Question about Dixon Ticonderoga Office Equipment & Supplies
Turn on bluetooth bt1818 usb/sd
How do i turn on my bluetooth on my mp3 frontloader dixon bt 1818 usb/sd bluetooth
How/where do I enter pairing code?
When you want a bluetooth device to connect to your computer's bluetooth receiver, you have to set up the 'password' (which you decide) on both your PC/laptop AND your external device (e.g. BT enabled mobile phone). Generally on the PC/laptop this will be via the drop down menus got by right clicking the BT symbol on your desktop and selecting 'properties' (or via the start menu listing for BT device etc). Then for example your mobile phone's BT menu, via its settings. Do this for each external device. Sometimes devices come with a preset passkey/pairing code which can be a default of 0000. Consult device documents. If the device has no preset then set it up to be the same as the one you set for your PC BT receiver. Test the link by sending (TX) a file to the external device & vice versa (receiving device must be set to receive FIRST)
Dec 15, 2014 | VIA Computers & Internet
How can i get my pic's off my cdma phone no sd card no usb this is a lg 230 phone and my phone comp.. say that they are taking down the cdma but need pic's for court any help thanks
Check if the phone if Bluetooth capable, then you can send the pictures via bluetooth to another BT device (Computer, phone, tablet). If not, take the most important and send it by email. Because is not a new phone, probably the pics have little resolution, you may send a bunch in just one email.
Dec 04, 2014 | LG Cell Phones
Pairing manual for Craig CMA3532BT
To Pair:
1. Turn on your Bluetooth speaker (slide switch to BT)
2. Light on bottom should turn on Blue. If not, plug speaker into USB connector and bottom will turn Red to indicate it's charging.
3. Make sure Bluetooth is turned on your PC or Phone. Select device name: CMA3532BT.
4. Enter pairing code (passcode): 0000 or you can try: 1234
Apr 19, 2013 | Audio Players & Recorders
How to pair craig cma3532bt
To Pair:
1. Turn on your Bluetooth speaker/headphones (slide switch to BT)
2. Light should turn on Blue. If not, plug speaker into USB connector and light will turn Red to indicate it's charging.
Jan 03, 2013 | Radio Communications
I'm trying to transfer photos from my lg to my computer and have been told the easiest way is to bluetooth it. However, I cannot find bluetooth on my 620g
If you cant find your Bluetooth settings, you can still activate your BT by the ff steps.
  • open or turn-on the Bluetooth of your computer.
  • select picture(s) from your phone.
  • Tap SEND. then a new sud menu will appear.
  • Choose bluetooth.
  • Find your computer's BT device. Then send.
But, if you want the fastest way, you can use either of these two:
  • Thru USB cable. - Connect your phone to your computer via a USB cable. choose MASS STORAGE for faster transferring.
  • Get your MicroSD from your phone and use a MEMORY CARD READER. In this case, you will transfer your photos with the same process of a CARD STICK>
Jun 19, 2011 | Cell Phones
What prosess bluetooth download because my system have not bluetooth so i want to download bluetooth pleace give me advice
as i can understand,your computer have no BT device and you want to active BT ,so you have to
buy a BT device[nearly of cost 150 Rs] and placed it in the place of usb cable.ok!
Sep 30, 2010 | Computers & Internet
Connect to internet?
This answer assumes that the reader is already using their SD slot and wish to use another way to connect to the internet. I'm going to show you how to connect a USB Bluetooth dongle using the Toshiba e350 USB host cable. After that you can choose to share a computer internet connection via ActiveSync/WMDC or use BT DUN and a wireless phone with existing internet plan.
Windows based PC software (only needed for ActiveSync based internet sharing):
ActiveSync or WMDC
Toshiba PC Bluetooth stack 7.10.04 (or latest version for your operating system, I'm using Windows 7)
PC Hardware:
Super Mini Bluetooth 2.0 Adapter Dongle (mine was VID 0A12 PID 0001 Broadcom BCM2045 "CSR" based)
WM2003 PPC software:
Zeno USB Host Drivers v6.0a
Toshiba PDA Bluetooth stack 4.01 (filename bltstk-401-en.zip)
WM2003 registry editor (TaskMgrv2.9_WM2003SE.zip is a free task manager and registry editor, very cool)
Opera Mobile 8.65 (optional)
WM2003 PPC Hardware:
Toshiba USB host cable
2 or 4Gig SD card (for e350)
I'm going to target a Windows 7 PC with USB Bluetooth adapter, Windows Mobile Device Cener (WMDC), and an already partnered and synced Toshiba e350/355. The reader should already have a 2Gig SD card in the e350; remember WM2003 doesn't support SDHC. Any software to be installed onto the device should be done through ActiveSync Add/Remove and should not be installed to the default internal memory, but instead to the SD card.
