ImageRUNNER ADVANCE C7065 Copier scan to a specific folder
Jowinson
  • 16 Answers
SOURCE: Creating a Scan folder
In this case, make sure that your Canon Copier Imagerunner C587OU has CD software that comes with it. You need to connect the Canon copier to the computer with a USB cable or through the parallel port which the Canon Copier may not likely have. Then on your Pc and put the cd in the Cd drive of the Pc, when your Computer prompts "Found New Hard Ware" direct the computer to install the Canon copier through the Cd drive, after the Installation the Computer and the Canon copier can now be able to communicate thereby allowing you to scan from your Pc to the canon copier.
Posted on May 08, 2008
SOURCE: scanning instructions for a Canon Imagerunner 6570 multifunctional copier
The scanner is black and white only.
Posted on Jan 06, 2009
idriss47
  • 26 Answers
SOURCE: e000 error message on canon imagerunner 2000 copier
Hello.
E000 means :
"The main thermistor reading does not reach 40oC 14 sec after the fixing heater goes ON (fixing low temperature error)"
Posted on Jan 20, 2009
  • 153 Answers
SOURCE: Scan documents on a network folder
yes it is providing it has a send kit installed on the machine, its called windows SMB scanning, and fairly easy to set up should be in your user manual on how to do it.
Canon Tech
Posted on May 20, 2009
hch2011
  • 458 Answers
SOURCE: I am having trouble scanning an image into a
Usually the images or documents requiring scanning or printing has to be displayed on a program like work productivity to allow for action buttons to be appears ready. For example, documents stored on hard drives are least printable or scan able directly from the medium where stored. Open the stored location is on the computer to display the document as pages before printer jobs are attainable.
Posted on Feb 02, 2011
How do I Scan from a C2020?
In regards to scanning from a Canon ImageRunner to a Mac, this used to be done via SMB. But then Apple modernized the SMB protocol in Lion & Mountain Lion & Mavericks, and Canon decided to remain in the dark ages with their old-fashioned SMB protocol support. So therefore, Canon ImageRunners are now incompatible with Lion (OS X 10.7) & Mountain Lion (OS X 10.8) & Mavericks (OS X 10.9) & Yosemite (OS X 10.10) & El Capitan (OS X 10.11) for scanning via SMB.
The solution is that we now have to use the FTP protocol for scanning, when scanning from a Canon ImageRunner to a Mac running Lion (OS X 10.7) or Mountain Lion (OS X 10.8) or Mavericks (OS X 10.9) or Yosemite (OS X 10.10) or El Capitan (OS X 10.11).
To use the FTP protocol, you first need to enable it on your Mac by going into the Terminal and typing this command:
sudo -s launchctl load -w /System/Library/LaunchDaemons/ftp.plist
After enabling FTP via the Terminal, go into the Sharing system preference. Enable File Sharing in the left margin. Add the shared folder where you want the scans to end up. We usually like to create a folder on the Desktop entitled "Canon Scans", so you can just drag this folder into the list of folders. Click on the "Options" button to make sure that AFP is enabled, but you do NOT need to enable SMB.
Now you can go into the Network system preference where you will need to manually assign a static IP address for your machine. The Canon ImageRunner will need this static IP address so that it can find your Mac.
Once you've done all of the above, you can now create a new "one touch entry" on the Canon ImageRunner printer to scan to the shared folder on the Mac.
To do this, click on the physical button on the copier that says "Additional Functions", then press "Address Book Settings".
Then, on the Canon ImageRunner screen, press "One Touch Buttons".
On the next screen, press an existing name to edit it, or press a numbered button to edit a new name. (You can scroll through the pages with the arrows on the right.) You must press the "Register/Edit" button to add or edit that button.
If you're adding a new button, then on the next screen, you'll have to press "File".
Then you'll be taken to the next screen. The information to type in is the following:
Name: Give the button a name
One-touch Button Name: Give the button a short name that will fit on a button.
Protocol: FTP
Host Name: The static IP address that you assigned to the Mac. Do NOT use any special characters or slashes... just enter the IP address.
Folder Path: shared folder name. The trick to this is that you have to give the path from the starting point of the home folder. So if the shared folder is named "Canon Scans" and it sits on the desktop, then type in this file path: "Desktop/Canon Scans" (without the quotes).
