Question about Craftsman 10" Table Saw
Wire diagram for craftsman 10" table saw
I changed the switch on my craftsman 10" table saw. Dah ; thought I could remember where the wires connect, BUT I GUESS I CANT! can anyone tell me how /where the wires connect for saw model #137.248880on the reset button and the main switch. There is only 2 white and 2 black wires , the ground I know. thanks
    New Friend:
Hi there.
Prior to plug it try this.From your 3 prong grounded plug trace it up to your saw were you should have a black and a white from the same wire's end.Now the two whites are probably from the reset that you haven't replaced?Write back to let me know if this is right and I'll proceed.
Posted on Jul 27, 2013
  • 8404 Answers
SOURCE: i need the wiring diagram for my 10 table saw
Im guessing ... the motor is 110 volt AC (AC dont care if it is coming or going) ... find the two terminals in the motor and hook the wires back up. If it HAPPENS to be incorrect, the saw will run poorly or the overload will trip.
I wouldnt be afraid to use this method on my craftsman table saw.
Posted on Nov 03, 2009
  • 80 Answers
SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Posted on Jan 20, 2009
  • 4 Answers
SOURCE: wiring diagram for model 137.248830
SAME SAW I HAVE, I ASSUME YOU DONT HAVE THE ORIGINAL OWNERS MANUAL. GO TO SEARS.COM, AND TOWARDS THE TOP THERE IS A "PARTS" HEADER. CLICK ON IT AND ENTER MODEL NUMBER WHEN REQUESTED, THEY WILL ASK UP IF YOU ARE LOOKING FOR A SPECIFIC PART OR MANUAL . HOPE THIS HELPS
Posted on Apr 15, 2009
  • 384 Answers
SOURCE: key switch on Craftsman table saw
Switch is filled with sawdust. Disassemble and clean out.
Posted on Sep 14, 2009
SOURCE: Wiring diagram for a Sears Craftsman 110/220V motor
I found a local small motor technician who was able to help with the wiring configuration for the 110/220: I had wanted the motor to run on 110V
Posted on Dec 04, 2009
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
Model 36-979. Where can I get a wiring diagram for the power switch?
images for Delta Table Saws wiring diagram for power ...
Replacing a Table Saw Power Box and Switch. Rocket ...
? 7:45
https://www.youtube.com/watch?v=8A25b9BjkmY
Feb 12, 2014 - Uploaded by AdventuresInDIY
See how an in the way power box on a 10 inch Delta table sawwas switched out ... Would you happen to have a wiring diagramfor your saw.
Oct 28, 2015 | Delta Saws
Need wiring diagram for craftsman 10" mitre saw... mod # 113235220
You can download a wiring diagram for your saw in sears parts direct.
Aug 21, 2013 | Craftsman Saws
On a Craftsman 10" table saw Model 137.221960,
I have this saw. Motor just went on me (siezing up and smoking/burning) so if anyone can use parts then you're welcome to them. jmbombadil@yahoo.com in Conshohocken, PA.
Sep 20, 2011 | Craftsman 10" Table Saw
I have a delta contractors table saw that wont start. It has a Marathon Electric Motor 62-044 that hangs off the back. It has capacitors rather than brushes. When you turn on the swithch it does nothing. I...
Most likely to quit suddenly is the switch.
My table saw switch broke recently, and at first I thought it was the motor.
Over the years I remember seeing table saws fitted with a handy box and ordinary light switch to replace the table saw switch.
Check for power at motor: Sometimes the wire connection from switch has access box on the motor where you can get in and check for power.
Feb 01, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
My craftsman 10" table saw will not start. i flip the switch and recently it would "ping"...blade would spin briefly then stop. I could find "the spot" when turning on the switch to get it started but it...
No, it is more likely the motor. To check it tho, bypass the switch and see if it kicks right in when direct wired. That way you kno if it is the switch or the motor. J.
Jun 28, 2010 | Skil 10" Table Saw
Need wiring diagram for a Craftsman Table Saw Model 113.298050
Keep your model number handy and have a look around here. If you can't find the identical model, you may find one of similar vintage with a wiring diagram that will suit your needs.
Otherwise, you may have some luck at the sears support site, at www.managemyhome.com, though I have had poor results finding them there.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 05, 2010 | Craftsman 10" Table Saw
Craftsman radial arm saw 113-197751 wiring diagram needed
A friend just inherited a model 113.197110 and we are in the process of trying to restore it. I can draw you the wiring connections if you haven't figured it out yet.
Apr 04, 2010 | Craftsman 10" Table Saw
I need to replace my table saw switch assembly
I am not getting either # from sears parts. I deal in Craftsman Belt drive table saw parts. I should have a switch that would work for you. Can you send a picture? jimatcavanaungh@cs.com
Nov 03, 2009 | Craftsman Saws
Craftsman 10" Table Saw Logo
477 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
