Mita copie c1025 fault c5300 - Office Equipment & Supplies
Problem code c1440on 2003 ford explorer
C1440 Pressure Transducer Input Circuit Failure YES
C1440 (ABS only) Pressure Transducer Input Circuit Failure ABS Module Go To Pinpoint Test P .
Normal Operation The brake pressure switch provides an additional speed control deactivation if the brake pedal position (BPP) switch fails. When the brake pedal is pressed, 1700 kPa (246 psi) of brake fluid pressure in the brake master cylinder opens the brake pressure switch, removing B+ voltage to the speed control servo electric clutch.
    Possible Causes
  • circuit 10 (LG) open
  • circuit 307 (BK/YE) open, short to power
  • ABS module
  • brake pressure switch
  • speed control deactivator switch
PINPOINT TEST P: DTC C1440 (ABS ONLY) - PRESSURE TRANSDUCER SIGNAL FAULT CAUTION: Use the flex probe kit for all test connections to prevent damage to the wiring terminals. Do not use standard multimeter probes.
Test Step Result / Action to Take P1 VERIFY THE DTC
  • Connect the diagnostic tool.
  • Key in ON position.
  • Clear DTC C1440. Road test the vehicle. Repeat the self-test.
  • Does DTC C1440 repeat?
Yes
GO to P2 .
No
The system is OK at this time. P2 MONITOR THE BRAKE PRESSURE SWITCH PID FOR CLOSED POSITION
  • Enter the following diagnostic mode on the diagnostic tool: ABS Module PID.
  • Monitor the powertrain control module (PCM) brake pressure switch PID.
  • With foot off the brake pedal, does the PID read closed?
Yes
GO to P3 .
No
GO to P4 . P3 MONITOR THE BRAKE PRESSURE SWITCH PID FOR OPEN POSITION
  • Monitor the PCM brake pressure switch PID.
  • While pressing the brake pedal, does the PID read open?
Yes
GO to P9
No
GO to P7 . P4 CHECK THE CIRCUIT 10 (LG/RD) FOR AN OPEN
  • Key in OFF position.
  • Disconnect: Speed Control Deactivator Switch C1025.
  • Measure the voltage between the brake pressure switch C1025-2, circuit 10 (LG/RD), harness side and ground.
  • Is the voltage greater than 10 volts?
Yes
GO to P5 .
No
REPAIR the circuit. CLEAR the DTCs and REPEAT the self-test. P5 CHECK THE BRAKE PRESSURE SWITCH
  • Measure the resistance across the brake pressure switch pins, component side.
  • Is the resistance less than 5 ohms?
Yes
GO to P6 .
No
INSTALL a new speed control deactivator switch. REFER to Section 310-03 . CLEAR the DTCs. REPEAT the self-test. P6 CHECK CIRCUIT 307 (BK/YE) FOR AN OPEN
  • Connect: Speed Control Deactivator Switch C1025.
  • Disconnect: ABS Module C155.
  • Measure the voltage between the ABS module C155-40, circuit 307 (BK/YE). harness side and ground.
Yes
GO to P9
No
REPAIR the circuit. CLEAR the DTCs. REPEAT the self-test. P7 CHECK CIRCUIT 307 (BK/YE) FOR A SHORT TO POWER
  • Disconnect: Brake Pressure Switch C1025.
  • Measure the voltage between the ABS module C155-40, circuit 307 (BK/YE), harness side and ground.
  • Is any voltage present?
Yes
No
GO to P8 . P8 CHECK BRAKE PRESSURE SWITCH
  • Start the engine.
  • Measure the resistance between the brake pressure switch C1025 pin 1, component side and the brake pressure switch C1025 pin 2, component side while firmly pressing the brake pedal.
  • Is the resistance greater than 10,000 ohms?
Yes
GO to P9 .
No
INSTALL a new speed control deactivator switch. REFER to Section 310-03 . CLEAR the DTCs. REPEAT the self-test. P9 CHECK FOR CORRECT ABS MODULE OPERATION
  • Disconnect all ABS connectors.
  • Check for:
    • corrosion
    • pushed-out pins
  • Connect all ABS connectors and make sure they seat correctly.
  • Operate the system and verify the concern is still present.
  • Is the concern still present?
Yes
INSTALL a new ABS module. REFER to Anti-Lock Brake System (ABS) Module in this section. TEST the system for normal operation.
No
The system is operating correctly at this time. Concern may have been caused by a loose or corroded connector. CLEAR the DTCs. REPEAT the self-test.
Jul 01, 2017 | Ford Cars & Trucks
2002 f150 cruise inop shows code 3?
  • 3 flashes - deactivator switch is open or circuit defective.
    • Flash code 3 - deactivator switch circuit failure
    • Central junction box (CJB) fuse 13 (20A).
    • Circuitry.
    • Deactivator switch.
    • Speed control servo.
    • Go To Pinpoint Test H .
    PINPOINT TEST H: FLASH CODE 3 - DEACTIVATOR SWITCH CIRCUIT FAILURE
  • CONDITIONS DETAILS/RESULTS/ACTIONS H1 CHECK THE DEACTIVATOR SWITCH CIRCUITRY
    Speed Control Servo C122
    Measure the voltage between the speed control servo C122 pin 9, circuit 307 (BK/YE), harness side and the speed control servo C122 pin 10, circuit 57 (BK), harness side.
    Yes INSTALL a new speed control servo. REFER to Speed Control Servo in this section. REPEAT the self-test.
    No GO to H2 . H2 CHECK DEACTIVATOR SWITCH POWER
    Measure the voltage between the deactivator switch C1025, circuit 10 (LG/RD), harness side and ground.
    Yes GO to H3 .
    No REPAIR the circuit. REPEAT the self-test. H3 CHECK CIRCUIT 307 (BK/YE) FOR AN OPEN Measure the resistance between the speed control servo C122 pin 9, circuit 307 (BK/YE), harness side and the deactivator switch C1025, circuit 307 (BK/YE), harness side.
    Yes INSTALL a new deactivator switch. REFER to Speed Control Deactivator Switch in this section. REPEAT the self-test.
Nov 23, 2016 | 2002 Ford F-150
HOW DO YOU CLEAR ERROR CODE C5300 IN A KYOCERA 5050 MACHINE
You will need to replace the cleaning lamp for the drum unit or replace the engine board
Dec 16, 2014 | Kyocera Mita Office Equipment & Supplies
You can try resetting the fuser error code by performing the procedure below:
On the copier type - 10871087 (may have to be in the job status menu first)
Once in MA mode type in - 163
Start
Execute
Start
You should then either cycle the power or the machine will cycle for you.
If this does not work you will need a new cleaning lamp for your fusing unit.
The cleaning lamp (which is in the drum unit) is defective. Replace the drum unit.
Kyocera mita 2530
Two most common faults for this are - if its a smudgy line, replace/repair the fuser unit. If it is a neat straight line, replace the drum unit.
Dec 06, 2013 | Office Equipment & Supplies
Mita all copies have clean, thin, black streaks
Needs a clean around the fuser area. You may see a build up of toner near the rollers which is being drawn in. There's an outside chance that the lens needs cleaning also.
Jul 07, 2009 | Kyocera Mita Kyocera-Mita SCANNER RACK...
11 people viewed this question
jasbo
jasbo
