Question about Peavey PV-215 Dual 15 2-Way Speaker Enclosure *
Sony STR-DN1010 with RCA output jack to Peavey PV-215 speaker input jack
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Peavey Expert
  • 232 Answers
Is this a line level out put on the Sony? all the amp outputs on this unit use Banana Plugs, you will need an amp some where if it is. This speaker is not powered.
Posted on Sep 20, 2014
I can't seem to independently control effects on my mains AND monitors.
We'll need the make and model of your mixer in order to help you.
May 28, 2016 | Music
Horns wont play in peavey 215
broken crossover or bad diaphram or wire off in the high circuit.
Mar 13, 2014 | Peavey PV-215 Dual 15 2-Way Speaker...
Hello, I have a Sony STR-D85 surround sound system. I need to connect my phone to the system so that my phone's music plays through my surround sound speakers. The front of the console has a headphone...
Headphone jack is an output not input jack. Your going to need a cord to go from your headphone jack(output) of your phone to audio input on your receiver. The cord has a mini stereo plug to the phone and RCA plugs of left and right to your receiver auxiliary input. Good luck..
Jul 15, 2011 | Sony STR-DE485 Receiver
I feel like a dork asking this question but how do you connect the amplifier to your mixer. I see that there are places for a banna plug however my mixer will not take a 1/4 banna plug.
In case you don't have one, here is a link to the manual:http://www.peavey.com/assets/literature/manuals/80300573.pdf I don't know if you are using a separate crossover between the mixer and the amp but here is the simplest explanation.I just reread your question and I don't even know whether you have a Peavey amp. Run proper cables from the main output of your mixer to the main inputs of your power amp.They will be 1/4"shielded cables or Balanced XLR cables. Do not use unshielded speaker cables to hook the mixer and the amp together.Run speaker cables from the speaker outputs of the amp to the input jacks of your speakers.Make sure the impedance of your speaker cabinets equals or exceeds the impedance rating marked on your amp. Here is the link to the newer model PV2600 manual:http://www.sweetwater.com/store/media/pv2600_doc_manual.pdf Don't use Speakon cables unless your speaker cabinets are equipped with Speakon input jacks. Banana plugs aren't as solid a connection as the binding posts are.
Nov 07, 2010 | Peavey Pv 2600 Power Amplifier
Connecting a Sony Subwoofer SA-W2500 to a STR DE 598
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Jan 08, 2010 | Sony STR-DE598 Receiver
Hook up wireless speakers
I'm assuming the wireless speakers you have utilize an RCA jack to connect to the receiver.
Solution:
The good news is yes, you can use them on your receiver. The bad news is that the only output on your receiver is "VIDEO OUT" so whatever you want to watch or hear on the wireless speakers must be connected to the "VIDEO INPUT".
If the wireless speaker module uses speaker wire to connect to a receiver you will simply tap into the surround thumb clip speaker jacks.
I will add that wireless speakers tend to be disappointing when used in home theater.
Mar 24, 2009 | Sony STR-DE475 Receiver
PV 2600, couple years old, light usage. Connected to two PV SP3K speakers. One channel started to cutout somewhat but not all the way, Switched a few input cables, swapped L&R. Then whole amp shutdown....
Hi..
I've worked on similar units.
Things I'd check first :
Dust in the unit.
Weak solder connections /crusty debris stuff on the input jacks or output terminals
Any flex cables soldered in tend to be a problem on peavey amps I resolder all those contacts.
Checking the amp w/o a load IS NOT a good suggestion.
What style output connections are you using?
1/4 inch, binding post, or Neutrik style?
Dec 29, 2008 | Peavey PV® 2600 2-Channel Amplifier
Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
  1. Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
  2. connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
  3. make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
  4. leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
You can even now turn off your subwoofer / adjust the volume easily now!
Oct 30, 2007 | Audio Players & Recorders
Peavey PV-215 Dual 15 2-Way Speaker Enclosure * Logo
62 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Jaime Hernandez
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
