Question about Tablets & eReaders
How can i unlock my kindle model d01200
My son locked my kindle and i cant unlock it
Reset forgotten password kindle touch m/o:D01200
  • Hold the power switch for twenty seconds. You will need to slide the power switch along and hold it for twenty seconds before releasing it.
  • Your reboot screen should appear when you release the power switch.
  • Give your device time to reboot for a minute or two.
  • Turn the Kindle Fire HD back on.
  • Mar 04, 2018 | Tablets & eReaders
    I bought an amazon Kindle Fire on ebay and cannot get it unlocked. help please.
    Brenda, Check the attached links,
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    How to Reset Locked Kindle Fire
    Kindle Fire HD how to reset when locked up EpicReviewsTech CC
    when ur locked out of ur kindle how do reset it
    Kindle Fire Password Remove
    Mar 02, 2016 | Amazon Kindle Fire HDX 7
    How to unlock kindle fire
    Forgot my password
    Did you forget the password used to unlock your Kindle? If so, you'll need to reset the device to gain access. By resetting, your Kindle will be restored to factory defaults, which means your registration information and content will be removed, and all settings will return to the defaults.
    To reset a Kindle Fire 1st Generation:
    1. From the lock screen, slide the Unlock Bar from right to left
    2. Use the keypad to enter characters into the password/PIN field four times
    3. You'll be prompted to reset your Kindle Fire. Tap "Ok reset"
    To reset all other Kindle Fire models:
    2. Use the keypad to enter characters into the password/PIN field five times.
    3. When prompted to reset your Kindle Fire, tap "Reset"
    To reset a Kindle 2nd Generation, Kindle Keyboard, or Kindle DX:
    1. Slide and release the power switch to turn on the device or exit sleep mode
    2. Enter "resetmykindle" in the password field and press the enter key on the key pad
    3. Wait several minutes while your Kindle restarts
    To reset a Kindle (5-way controller):
    1. Press and release the power button to turn on the device or exit sleep mode
    2. Select the keyboard key once on the password screen and enter "resetmykindle" in the password field, then select "Enter"
    To reset a Kindle Touch or Kindle Paperwhite:
    2. Tap the password field to bring up the onscreen keyboard
    3. Enter "111222777" and select "OK"
    If you don't remember your Parental Controls password, you can deregister your device instead of resetting, as long as you're connected to a wireless network. You'll need to redownload your content, but items that were transferred via USB will be kept. Here's what to do:
    1. Visit the Manage Your Content and Devices (www.amazon.com/manageyourkindle) page on your computer
    2. Select the "Manage Your Devices" link
    3. Select "Deregister" to deregister your device from your account
    Sync your Kindle, then register again.
    If you need help with your Wi-Fi password, please contact your Internet Service Provider or router manufacturer.
    Feb 25, 2015 | Amazon Kindle Fire HD 8.9"
    Kindle Touch D01200 - Why do the screen freeze. I know how to solve (happens frequently), but would like to know why
    It should not happen at all.
    If you have 2,000 books on it and 400 collections then yes, the poor machine will just give up.
    Keep it thin - just a handful of books on;
    on the HOME page search for skdhfsdfh - if it says "6 documents not indexed" go down and delete those 6 books, they are corrupted - you can download them again.
    Aug 07, 2013 | Amazon Kindle Touch 4gb, Wi-fi, 6in -...
    My kindle will not turn on.
    maybe it is out of battrery.
    May 03, 2013 | Amazon Tablets & eReaders
    Unlock kindle fire pin code
    Once the Kindle Fire is locked, there is no override or back door to unlock the device. You will need to contact Amazon to unlock the device. They usually send you a new device.
    Apr 21, 2013 | Amazon Kindle Fire HD
    My kindle fire hd is locked.
    If you see a lock when you open the kindle have you tried to run your finger from the lock across the screen??? Most new kindle users are unaware of this as I was. If that isn't your problem then I cannot help you. good luck.
    Dec 18, 2012 | Amazon Kindle Fire HD
    Kindle modle D01200 wants impossible passcode
    I bought a Kindle Touch D01200 Wi-Fi 6" E Ink Display 4 GB Graphite and it was a Demo modile. I need to know how to get it off of the demo and register it with Amazon if I can?
    Jul 30, 2012 | Amazon D01200 Kindle - 6-inch E-Ink...
    Tablets & eReaders Logo
    165 people viewed this question
    Top Tablets & eReaders Experts
    Are you a Tablet and eReader Expert? Answer questions, earn points and help others
