Question about Jenn-Air 30" Built-in Double Wall Oven Jjw9430dds, Demo
Jenn air display board....
I could not find my Jenn air model number, however I have the information on the display board, Is there a way to get the model number for this display board from the following information: 100-00696-00 cn:209617 CHEAD dbl sn:8907 Thanks for your help
SOURCE: Problems with Jenn-Air Electric Double-Wall Oven
Try changing the clock assembly --
http://www.partselect.com/ModelFrames.aspx?ModelID=221346&ModelNum=WW30430P&mfgModelNum=&ManufactureID=1&Selected=51238&Position=1&mfg=Maytag&Type=&Mark=1
here is a link to the diagram.
PS120923
Electronic Clock Assembly (Series 10)
Help with series numbers
here is the part number.
Posted on Feb 17, 2008
  • 1314 Answers
SOURCE: Jenn Air Oven Model WM27260B Error code F7 plus beeping
f7 is a shorted key-stuck function on control
Posted on Feb 19, 2008
SOURCE: Electronic Display
Go to, fixitnow.com for a cheap fix on these displays. It worked on my jenn air.
Posted on Feb 28, 2009
localwonder
  • 6784 Answers
SOURCE: jenn-air w156, displays f1 fault code. how do i
This is a Defective touch pad or membrane
Replace touch pad or membrane (this problem is usually the touch pad)
Posted on Jun 23, 2009
pride applia
  • 232 Answers
SOURCE: jenn-air ccg2520 burners will not ignite - no
check for power by pluging something else in, did it get somthing spilled in it, compressed air blown under knobs removed should doit or just wait for it to dry out are all the burners affected
Posted on Jul 01, 2009
F7 code flashes on jenn aire 27 inch wall oven
The F7 code indicates that the touch pad either has a "stuck" or shorted key. Depending on the oven model, you either need to replace the touch pad or the controller (clock) and the touch pad. (Some Jenn Air appliances sell the two as one unit.)
Please add a comment with your model number to get additional information on the availability and price for the parts. (Parts may be available from a number of suppliers, including jenn-air.partselect.com.)
I hope this helps.
Mar 01, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
I have a jenn-air electric down draft slide in range. I had a power outage and now stove top works fine but no display or oven functions not even oven light.
You will need to replace the control board (clock assembly) on your unit. I see this all the time with power surges and it takes the control board out. Your model is a discontinued one and the part may need to be a special order. Here is a link to the part, call the number that is on the page and I am sure they may get it for you.
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-clock-item-number-ap4088717.aspx
Nov 08, 2011 | Jenn-Air SVE47100 Slide-In Electric...
What does F1 mean on my oven
F1 code for Jenn Air is related to the main electronic control board. If you can turn your breaker off for a few minutes then back on it may reset. If not you will most likely need a new control board. Depending on your model number and age there may be extended warranty on the parts, check with Jenn Air to be sure
Apr 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
F1 fault code? Jenn-Air SVE47100
HI. This is concerning the relay board that is installed in your unit. I would recommend to inspect the entire wiring harness that is linking the relay board to the elements, and other power component's. If the harness is ok, and connected tightly, and correctly, this will confirm that the relay board has failed. It must be replaced in the case. Be sure to inspect all wiring harness connections for corrosion before you replace the board. This could be as simple as a failed connection.
PRB Part Number is #71002144
Nov 14, 2009 | Jenn-Air SVE47100 Slide-In Electric...
The touch pad on my Jenn Air Model JES9800BAF does not work. The clock does not display either. All four burners operate normally.
All burners work fine, clock display is blank, if the oven isn't working either, your display / control board is shorted out
Nov 13, 2009 | Jenn-Air JES9800BA Electric Range
Jenn-Air model #sve47600b. Today put new display control panel in. Didn't fix the problem. The display now works, but the oven light and fan will not stop running. Also the touchpad doesn't work. If it...
Make sure that you properly plugged in the keypad cable. There is the wide connector that brings all the keypad touches up to the display board, and there is the small 4-black wire connector that brings power to the control board.
For future reference, we repair electronic control boards at www.fixyourboard.com, maybe we can help you in the future.
Oct 08, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Mar 23, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jenn Air SVE47600b dead touch panel and blower runs constantly
I have had similar problems:
Display was the Part # 71001799 circuit board..$175+labor
Oven blower problem was control relay board, part# 12001689...$224+labor
My solution. replace with non-Jenn Air.
Check Consumer Reports. Jenn Air has high repair history.
Mar 14, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Jenn Air JMW8530CAB time/temperature light don't work
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 18, 2008 | Jenn-Air JMW8530C Electric Double Oven
Jenn-Air 30" Built-in Double Wall Oven Jjw9430dds, Demo Logo
Top Jenn-Air Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Jenn-Air Heating and Cooling Expert? Answer questions, earn points and help others