Let's start by loading the e350 software. Install the Zeno Host drivers, followed by the Toshiba 4.01 stack. There is a newer version of this stack but it didn't work for me, so find the older bltstk-401-en.zip. The registry editor is needed for ActiveSync internet connection sharing but optional for BlueTooth Dial-up Networking (BT DUN). I'd recommend installing Opera Mobile as well. Be sure to press the reset button on the back of the e350 when done. You may now connect the USB host cable with Bluetooth adapter.
On the Windows PC connect your Bluetooth adapter and install the Toshiba PC bluetooth stack. Power up the e350 and, after a short time, there should be a wireless icon in the lower right hand corner of the main window. Back to the Windows PC, double click the Bluetooth icon in the task tray and you should be prompted to create a new connection. After awhile it should recognize your Pocket PC. If at any time you are prompted to insert a password for secure connectivity, write down a number (preferably 8 or more digits) and type it in. It will probably ask on the Windows PC first but once you continue immediately check your e350 since it will now prompt for the same password. Once it has been entered in both devices they are now "paired".
Tap the wireless icon on Pocket PC then Bluetooth Settings. Tap the magnifying glass to search for connections, your PC should already be listed as a remote device. Tap and hold over the name of your PC in the upper portion of the window and select Update Service. At least one COM port should be listed in the lower window. Tap and hold over it's name, then tap connection registration.
On the Windows PC open WMDC and select Connection Settings. Change the "Allow connections to one of the following:" drop down to the COM port listed on your device and be sure it's checked. The other settings should be default.
On the Pocket PC tap ok to close Bluetooth settings then tap Start > Programs > Bluetooth Folder > Bluetooth Connection. This will initiate an ActiveSync session and, if everything has gone well, it should connect, perform a sync then immediately disconnect. I have a problem with the immediately disconnect part, that's where the registry editor comes in. Using your preferred registry editor locate the HKEY_LOCAL_MACHINE\SOFTWARE\TOSHIBA\Bluetooth\DeviceProperty\Mode\ActiveSync\AutoDisconnect key. It's default value shoule be 1 but we want to change it to 0 thereby preventing ActiveSync from disconnecting after it sucessfully syncs.
With that done you'll probably need to reset the e350 again. At this point, because ActiveSync is set to share the computer internet connection by default, the next time you connect you should have internet access. Open your preferred web browser and check. When you are done with the internet, tap Start > ActiveSync and the Stop button. In Windows 7 as long as I'm connected I can see the Pocket PC in Windows Explorer as if it were an external drive. This makes it very easy to copy files back and forth wirelessly. Initially I set up a bridged PAN connection but, to be honest, ActiveSync works much better all around.
For BT DUN you'll need a properly configured and enabled Cell Phone with bluetooth DUN capabilities. Simply make the phone "visible" and search for it as you did the Windows PC. Pair with the phone, Update Service and register Dial-Up Networking. Tap Start > Settings > Connections tab > Connections > Add a new modem connection (Tasks tab). Enter a name for the connection and choose Bluetooth Card as the modem, then set the dial-up number, User Name, and Password from your Cell Provider. On the Advanced tab (next to Tasks tab) you may want to tap Select Networks to verify "Programs that automatically connect to the Internet should connect using:" My ISP.
You can set up ActiveSync Internet sharing along side BT DUN. When ActiveSync is connected it will automatically be the source internet connection. When disconnected, the e350 will automatically attempt to use the BT DUN connection instead.
Why not use the default Microsoft BT stack on the PC? It doesn't publish any real services, just a COM port that I never got to work. The Toshiba BT stack does have a 30 day warning so you might need to fix that.
For me the total cost of setup was about $30. The host cable was $15, the SD card $10, and the USB BT dongles were $2 apiece.
Nov 03, 2009 | Toshiba e350 Pocket PC
I want to know how to get my images and music from my phone onto the computer?
There are 3 ways.
The first is to connect it with a USB cable and software that came with the phone.
Second is to use the bluetooth option but your computer must have bluetooth too.
Third is to copy images to micro sd memory card and then attach it to a card reader on the computer.(with the adapter)
Please rate answer if it worked if not let us know.
Thanks
Oct 15, 2009 | Samsung SGH-F210 Cell Phone
Acer aspire 4730z bluetooth problem
Yes your Machine got WPAN: Bluetooth® 2.0+EDR (Enhanced Data Rate).
If its not working then you need the drivers, you can download them free here
If you problem was solved, Kindly do Rate!
Jul 31, 2009 | Sony MEX-BT2500 CD Player
24 people viewed this question
Top Dixon Ticonderoga Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dixon Ticonderoga Office Equipment and Supply Expert? Answer questions, earn points and help others
