Question about Garden
Is oil color for a gas tiller normal when it's like a light cream color?
I opened the plastic plug where to add engine oil and some of the oil inside oozed out and it was like lite cream color. Is this a normal color? Thank you for any comments.
  • 2,239 Answers
The oil is immulsified, so there has been water in the oil.
Posted on Jul 26, 2013
Why does this tiller have two places to add oil?
Engine and Gearbox
or
Engine and Two Stroke Oil for the gas if the engine is two stroke.
Difficult to say without a make and model. The caps normally have embossed legends on them or a sticker nearby.
Apr 29, 2016 | Garden
How do I change the oil on powermate front tine tiller?
If you mean engine oil, place unit in big drain pan, remove plug at bottom edge of engine crankcase, drain, replace plug, fill with fresh oil.
Sep 30, 2014 | Powermate 21 in. 173 cc Front Tine...
Oil drain location on cub cadet rt65
How old is it? Lots of newer small engines don't have a drain plug. You tilt it on its side and let the oil run out the oil filler hole after removing the dip stick. I put a piece of plastic shopping bag over the gas tank hole and put gas cap back on to help keep gas from coming out. Good luck.
Jul 26, 2014 | Cub Cadet RT65E - RT65E 18" 208cc Dual...
Chocolate ice cream has turned a funny color and that side is running loudly
A grey color often indicates the beater bar is grinding on the inside of the barrel. What you may be seeing is metal. Be sure your beater bar is not bent. Visually inspect the inside of the barrel for marks. Wear is not normal. If you see wear and the beater bar is not bent, be sure all plastic bearings and components are installed. Also, it is normal to have some drip and lube in the drip pans, excessive amounts usually indicate problems though. Hope this helps you.
Mar 14, 2013 | Taylor 2008 C713-27 Soft Serve Ice Cream...
Tiller engine won't turn over after the till was on its side to clean tines
remove the spark plug and pull it to force any fuel and oil from the cylinder hold a rag over the top of the spark plug hole as fuel and oil will spray out check the oil level before running the engine again
Apr 30, 2012 | Troy Bilt Bronco 208cc 4Cycle Gas Powered...
I recently bought a second hand pony garden tiller and want to check and change oil in the tiller. Serial #496063 Can you tell me where to check the oil and how to change or add oil???
Hi and welcome to FixYa. I am Kelly. You did not mention engine size but most of the "Pony" Tillers had a 250 cc Briggs and Stratton engine.
The owners manual is here::
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/tillers/769-03556.pdf
If you download the manual on page 23 figure 7-6 you will see the WHITE oil cap on the right side of the engine just forward of the belt. Unscrew that by placing a screwdriver across the 2 raised tabs IF you can not get it loose with your fingers. There is a dip stick with oil level indicators on it inside the engine.
Just forward of the dip stick in figure 7 - 6 there is a rectangular / 4 sided plug. That is the oil drain port. Changing the oil is a matter of removing the plug and waiting until all the oil had drained and then reinstalling the plug.
Oil is added via the dip stick port. (White 2 tab cap behind the oil drain plug near the belt area)
Since I do not have your engine number I could not get your engine manual for you. The engine number is stamped on the Air Shroud of hte engine and will be in 3 parts. I believe this is your engine number but not 100 % sure: 150212-2560-B8
The parts and owners manual are on this page. ( you will need to downloand each one)
http://www.briggsandstratton.com/engines/support/operators-manuals.aspx?NTT=150212-2560-B8
Engine: http://www.briggsandstratton.com/document/index.aspx?doc=277040WST_E_LO.pdf
Engine parts:
http://www.briggsandstratton.com/document/index.aspx?doc=MS3796_E_LO.pdf
Thanks for Choosing FixYa,
Kelly
Oct 04, 2010 | Troy-Bilt Pony Garden Tiller
I have bougt an old Ariens RT 254 and wonder if I shall use petrol with oil or not.
I can't find anything on an RT 254, but if you meant RT 524, that is a rear tine tiller with a 5 horsepower gasoline (petrol) engine. That engine should not require you to add oil to the petrol. You can purchase a generic service manual which does includeyour tiller here if you like.
Or, just look for a crankcase oil drain plug which sticks out the side of the very base of the engine, and a fill plug, which is angled and higher up and usually plugged with a screw-in plastic plug. Take that plastic plug out and check the oil - in fact, if it's an old machine, I recommend you drain the oil (using the lower plug) and refill it (until it is at the level of the upper plug). In any case, this confirms you don't need to add oil to the petrol. Happy tilling! Please rate my solution if helpful, thanks.
Aug 15, 2010 | Ariens Garden
Broken Gasket?
Head gasket has failed allowing oil and coolant to mix together. Don't drive it until repaired,
Feb 05, 2009 | 1998 Acura RL
Fg 110 mini tiller by honda
I have had the same problem.
The first time the solution was to replace the rubber membrane underneath the primer bulb. Take off the bulb, then remove the plastic part underneath the bulb. There is a rubber membrane underneath that. The ethanol in the gasoline tends to deteriorate the membrane. The honda dealers sell them for about 14 dollars.
The second time the problem was caused by the gas cap, not properly venting. In this case the engine would start and run, but when I gave it full throttle, it would quit.
It got so bad that it wouldn't even run. I noticed when I loosened the gas cap it ran great.
So I took off the cap, removed the inner parts, and got a diaper in and pushed it though the holes in the plastic part underneath the cap, and through the rubber plug in the center. I did this a few times and check with my mouth to see if I could pull some air through the cap. When it breathed satisfactorily, I put the cap back on the gas tank and it ran great. Now it runs better than new.
Jan 13, 2009 | Honda 25cc 4-cycle Mini Tiller
Broken Gasket?
yes the motors head gasket failed and to add on this it is an expensive fix but it is cheaper than buying another car but make sure u go to a well known shop and get a warrenty for the repair
Jun 27, 2008 | 1997 Pontiac Grand Am
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
