Dell rps-600 I need to find a diagram or pinout for the dc cable for a dell rps-600 cable, can you help?
SOURCE: Please help.... I need a wiring diagram or pinout for my Jensen xa1120 amp, thanks
xa 1120 amp pin out 123
456
1 left neg
2 ground to radio
3 left positive
4 right neg
5 blank-not used
6 right positive
Posted on Oct 10, 2008
farr64
  • 121 Answers
SOURCE: need wiring diagram or pinout
try tracing the user manual on the web punch in the model no ect .this should give you the answers.good luck farr64
Posted on May 08, 2009
  • 3289 Answers
SOURCE: NEED A WIRING DIAGRAM FOR
Here's your Lincoln Idealarc Owner's Manual.
If this was helpful, please rate it 4 thumbs up - thanks & good luck!
Posted on Sep 25, 2011
alicantecoli
  • 22326 Answers
SOURCE: mitsubishi challenger pinout diagram for instrument cluster
No chance the manfacturers do not release this sort of information or the ECU pins only to the dealers .
Posted on Feb 11, 2012
ghost2233
  • 3606 Answers
SOURCE: Please can anyone tell me the pinout for DC power jack on dell latitude d600 motherboard ?
Hello the homepage is here:
http://www.dell.com/support/drivers/us/en/ussoho1/Product/latitude-d600
The power supply produce 90 watts,19,5 volts, 4,5 amps.
Here is youtube video with that problem:
http://www.youtube.com/watch?v=94rTbuP3txc
And part 2:
http://www.youtube.com/watch?v=C1TEaZI83Uc&feature=relmfu
You can buy a new here:
http://www.amazon.com/Power-Jack-Dell-Latitude-D630N/dp/B0040DDBPY
good luck
Posted on Nov 06, 2012
I need to know the pinout arangement on a eclipse AVN 600 trying to solder directly to the pins for a benchtest Kind Regards Justin
Is it an avn6600? If so you can download the owners manual from eclipse it should may have the Pino it or a diagram from which you can figure it out. I would try contacting eclipse and getting a new harness.
Jul 04, 2016 | Eclipse Car Audio & Video
Will a NVIDIA GeForce gt 610 graphics processor work on a Dell Dimension 2400 PC Desktop
YES, Zian it will work....BUT,....................
1) It is a PCI graphics card, and uses a PCI expansion slot.
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2898922&CatId=319
The Dell Dimension 2400 Desktop PC's motherboard, has three long white PCI slots,
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/techov.htm#1105465
http://www.ebay.com/itm/Dell-Dimension-2400-Desktop-Motherboard-System-Main-Board-F5949-K5148-G1548-/190750417467?pt=Motherboards&hash=item2c699c623b
http://en.wikipedia.org/wiki/Conventional_PCI
If one of those long white PCI slots is open, you can use a PCI graphics card.
Concerned that the graphics card uses DDR3 graphics memory, and your computer only uses DDR Sdram ram memory?
Don't be.
The graphics card has it's own processor (Graphics Processing Unit), and graphics memory.
It runs independent of the system resources; the Processor and Ram Memory.
http://en.wikipedia.org/wiki/GPU
The concern is the Power Supply.
Original power supply's maximum rated Wattage is either 200 Watts, or 250 Watts.
The above graphics card requires a minimum system requirement/power supply requirement; of 300 Watts.
I would recommend replacing the Power Supply.
(Especially with it's age, if it is still the same one)
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1389575&CatId=1078
ONE thing though..............
Watch the 20-pin ATX main power cable connector, and the wires in it. Be sure they are in the standard place setup.
Check the pinout, and color code of the wires,
1) Dell Dimension 2400 desktop computer, 20-pin ATX main power cable connector pinout,
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/techov.htm#1105612
2) STANDARD 20-pin ATX main cable connector pinout, and color code of wires; as set by JEDEC,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
[Be aware that the ATX main power cable, and connector, you get with a new power supply; such as the above, will have a 20 =4-pin ATX main power cable connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4
Use the 20-pin connector, tie the 4-pin power cable up out of the way]
For a time period Dell was making the motherboard's main power cable connector - Proprietary.
Meaning they has that motherboard connector wire pinout changed.
Colors of wires were in a different place, than the standard setup by JEDEC.
Orange wires are 3.3 Volts (DC)
Red wires are 5 Volts (DC)
Yellow wires are 12 Volts (DC)
Black wires are Ground wires.
Guess what happens if a 12 Volt Yellow wire, is plugged into where a Black Ground wire is supposed to be?
ZZZZZZzzzzt! Motherboard fries, processor fries, ram memory fries, and graphics card. (If used)
Check the color code of the wires, in the 20-pin ATX main power cable's CONNECTOR, for the Dimension 2400's power supply.
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 14, 2012 | Dell Dimension 2400 PC Desktop
My cash drawer in not working
Kindly check the Data cable ( RJ11) if connected properly, connector points turned green. Try Changing it.
hope below links help you
6 pin RJ12 6P6C male connector diagram and applications pinouts RJ12 to rs232
Pinout cable and connector diagrams usb serial rs232 rj45...
Sep 13, 2012 | Partner Tech PT-8800 POS Terminal -...
I have need vga cable diagram
Hi, the pinout look like this:
Sep 20, 2011 | Dell E551 15" CRT Monitor
Pin diagram for psc 8-0065-56 RS232 cable
Hello friend,
Despite seeing his request the RS232 serial cable pinouts 8-0065-56 is old, I wonder if you got the pinout of this cable and could send me, I have a big problem to solve and need this pinout if I could help will be very grateful
Hug john son
Mar 05, 2010 | PSC VS1000 & VS1200 Accessories - P/N...
I need the PCB to power socket pinout connections for a dell 1545 laptop
Hi, try this link, it may help you butmay be not.
http://support.dell.com/support/edocs/systems/ins1545/en/SM/index.htm
I'm not wuite sure what the power socket looks like, but normall it's a center pin dc style socket.
the rest of the solder connections are just anchore pins.
I hope this has helped in some way.
Regards - Anthony
Feb 01, 2010 | Dell Inspiron 1545 Notebook
VGA connector on a Dell e770s 17 inch monitor has been cut. Need to know where the wires go on a 15 pin db connector?? Can anyone help...Thanks gvp
Found out the information thru this page. Its a diagram of the 15 pin VGA Pinout and where the pins are supposed to go and what there fuctions are, hope this helps. Page is courtesy of pinouts.ru
http://pinouts.ru/Video/VGA15_pinout.shtml
Aug 29, 2009 | Computers & Internet
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
