting the door on a neff dishwasher
I have the same problem with my newly installed Miele integrated dishwasher. The door does not stay open when you are trying to load dishes. I heard that there is an adjustable internal mechanism to adjust the tension on the door. But, I am still working on solving my problem.
Posted on Aug 17, 2008
I have a Kelvinator dishwasher,KD14ss, the door does not close ,ther is nothing in the way of the door ??
Hi Bets, It could be that the dishwasher door is hitting the installation cabinet or the screws holding it in place. Check to be sure the door is not hitting the cabinet or screws under the counter. Many times a screw may come loose and get in the way of the dishwasher door. If this happens the dishwasher door cannot close. Simply tighten the screw back into place and test to be sure the dishwasher door closes properly.
The dishwasher door hinges pivots on the bottom of the dishwasher frame. It holds the dishwasher door on and the pivoting allows the dishwasher door to open and close. If the dishwasher door hinges are bent or loose then the door cannot close properly. Replace the dishwasher door hinges if you find them to be bent or damaged.
Hope these will help.
David
Jan 27, 2018 | Kelvinator Dishwashers
Dishwasher will not start unless I push the door in further
could you please let us know the model #
thanks
sb on the door frame if not go here for a model# finder
http://www.neff-home.com/uk/service/manual
Jan 22, 2018 | Neff Dishwashers
Deactivate childlock on fully integrated neff dishwasher
If door won't close and you don't have a child-lock, just push the door closed a lot harder than you normally would - NEFF manual says to do that, and it worked for me! I think it just forces it to engage and 'releases' the catch, as after that it closed with just normal pressure applied.
Apr 09, 2012 | Neff 24 in. S5456 Built-in Dishwasher
Our dishwasher is blinking CL - i think this means 'Close'... Even when the door is properly closed, it blinks CL and won't start!! Help!
Hi
Error CL appears when the dishwasher control detects door switch is open or door is open. You'll have to open the door and check the continuity of the door switch. If the door seems to be closed then it is the control has detected an issue with the door latch. Check the door latch & seals to make sure door is closing fine. Unplug the dishwasher from power outlet and wait for 10-15 minutes. Restart the dishwasher and check if the error is still there. If error still appears then you'll need to repalce the door switch/door latch. Hope this helps... Please post back for further assistance.
Daniel
Mar 24, 2011 | Frigidaire Professional Series 24 in....
Door Open but latch in closed position - HELP!
You need to operate the door release handle at the same time as applying pressure to the latch you can see just inside the door (imagine which way it would move if the thing was working as designed), the tech has possibly simulated a door closed position for testing purposes.
Apr 22, 2010 | Neff 24 in. S5456 Built-in Dishwasher
May 31, 2009 | Neff 24 in. S4456 Built-in Dishwasher
Neff dishwasher door problem.
The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
May 21, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Fitting a new front panel to the NEFF 54432 integrated dishwasher
My Neff integrated dishwasher has two holding screws in the top corners and then two hidden screms half way down the side behind plastic covers. Loosen these side screws, remove the top two corner screws and then the door cover/panel should lift out of two lugs at the bottom.
Aug 13, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Brada ef2401 door won't close
We actually had the same problem with our Brada dishwasher. There is a plastic clip inside the door that latches on to the dishwasher to keep the door closed. In our case this clip had flipped inside the door (periodically continues to happen to this day). To resolve we took the door apart - carefully - and flipped the clip back into proper position. You can only do this if the dishwasher is not under warranty as once you take it apart you will likely void the warranty on it.
Aug 12, 2008 | Dishwashers
Adjusting the door on a neff dishwasher
Mar 16, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Neff S51M53X0 24 in. Built-in Dishwasher Logo
351 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