User: the full account name of the account which owns the shared folder.
Password: the password for the account which owns the shared folder.
And that's it! You are now all set to scan from your Canon ImageRunner to your Mac!
I hope you enjoyed this article. If so, please donate a small amount via Paypal so that I can continue to post blog articles in the future.
Jul 15, 2014 | Canon for IMAGERUNNER C2020 C2050 C2058...
Scan and Send not sending - CAnon Image runner Advance 5045 - was working 3 weeks ago - not working now
working 3 weeks ago. well, something must have changed in your network since then, check smtp server with your mail provider if it is scan to email. if it is scan to the file, check firewall, ip addresses, destination folder, login and passowrd to the destination pc.
Jul 31, 2013 | Canon imageRUNNER 5000 Copier
Replace waste toner container imagerunner c7065
On the right side of the copier towards the back lower corner you will find the cover to the waste toner tank, a single screw holds it in place, remove the cover panel, behind it is a large plastic bottle pull it out empty it put it back in, pay attention on how it comes out so you will be able to replace it, may have to pull the lid holder out first.
To clear the error after changing the waste toner container on Canon C7065 Image Runner Advance, from the control panel, click on the setting/registeration button. Logon to the machine, you will need admin ID # and pin #, Once logged in pick adjustment/maintenance, on the next screen pick maintenance, then use the arrow key and chose page 2 on the next screen touch initalize after waste toner replacement.
Apr 01, 2012 | Office Equipment & Supplies
I've connected my IR1023iF to the network. The printer and fax work fine but the scanner doesn't work at all.
If you've hooked up the copier via ethernet cable then it needs to be setup for scan to email, FTP or scan to folder (smb). This can be done through the copiers web interface which is accessed by typing the copiers IP Address into your web browser. If you've hooked the copier up via USB, then there is 'toolbar' software that you would use for scanning. If you need the software, let me know and I can post it on an FTP site. Just an fyi...I'm pretty sure that you can't hook up both ethernet and USB at the same time.
Nov 11, 2009 | Canon imageRUNNER 1023iF Black and White...
How to configure imagerunner c3100 as a printer on a network
what do you need to know?
you need to put a static IP address or set it to DHCP and load the canon print driver.
you need to create a tcp/ip port on the ip address of the copier
Aug 22, 2009 | Canon imageRunner C3100 Copier
Canon Tech
May 18, 2009 | Canon ImageRunner 3025 Black and White...
Canon IR C3100N Scanner Setup
Hi Its fair simple, if you are scanning to windows PC, Create a folder called scans in your C:\ drive. Share it and give all the permissions. Thereafter log on to your copier using the IP address in your internet explorer. Go to address, click address book one, click the second tab on your left saying register new address. thereafter enter you name, then change from FTP to SMB and then host name will be your computer name\ip address, followed by scans(\\computername\scans)just like that. followed by your username and password.
Thanks
Mar 12, 2009 | Canon imageRunner C3100 Copier
Scan document to pdf format
you have to set up on the machine to scan to SMB. you then creat a folder in your c drive to recieve the scaned documents the folder needs to be a shared folder and you have the option to recieve it im PDF format.     let me know if that helps you out.
Feb 11, 2009 | Canon imageRUNNER 2020 All-In-One Laser...
Installing of canon iR8500 digital copier
Hello ms1974,
I appologize if I responded in to you question in a curt manner. I am afraid I lumped your question in with ones like "I can't scan to e-mail, do i need a network cable?". However your question is rather wide open as far as what your needs are and what the device is capable of and what your question is. If you need to scan to a folder, (individual workstation or server) you will need to make a shared folder. Some customers want a shared folder on the server so that everyone can access it. Some people want individual shared folders constructed for each user. Some want both or neither. Because of security, many companys opt for strictly scanning to e-mail, as it can be monitored, tracked, and controlled by the IT people easily. The setup for each is quite different.imageRUNNER 7200_8500_105 Sending Function Guide.pdf . This should help you. If have more specific questions after reviewing this document then please allow me to help you.
Jun 30, 2008 | Office Equipment & Supplies
May 07, 2008 | Office Equipment & Supplies
53 people viewed this question
jasbo
jasbo
